Sponsored by:
Sponsored by: CARiD
View Poll Results: If you installed the 5th gen VI on a 4th gen:
used a 5th gen lower IM, had NO clearance problem
26.09%
used a 5th gen lower IM, did have clearance problem
21.74%
used a 4th gen lower IM, had NO clearance problem
21.74%
used a 4th gen lower IM, did have clearance problem
30.43%
Voters: 23. You may not vote on this poll
If you have installed the 00VI on a 4th gen, please answer poll
Old May 26, 2005 | 09:04 AM
Stephen Max's Avatar
Trying to determine what is causing clearance issues with coil pack mounts.
Old May 26, 2005 | 09:13 AM
DandyMax's Avatar
3.5 in the works
5th gen LIM ... on my 98 it didn't clear coil #'s 3 and 5. It hit the bosses as well as the coil pack itself slightly.
Kevlo was speculating it was the Mitsu/Hanshin coil difference... he may be on to something I'm not sure... since the bosses are hitting the valve covers have to be different too.
There doesn't seem to be any real height difference with the LIM's... unless perhaps the angle on the UIM mating surface is slightly different but roughly the same height through the centerline. I don't remember really noticing anything like that but then again I just took a couple quick measurements, didn't really study them carefully.
Old May 26, 2005 | 09:25 AM
I used the 4th gen LIM and had to grind the #3 and #5 coil mounting bosses on my 95.
Old May 26, 2005 | 04:04 PM
Terran's Avatar
I'm curious about this too...If those who vote could also post what they voted and the year of their car as DandyMax did I would appreciate it.
Old May 26, 2005 | 04:15 PM
THT's Avatar
THT
Throbbing member
I only used the DEK upper IM, everything else is from the DE and I had to grind down the mounts.
Old May 26, 2005 | 11:10 PM
s0ber's Avatar
I am installing mine this weekend, I will post back when I do, incase I do, i'll have the Dremel ready.
Old May 27, 2005 | 07:23 AM
Terran's Avatar
What kind of wheel do you use with the dremel. Would one of those stone grinding drums do the trick?
Old May 27, 2005 | 07:30 AM
Grinding stones can get clogged with aluminum. I would use the coarse-medium grit sanding drums. Actually the cut-off wheels would do a good job, too, and probably a lot faster.
Old May 27, 2005 | 08:01 AM
Terran's Avatar
Ok, I'll pick some of those up before I start just in case. Thanks.
Old May 27, 2005 | 09:02 AM
DandyMax's Avatar
3.5 in the works
Or a good die-grinder bit works quickly, especially with air tools.
So am I the only one with a 5th gen LIM who's had clearance problems?
Old May 27, 2005 | 09:05 AM
Terran's Avatar
We already have a dremel though, so I'll just stick with that.
I believe maxS also had problems and he also has a '98.
Old May 27, 2005 | 09:09 AM
SDot82's Avatar
I used the 5th gen LIM and had clearance issues. Used a hand held grinder took about two seconds do grind down the coil pack mounting bosses.
Old May 27, 2005 | 09:21 AM
s0ber's Avatar
At homedepot they sell little Dremel Kits, they have General Purpose, Cutting Kit, and Polishing...
They go for about $12/ea...
The general purpose should serve you well, it brings one big cutting wheel, and 36 regular sized cut-off wheels.
Old May 27, 2005 | 09:22 AM
Terran's Avatar
Well there goes the theory of 97 and earlier being fine.
Do the coilpacks have enough support when there's only one place to attach them?
Old May 27, 2005 | 09:58 AM
Yes, there's not really any load on them.
Old May 27, 2005 | 10:32 AM
BSwithTF's Avatar
I used the 5th gen lower IM but I used the 5th gen rear valve cover /5th gen rear coil packs as well so I had no clearance issues.
Old May 27, 2005 | 10:35 AM
tedo007's Avatar
faster than you think
I still don't understand why some of us have issues. I am using the 4th gen vavle cover, but am about to switch to the 5th gen one since i have to replace the vavle cover gaskets. They are leaking,
Kevlo911
Old May 27, 2005 | 10:45 AM
DandyMax's Avatar
3.5 in the works
Kevl, what were you saying about the differences in the two makes of coils?
Old May 31, 2005 | 07:32 AM
jmeister's Avatar
I have a 98 and had clearance issues w/ the 3 & 5 mounts and packs themselves using the 5th gen lower. They are the Hanshin coils.
Old May 31, 2005 | 07:36 AM
s0ber's Avatar
I have a 95 and I did have problems with clearance with the lower A32 valve cover...
Old Jun 3, 2005 | 10:58 PM
Jar's Avatar
Jar
I was just gonna pipe in with that, i've read a lot of posts about grinding the bosses down, why not just swap over the 5th gen valve covers too? is there any difference other than the lack of clearence in the rear?
Old Jun 4, 2005 | 09:36 AM
s0ber's Avatar
You could do that too, would make the swap MUCH easier, plus you wont have to figure out the PCV valve since it sticks out of the side, I might try to get a 5th gen VC one day, but there not that easy to get ahold of, thats why people use the A32 VC...
EDIT to my original post:
For the A33 VC you need the 5th gen rear Coil Packs .
Old Jul 10, 2007 | 05:58 PM
nismology's Avatar
I see some people like to vote in 2-year-old polls.
The LIM you use won't matter. It's which VC you use.
/thread
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
MikesChevelle
Aug 6, 2015 11:36 AM
