Sponsored by:
Sponsored by: CARiD
Tested: 04 VQ35 IM on 98 VQ30
Old May 2, 2005 | 09:50 AM
allen222's Avatar
Hello
This weekend I tried to put the intake manifold from an 04 Maxima onto my 97 Maxima engine. The lower manifold will bolt on just fine and appears to form a tight seal to the heads however, the holes for the injectors are different. If you want to use the 04 Maxima lower IM you will need to dremel the injector holes on your VQ30 heads slightly, not much, but some. The upper intake manifold hit the coil packs as well but that could probably be solved with a little effort. I gave up because of other issues with my particular application.
Of course you will need to use a top feed fuel rail and top feed injectors. The 04 fuel rail is a returnless type and is probably not the best way to go. The 00 VQ30 uses a top feed returnable type, that is what I was going to use but gave up before I got the chance.
Hope this helps someone,
allen
Old May 2, 2005 | 10:28 AM
Ninos_Maxima's Avatar
be the change u want2C
1 question, why did you try this? Any special reasons, im curious
Old May 2, 2005 | 10:42 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What were you planning to do about the heads intake port vs. LIM different shape/angle?
Old May 2, 2005 | 10:54 AM
Larrio's Avatar
The Definitive AE Master
yes, i'm interested in icey2k1's question also.
the vq30 heads have oval shaped ports where the lower IM meets up to it. The vq35 heads have round circular ports where the lower IM meets up to it.
Old May 2, 2005 | 10:57 AM
allen222's Avatar
I need an IM that will allow for a side or front entry throttle body to go into a RWD chassis.
allen
Old May 2, 2005 | 10:59 AM
allen222's Avatar
I wasn't going to worry about it, I've got enough issues to deal with on this project to worry about a relatively minor mismatch in port shapes.
allen
Old May 2, 2005 | 11:12 AM
NmexMAX's Avatar
dot dot dot ...
What exactly are your plans for your max?
Old May 2, 2005 | 11:25 AM
Stephen Max's Avatar
allen
It may look like a minor mismatch, but there are six of them and they will lower your volumetric efficiency. The higher the rpm, the greater the loss in VE.
Old May 2, 2005 | 11:26 AM
IceY2K1's Avatar
Pathfinder VQ35 is your friend....
allen
Old May 2, 2005 | 11:44 AM
allen222's Avatar
It may look like a minor mismatch, but there are six of them, and above a certain rpm they will lower your volumetric efficiency.
I'm sure your right.
allen
Old May 2, 2005 | 11:49 AM
allen222's Avatar
That's what it's lookin like, if there isn't hood clearance for a custom tubular type IM I'll look for one of those.
allen
mclasser
22
Nov 12, 2020 01:58 PM
A32goldylocks
Sep 14, 2015 06:49 PM
soloist3
29
Sep 1, 2015 03:47 PM
Balkins
Aug 9, 2015 02:48 PM
