Sponsored by:
Sponsored by: CARiD
What kind of work should I be expecting (VI)
Old May 21, 2005 | 06:31 PM
|Bijan|'s Avatar
UCF Lexus
Using my 4th gen plenum, 4th gen stock fuel rail/injectors, 5th gen TB - what kinda of work will need to be done? The threads Ive seen (I may have overlooked a few) dont include this setup.
I know the plenum has to have 2 holes drilled...but there's one stud sticking up on 1 side of the plenum...do I need to knock it out?
If I wanted to run it with fully bypassed EGR, will the ecu throw codes or will it not recognize it at all?
Advice on how to mess with AICV and other necessary mods to get the VI on?
What RPM switch did you choose? Is there a writeup on the install of that?
Old May 22, 2005 | 06:35 PM
mansurxk's Avatar
bump squared, im goign to do this EXACT setup on mine
Bijan- THT and Nismo3112 have done it ive been asking THT about all the details, im waiting on adapters from vsamylov for the TB and IACV...
Old May 22, 2005 | 06:53 PM
Kevlo911's Avatar
Kevlo for President
Ecu will throw codes, contact BSwith(spell?), I believe he has bypassed the EGR system w/ the use of resistors to eliminate ECU codes. Also he can help you wire up the 5th gen IACV, it is built into the 5th gen TB.
You can use the Summit RPM switch.
Old May 22, 2005 | 07:15 PM
Terran's Avatar
This one?
Is it this one or the harlan that alot of MEVI guys had problems with? Is the harlan even sold anymore?
Old May 22, 2005 | 07:19 PM
Kevlo911's Avatar
Kevlo for President
That link just shows me the search:
http://store.summitracing.com/partde...=KeywordSearch
Old May 22, 2005 | 07:39 PM
Terran's Avatar
Oh sorry. The one you linked was the one I meant to link to.
Old May 22, 2005 | 09:45 PM
THT's Avatar
THT
Throbbing member
I have my EGR completely disabled but no codes. I've had a couple people tell me it's not possible but it is. I checked for codes today and no codes.
Old May 23, 2005 | 06:39 AM
Kevlo911's Avatar
Kevlo for President
You prob left hte sensors hanging in the engine bay, huh?
Old May 23, 2005 | 03:17 PM
THT's Avatar
THT
Throbbing member
Yeah. But a few people have said that doing so would trip the CEL.
Old May 23, 2005 | 03:51 PM
jmeister's Avatar
I'll probably be bugging you experienced installers this weekend w/ all kinds of questions about this.
Finally got some down time for the install and plan to have mine up & runnning w/ VAFC this time next week... it's gonna have to be if I want to get back home.
Old May 23, 2005 | 07:56 PM
THT's Avatar
THT
Throbbing member
Be sure to read the many threads in this forum on this topic first as it'll answer most of your questions. All Motor should almost be renamed to "4th gen 00 VI How-To"
Old May 24, 2005 | 08:52 AM
eckohb's Avatar
i just bought my 00 upper IM yesterday. Im ordering the switch, and adapters this week. Me and another org member will be doing the install. What exactly needs to be drilled? Does anyone have any pics? I'll be using everything 4th gen, just 00VI.
Old May 24, 2005 | 09:36 AM
jmeister's Avatar
There are all kinda pics & info in the all motor stickies about the 4th gen lower, etc. Stephen Max has some good stuff in there.
Old May 24, 2005 | 11:15 AM
Stephen Max's Avatar
In order to use the 4th gen lower IM, you will have to install it flipped around 180 degrees in order to get the bolt holes at each end of the IM aligned close enough to be able to use them.
Then you have to drill out two existing holes and install 6mm Keenserts or Helicoils (I recommend Keenserts.), and you have to drill two new holes to provide all the necessary mounting bolt holes.
You will also have to drill two holes at either end of the 00VI near the existing bolt holes.
Old May 24, 2005 | 11:21 AM
eckohb's Avatar
thanks for the info. i didnt even know there were how-tos/stickies on the VI. This looks like it oughta be fun
Old May 24, 2005 | 11:54 AM
Dubbya's Avatar
VK56 Inside
Do you think the same resistor fix could be used on a 3.5l swap running a 96 ecu? I know that my egr system will be non funtional because of the ecu controlled egr system in the 3.5l. I am just concerned with 1. getting inspected. I have a hook up for now, but I dont like to gamble. 2. the CEL light. Not a huge deal, but it would be nice not to have one.
Old May 24, 2005 | 12:07 PM
I've got mine hanging, and I get a CEL and code 10-5 after about two-three weeks of driving. I don't know why it doesn't show up sooner. I'm going to try the resistor trick.
Old May 24, 2005 | 12:16 PM
eckohb's Avatar
hey stephen max, do you also sell the adapter plates? i coulda sworn you did as well, but i may be mistaken
THT's Avatar
THT
Throbbing member
The only CEL code I pull is the one for the banks running lean. And that one comes on after I leave the car idling for 10+ min.
Old May 24, 2005 | 12:19 PM
I do. PM me.
Old Jun 14, 2005 | 01:38 PM
|Bijan|'s Avatar
UCF Lexus
bump...trying to get the VI on this week
Old Jun 14, 2005 | 05:36 PM
SDot82's Avatar
Good Luck
Old Jun 14, 2005 | 10:50 PM
eckohb's Avatar
i will also be attempting the VI on saturday. We'll need all the luck we can get.
Old Jun 14, 2005 | 11:24 PM
Nismo3112's Avatar
Custom User Title
What I did was enlarge the 2 inner holes on the 00VI so I could use long bolts that would thread into the holes that are already there. But doing it my way required some minor port matching on the lower IM, maybe less than 1mm on each of the ports.
I also only used a total of 4 bolts, (just like the 4th gen IM) to hold the 00VI down, and that doesn't seem to cause any probs.
Old Jun 15, 2005 | 10:29 PM
vsamoylov
hey i got some adapter plates in stock now. contact me if interested.
i have 2 iacv adapter plates
1 adapter plate if you are using the 5th gen tb
1 adapter plate if you are using the 4th gen tb
the iacv adapter plates are needed no matter what
but the other plates you need to decide which tb to use
Old Jun 18, 2005 | 09:05 PM
AsthmaMax11's Avatar
Hey Bijan
If you need an RPM switch I have a spare Harlan you can use. Just let me know, I am interested in how this turns out!
Old Jun 18, 2005 | 10:32 PM
Ninos_Maxima's Avatar
be the change u want2C
vs how much for the adapter plate for the 4th gen tb?
Old Jun 19, 2005 | 10:03 PM
vsamoylov
adapters are $60 each.
Old Jun 20, 2005 | 07:21 AM
eckohb's Avatar
damn, you raised the price quite a bit didnt you
Old Jun 22, 2005 | 12:03 PM
|Bijan|'s Avatar
UCF Lexus
Take that to PM
Does ANYONE have any other info. (please see my 1st post)
Old Jun 23, 2005 | 09:06 AM
Ka$hThaRipper's Avatar
^^ yeah, im going to try to tackle this soon..
how many and where exactly do the vacuum lines need to be run (from and to hwere)...
is it just ocmmon sense, and a repeat of what's already there under the hood?
Old Jun 23, 2005 | 09:12 AM
jmeister's Avatar
Common sense doesn't work.
Try the factory service manuals or use the search feature you paid for.
http://jime.homeip.net/files/FSM/
homeyclaus
Sep 3, 2015 06:15 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
kenc15
Aug 5, 2015 08:29 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
