VQ35 swap pictures
Old 06-15-2005 | 05:19 PM
  #81
JClaw's Avatar
My mpg actually improved going from 3.0 to 3.5, but that is probably due to new O2 sensors, headers and new KS. Normally I get 320-330 miles on a tank but I drive it like it's rented. Driving like a granny I could easily get 400+.
Old 06-15-2005 | 06:26 PM
  #82
NmexMAX's Avatar
dot dot dot ...
From my 95-03, it went DOWN quite bad .. 26 down to 22. But it's apples to oranges since it's in a 4th gen body.
Old 06-15-2005 | 06:43 PM
  #83
vsamoylov
its not possible to drive like a granny.
Old 06-15-2005 | 06:53 PM
  #84
JClaw's Avatar
With so much nuts under the hood it's hard, but doable.
When there's an I/E 98 civic reving at you it's hard to resist putting 10 cars on him.
Old 06-15-2005 | 07:14 PM
  #85
aznsap's Avatar
lol, so lets say for example if the two cars (4th gen and 4th gen w/ 3.5L) are driven in the same manner. my brother has a '03 and i have a '95 and i've driven both and i get about 4 mpg more than he does.
Old 06-15-2005 | 07:20 PM
  #86
JClaw's Avatar
Weight has an effect. They say when you removed 100 lbs from a 3000 lbs car you increase mpg by 7 to 8%.
Old 06-15-2005 | 08:00 PM
  #87
Nismo3112's Avatar
Custom User Title
I get about 20 or so mpg in the city, 100% city.
Old 06-15-2005 | 10:08 PM
  #88
huyqvu's Avatar
vq35de right? from what car? since the max, pathfinder, and 350z are all vq35de just with different hp ratings.
Old 06-15-2005 | 10:13 PM
  #89
eckohb's Avatar
Max or Altima, since the 350Z is RWD, and the Pathfinder is too if im not mistaken
Old 06-15-2005 | 10:22 PM
  #90
vsamoylov
IMO nissan needs to stop lying about these different hp #.
Old 06-16-2005 | 12:00 AM
  #91
eckohb's Avatar
different trannies are going to put out different numbers. altima is 5 spd, maxima is 6 spd manual. 350Z is probably tuned more for the 287 hp number it gets. Pathfinder is rated at 265. so its not like they are "lying" so to say.
Old 06-16-2005 | 03:05 AM
  #92
huyqvu's Avatar
well if they all share the same engine code, is it possible that the only difference is the tranny? and if so, why cant we just get the motor from a 350z and slap on a tranny from a maxima?
Old 06-16-2005 | 03:36 AM
  #93
THT's Avatar
THT
Throbbing member
B/c the trans mounting is different. The Z is RWD whereas a VQ35 coming from a Maxima/Altima has the trans mounting for FWD.
Old 06-16-2005 | 04:28 AM
  #94
JClaw's Avatar
The truth about the HP numbers is that there are really only two different power outputs:
Pathfinder/Murano/Quest/Maxima/Altima= 240 HP, 260 lbs tq
350z/G35= 280 HP, 280 lbs tq
They got more torque than they want to admit, because Nissan thinks the public doesn't care about torque and only buys into high HP like Hondas.
Old 06-16-2005 | 06:41 AM
  #95
NmexMAX's Avatar
dot dot dot ...
Wha about the Z track edition .... Isn't it 350z, not x ..
Old 06-16-2005 | 06:46 AM
  #96
Kevlo911's Avatar
Kevlo for President
The new Z's(anniversary, ect..) Have a totally different IM so I am pretty sure they make more power.
Old 06-16-2005 | 08:55 AM
  #97
deezo's Avatar
Originally Posted by Stephen Max
If I remember correctly, Dubbya said 208 tq and 183 hp. The torque is not too shabby for an automatic, but the 96 ecu is holding him back at high end. A TS or JWT ecu with more advanced timing should make a significant improvement. And I need to make sure the VIAS is opening when it should.
It just kind of sucks to get on the dyno and expect good numbers. I was also disappointed but if has nothing to do with my mods. My serpentine belt started slipping at 5200 and also started smoking so my power dropped immediately afterward. I'm not sure if the dyno is really showing that the engine is not making power because of the serpentine belt slipping but I'll need to fix that issue and do another dyno here in MA.
Old 06-16-2005 | 08:58 AM
  #98
deezo's Avatar
Originally Posted by Kevlo911
Deezo you already home? How is the car?
I was in Mustang OK when I typed that and I almost got a chance to experience a tornado while I was there. I have some vids of the sky turning black.
The car is fine but I have some work to do and then I'll need to hit the dyno again. I guess I'll be hooking up with Zach to see where he goes.
Old 06-16-2005 | 09:35 AM
  #99
steph01's Avatar
the 30 th anniversary 350Z got less torque, but mor hp than the normal one.
Old 06-27-2005 | 12:50 AM
  #100
Fr33way™'s Avatar
Wild for Width
the 30th AE Z has 300hp
Old 07-28-2005 | 12:37 PM
  #101
Max1man's Avatar
Did we ever find out what Stephen set the Base Fuel Pressure to on that FPR?
Old 07-28-2005 | 12:39 PM
  #102
Stephen Max's Avatar
I set it to 53 psi.
Old 07-28-2005 | 12:41 PM
  #103
Max1man's Avatar
thank you sir
Old 07-30-2005 | 10:38 AM
  #104
RockfordMax's Avatar
Back from the dead
ok reading about all this engine swap mumbo jumbo, i thought of something. 350z blocks dont mount in our cars due to the transversal mount issues; however, if the new 350's are making 300hp, is it possible to take everything off of the rwd mount block and apply that to the fwd block? seems like this wouldnt be a problem. just my thoughts
Old 07-30-2005 | 10:42 AM
  #105
JClaw's Avatar
SR20DEN is making 263fwhp (about 310 HP crank) on a FWD VQ35 and his engine is stock. You don't need the z to make 300+ hp, but you need to tune it well.
Old 07-30-2005 | 09:34 PM
  #106
eckohb's Avatar
but whatd he do to his IM to make that hp?
Old 07-31-2005 | 09:07 AM
  #107
Jar's Avatar
Jar
Thats the part he doesnt want to spill at this point huh? I've seen that on a couple other threads.
Old 07-31-2005 | 03:54 PM
  #108
Back from the dead
i see. so basically the z is already tuned basically to SR20's setup, but from what i hear the Z manifold pwns us.... eek im confused now
Old 07-31-2005 | 04:07 PM
  #109
Nismo3112's Avatar
Custom User Title
The Z manifold is better than ours.
Old 07-31-2005 | 04:40 PM
  #110
mike96's Avatar
so sr20den's motor is tuned correctly to almost perfect? havent seen anybody else pull that power from the stock VQ35 correct me if am wrong
Old 04-08-2006 | 10:18 AM
  #111
Maxpower96's Avatar
Thx stephen for the pics...sorry for the delay in the response, i just came back from my trip.
Old 12-05-2006 | 10:33 AM
  #112
98zexima's Avatar
I was curious if someone could email me some info on this swap. I have a 98 auto and my 3.0 (and cv's) were thoroughly destroyed by nitrous.
Thanks to anyone willing to help.
Old 12-05-2006 | 03:12 PM
  #113
MDeezy's Avatar
check the stickie at the top of the page. it has a feast of information to get the ball rolling on the swap.
Old 12-06-2006 | 07:24 AM
  #114
VQ20's Avatar
Would really luv to know how he did that myself since i am doing a full 3.5 swap.
Old 12-06-2006 | 03:27 PM
  #115
GodFather's Avatar
Made in Taiwan
Here's where the motor end up: Under my hood...
http://forums.maxima.org/showthread.php?t=487198
Basically the swap is perfect, discounting the troubleshooting problems. No Cel's, no adaptability issues, every accessory from my 4th gen setup fits directly onto this built motor. Good luck.
-Peter-
Old 12-06-2006 | 03:54 PM
  #116
LA02MAX's Avatar
The z also has a different ECU (iirc the same as the 6th gen max though), exhaust, IM, and the revup motor has different cams. It's not a matter of gearing and correct me if I'm wrong, but I would think that the drivetrain loss on the Z's 6-speed would be greater than ours since it's RWD, right?
as many people (including SR20 himself) have pointed out, the IM is just a small piece of the puzzle that allowed him to make the power he does. He's done so many more small things that most people have not accomplished yet. The IM is a piece of cake to modify, so if anyone really wanted to do it, they wouldn't need a write-up...just my .02
Old 12-06-2006 | 06:24 PM
  #117
GoalieKeg's Avatar
Prove please.
Old 12-06-2006 | 07:00 PM
  #118
nismology's Avatar
Originally Posted by GoalieKeg
Prove please.
Notice the post date?
Old 12-06-2006 | 08:05 PM
  #119
Nismo3112's Avatar
Custom User Title
Holy old post batman.
Old 12-06-2006 | 08:07 PM
  #120
scrhale's Avatar
I thought we came to the conclusion that it is only better when exhaust VTCs are used. Otherwise else just stick to the stock FWD Maxima manifold.
That is just my reguritation memory.
Quick Reply: VQ35 swap pictures
