Sponsored by:
Sponsored by: CARiD
Can you post your hybrid motor config? (Block config and manifold)
Old May 4, 2005 | 06:06 AM
deezo's Avatar
I just want to see what's the most effective config for HP in hybrid motors only.
Thanks.
Old May 4, 2005 | 09:07 AM
Stephen Max's Avatar
VQ30DE block, heads and lower intake manifold
2000 upper intake manifold
2001 Pathfinder throttle body
Old May 5, 2005 | 04:58 AM
deezo's Avatar
Nice to see you're the only one that has a hybrid setup.
Come on guys!
Soon as someone talks about a turbo, you guys are all over that ish.
Old May 5, 2005 | 11:31 AM
Kevlo911's Avatar
Kevlo for President
VQ30DE Block, head
2000 Upper and lower manifolds w/ injectors
4th gen TB and IACV
Full working EGR system and NO Cel's
Old May 5, 2005 | 11:52 AM
krismax's Avatar
Father of the 00 VI
Come on guys!
Ill tell you when i get my car ,still waiting paitently
Old May 5, 2005 | 12:15 PM
deezo's Avatar
I thought you did a full swap? Either way, I can wait.
Old May 5, 2005 | 12:19 PM
Kevlo911's Avatar
Kevlo for President
If you get your car
Old May 5, 2005 | 12:32 PM
nismology's Avatar
HUH?? Doesn't hybrid refer to mixed-and-matches block/head combos?? I don't think a different intake manifold consitutes a hybrid. Even thought the 00VI doesn't exactly bolt-on perfectly, it's still a bolt-on.
Old May 6, 2005 | 08:53 AM
deezo's Avatar
If the manifold came off of another motor, that constitiutes hybrid to me. It all depends on the level you want to build the motor up to.
Old May 6, 2005 | 09:24 AM
nismology's Avatar
But it's a BOLT-ON. A different intake manifold doesn't mean you're building the motor up. It's an EXTERNAL modification. A hybrid motor in terms of the maxima means 3.5 block with 3.0 heads or vice versa. Anything external is a bolt-on, no matter the customization required to make it fit. But hey, it's your thread. I'll shut up.
Old May 6, 2005 | 10:26 AM
deezo's Avatar
It really has nothing to do with my thread which is going nowhere anyway; if your mixing parts from another motor (other than the same type), who are we to say it's not a hybrid? Who cares if it's a screw or a hose?
If you mix and match parts from one black to another, it's a hybrid. Why define it only to rods, pistons, heads and crank? The manifold feeds it all and is a component of HP also. Japmax has a full 3.5 with a MEVI, would that not be call a hybrid also?
What I'm looking for here is what configurations that have been done and work without issue for the benefit of extra HP.
Old May 6, 2005 | 10:40 AM
96sleeper's Avatar
Do heads not bolt-on? Do cranks and rods not bolt-on? The word hybrid means whatever he wants it to mean. Hybrid means to me, mixing parts from different engines, no matter the level. My hybrid is:
stock 3.0 block and heads
MEVI
PF TB and custom adapter plate
Old May 6, 2005 | 11:23 AM
nismology's Avatar
MEVI
Bolt-ons in the general sense refer to external modifications. An intake is a bolt-on, as is a y-pipe. But if you want to take it there Stillen superchargers bolt-on too, but you'll never hear somebody with any sense call it a "bolt-on" modification. How can you call a motor a hybrid if it's stock internally? The motor itself remains unchanged, regardless of what's on the outside. You can call a 00VI/Pathy TB a hybrid configuration but surely not a hybrid MOTOR configuration.
deezo- Japmax has a 3.5 block/3.0 head combo. That is a hybrid motor.
Of course there is no strict definition to what "hybrid" means, but it has been generally accepted on the org as being used when a different head/block combo has been used specifically.
A different intake manifold makes a motor a hybrid just as much as I/Y/ECU is "all-motor".
Old May 6, 2005 | 11:34 AM
So we are being consistent, since most of the threads in this forum have to do with 00VIs on 4th gens.
Old May 6, 2005 | 11:50 AM
deezo's Avatar
So even if he had a full 3.5 with a MEVI, it wouldn't be a hybrid? This debate is weak.
Notice I said mixing of parts from one motor to another (not from some store's shelf to your motor) results in a hybrid motor. SC's, CAI/HAI's and y pipes are "Off the shelf" bolt ons. They don't come from a production engine made by any particular car manufacturer. You add them as aftermarket parts. Hybrid is mixing of engine parts and the intake manifold is an engine part also.
There are levels of the extent we modify our cars, so heavily and some lightly. It's the same with building a hybrid motor.
Does it mean the car is not modified if it just has a Y pipe as opposed to and everything else that can go on the car?
nismology's Avatar
Old May 6, 2005 | 11:52 AM
nismology's Avatar
I never said that it wouldn't be a hybrid configuration. My point is that it wouldn't be a hybrid MOTOR configuration because the motor ITSELF would be stock internally. That's the difference. The title of your thread asked for hybrid MOTOR configurations, and only japmax's car fits this description. Everyone else in this thread has hybrid intake manifold configurations. It's just a matter of semantics i supppose. :shrugs:
Edit: I'm done with this thread...
Old May 6, 2005 | 11:58 AM
deezo's Avatar
Shame on you.
Just remember when talking about motors, intake manifolds are a part of them. That's why the title of my thread asks for BLOCK configs and MANIFOLD. Everyone is using something different.
Old May 6, 2005 | 12:08 PM
nismology's Avatar
Shame on you.
Understood. Sorry for the whored thread
Old May 6, 2005 | 01:16 PM
96sleeper's Avatar
If you want to get technical, we are talking about engines. Motors are run off electricity.
Old May 6, 2005 | 01:21 PM
deezo's Avatar
Old May 6, 2005 | 04:56 PM
nismology's Avatar
Actually, "motor" is the proper term. http://www.m-w.com/cgi-bin/dictionar...=motor&x=0&y=0
Old May 6, 2005 | 05:50 PM
JeffesonM's Avatar
living out of a maxima...
maybe a moderator could clean up all the crap in this thread?
Old May 6, 2005 | 08:12 PM
Nismo3112's Avatar
Custom User Title
3.5 Block
3.5 heads
3.5 IM
3.0 Timing
3.0 Oil pan
95 ECU, DE-K Injectors, DE-K FPR, 3.5 Fuel Rail
Old May 6, 2005 | 08:33 PM
japmaxSE's Avatar
Go Get a Life!
3.5 Block
3.5 Cams
3.0 Heads Prt'd
3.0 upper & Lower Pan
3.0 Timing
MEVI
Old Jul 27, 2005 | 02:35 PM
Max1man's Avatar
Originally Posted by Nismo3112
3.5 Block
3.5 heads
3.5 IM
3.0 Timing
3.0 Oil pan
What TB you using?
Old Jul 27, 2005 | 02:58 PM
nismology's Avatar
He's using the 2k2 TB modified for use with a cable.
Old Jul 27, 2005 | 03:00 PM
Max1man's Avatar
Any linkage to info on that process?
Old Jul 28, 2005 | 07:49 AM
DandyMax's Avatar
3.5 in the works
I spose I'll add to this list just for fun...
3.0 block and heads
2000 Lower and upper IM
2001 PF TB
lowpost99
Oct 26, 2025 06:53 PM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
AcuraLegend
Sep 22, 2015 04:22 PM
