Sponsored by:
Sponsored by: CARiD
VQ Intake Generations Questions
Old May 9, 2005 | 03:56 PM
flashover's Avatar
Ok, from simple inference through the threads, I am wondering if there is a difference in actual parts between the 2000 VI (vs) 2001-2003 Intake manifold.
They are both the black plastic VI right? Or am I missing something when I look at everyone's cardomain pics?
Thanks, Mike
Old May 9, 2005 | 06:47 PM
NmexMAX's Avatar
dot dot dot ...
Mike,
You're missing that the 00-01 is plastic on a 3.0 and the 2k2 + is cast aluminum sitting on a 3.5L. The 00-01 is the same part number.
Old May 10, 2005 | 09:42 PM
SR20DEN's Avatar
VQ Wizard
Thanks, Mike
And if you want to swap your manifold you need to locate a 2000 (Fed Spec) VI because it has the EGR connections and the 2001 VI does not.
Old May 11, 2005 | 04:59 PM
flashover's Avatar
Originally Posted by SR20DEN
And if you want to swap your manifold you need to locate a 2000 (Fed Spec) VI becuase it has the EGR connections and the 2001 VI does not.
Now I understand, Thanks for the replys.
SR20DEN, so 2k unless I bypass the egr...
What is your opinion about just cutting it out. I appreciate your suggestions due to your weighted experience.
- Mike
Old May 11, 2005 | 07:39 PM
SR20DEN's Avatar
VQ Wizard
IIRC some .org members were working on an appropriate bypass to fool the ECU. It's doable and may be worth a try.
MAXSE5SPD
Sep 17, 2022 04:00 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
