Sponsored by:
Sponsored by: CARiD
Tuning, A/F Ratios, Etc What's the deal??
Old Jun 19, 2005 | 08:19 PM
  #41
SR20DEN's Avatar
VQ Wizard
Originally Posted by Pimpmobile
nissan....
Correct.
Now who wants to take a stab at why you would want to use Nissan software, ingeneral, as opposed to TS or JWT software? This one has been answered already. I just want to make sure everyone is following along.
Old Jun 19, 2005 | 08:35 PM
  #42
JeffesonM's Avatar
living out of a maxima...
Originally Posted by SR20DEN
Correct.
...because they made the engine?
Old Jun 20, 2005 | 10:48 AM
  #43
Pimpmobile's Avatar
because factory settings are optimal for the VQ?.....
Old Jun 20, 2005 | 02:52 PM
  #44
JClaw's Avatar
Going with pimp on this one.
Old Jun 20, 2005 | 03:08 PM
  #45
nismology's Avatar
There are advantages to aftermarket tuning so i dunno where this is going...
Old Jun 20, 2005 | 03:15 PM
  #46
RA030726's Avatar
I'm nutty for Nissans
stock ecu, maybe with a raised rev limit. then dyno (unless you have a wideband setup) to check the air fuel. then use a air fuel controller if need be. aftermarket ecu's are tuned to one car, then mass produced, thus not releasing the full potential of your car with your mods. why spend money on something that wont live it its fullest.
Old Jun 20, 2005 | 03:27 PM
  #47
nismology's Avatar
A/F tuning isn't all that counts. Ignition timing advance has its place as well.
Old Jun 20, 2005 | 03:32 PM
  #48
JClaw's Avatar
Ignition Timing Advance is THE reason to get tuning done on 4th gens with VQ35's.
Old Jun 20, 2005 | 05:21 PM
  #49
NmexMAX's Avatar
dot dot dot ...
Old Jun 20, 2005 | 06:52 PM
  #50
JClaw's Avatar
The OBDI conversion is waiting on future paychecks, there's always something else to burn cash on. I need to stop
Old Jun 20, 2005 | 07:02 PM
  #51
SR20DEN's Avatar
VQ Wizard
This is true. The stock software that was written for the VQ35 is the best "one size fits all" scenario. If you don't have the luxury of having custom software written specifically for you car WITH your car, you're most likely wasting your money. The rest should be done with the tools you have in YOUR posession. And in most cases this is a piggyback fuel computer.
So we've established which software is, and why it is, the all around best.
We also know that we still have to send off the ECU to get the rev limiter raised.
And with the paramters that we're dealing with here we also know that it isn't feasible to swap out the entire wiring harness to use a 2k2 ECU. We're going to use a ECU which is native to the vehicle, most likely a '96.
Anyone want to fill in the blanks here?
Keep in mind, software and hardware (ECU) are NOT the same thing.
Old Jun 20, 2005 | 10:15 PM
  #52
nismology's Avatar
4th gen ECU w/ raised rev-limiter + SMT-7 > *
Old Jun 21, 2005 | 03:57 AM
  #53
JClaw's Avatar
Originally Posted by 98SEBlackMax
Thought it was supposed to only cost you $500 for the 300ZX ECU setup?
It will cost me 500$cnd (about 400US for you guys) so it's cheaper than JWT. The 700$ was a girlfriend-related spending spree (partly my fault and I take the blame for it).
Tuning: 400$cnd (300-320$US)
OBDII->OBDI harness adaptor: 150$cnd (115-120$US)
Both together: 500$cnd (400$US)
We're probably going to use the cam sensor holes (one on each cam) that the VQ35 uses. Both of those sensors are in my car and useless for now (just to seal the holes) but they will probably be replaced by the sensors compatible with the 300zx ecu. He's going to take one out of his RB26 and see if the size of the hole is right, since it is directly in front of the cam. This COULD mean that future VQ35 swapers could do it without going through the whole timing chain ordeal or going through all the 2k2 wiring BS.
Old Jun 21, 2005 | 05:59 AM
  #54
SR20DEN's Avatar
VQ Wizard
You essentually repeated exactly what I said. You did not fill in the blanks.
Old Jun 21, 2005 | 07:11 AM
  #55
Kevlo911's Avatar
Kevlo for President
Funny how everyone just assumes we will figure out the cam signal and get the SMT7 to work.
Old Jun 21, 2005 | 07:22 AM
  #56
SR20DEN's Avatar
VQ Wizard
Who said it hasn't been figured out?
Old Jun 21, 2005 | 07:25 AM
  #57
Kevlo911's Avatar
Kevlo for President
Who says Perfrect Power has it to update the firmware?
Old Jun 21, 2005 | 07:32 AM
  #58
SR20DEN's Avatar
VQ Wizard
Who said it had anything to do specifically with perfect power?
You're talking about something else anways so I withdraw on this one.
Old Jun 21, 2005 | 07:39 AM
  #59
Kevlo911's Avatar
Kevlo for President
Ahh!
So you know the cam signal and how it relates to the crank signal??
Old Jun 21, 2005 | 07:51 AM
  #60
SR20DEN's Avatar
VQ Wizard
Originally Posted by Kevlo911
Ahh!
Not entirely. But as I was saying, that is a different subjuect and not relavent to the current conversation.
Old Jun 21, 2005 | 09:20 AM
  #61
Pimpmobile's Avatar
A VQ30DE ECU with a VQ35DE flash?
Im on a roll so far
Old Jun 21, 2005 | 10:18 AM
  #62
I30tMikeD's Avatar
Im on a roll so far
You don't flash a VQ30 ECU, you need a daughter board and a burned chip.
Old Jun 21, 2005 | 12:06 PM
  #63
Pimpmobile's Avatar
VQ30DE ECU with a VQ35DE somthing or other?
no more socratic method
Old Jun 21, 2005 | 02:14 PM
  #64
SR20DEN's Avatar
VQ Wizard
Im on a roll so far
Bingo .
Old Jun 21, 2005 | 02:52 PM
  #65
JClaw's Avatar
How would we be able to advance the timing to what 2k2's with timing advance run? The stock Ecu limits that after a certain point.
Old Jun 21, 2005 | 03:36 PM
  #66
DandyMax's Avatar
3.5 in the works
Im on a roll so far
Bingo .
And just who is able to do this?
Old Jun 21, 2005 | 04:22 PM
  #67
JeffesonM's Avatar
can TS put the 2k2 maps onto a 96 ECU?
Old Jun 21, 2005 | 06:30 PM
  #68
SR20DEN's Avatar
VQ Wizard
A map is a map. It's nothing but a set of hexidecimal characters.
I didn't say put Windows XP on a Macintosh. But I am saying make the Mac OS look like Windows XP.
Old Jun 21, 2005 | 06:45 PM
  #69
nismology's Avatar
All they would have to do is copy and paste those a/f and timing maps onto a daughterboard!!! Brilliant!!! Damn...good thinking SR20. This is sooo much easier on them than making a modified map. I'm sure they could have a 3.5-spec ECU in production in no time.
Old Jun 21, 2005 | 06:53 PM
  #70
SR20DEN's Avatar
VQ Wizard
It isn't a new idea. I just never got the opportunity to use it so I am essentually giving it away.
There is more to the story that I can't give away becuase the rest of it is co-owned by someone else.
Old Jun 21, 2005 | 08:22 PM
  #71
j_bryan's Avatar
clever....reminiscent of daniel b martin.
Old Jun 21, 2005 | 08:33 PM
  #72
SR20DEN's Avatar
VQ Wizard
Just don't forget that it needs to be the L-Spec map.
Anyone experiementing with intake manifolds could get away with a 350Z map. Which I almost did on my car when I got my L-Spec. I just didn't want to spend the extra $200 at the time. But later this year I'll probably go through with it. The cam timing curves on the FWD cars are not what they should be. I even got Tadashi to verify this when I spoke to him last Janurary.
Old Jun 21, 2005 | 08:38 PM
  #73
krismax's Avatar
Father of the 00 VI
This sounds very good but i have no VTC what about me would this still hold true for me and the others with 3.5's with 3.0 ecu's with no VTC????
Old Jun 21, 2005 | 08:42 PM
  #74
SR20DEN's Avatar
VQ Wizard
I don't know if the VTC is software co-dependant of the tune of the car. But I am certain it is co-dependant of the VE (volumetric efficiency). Therefore the 2k2 3D map will have plenty of answers for all available cam settings at each RPM. And any software dependancies should be irrelivant. Especially since the '96 ECU won't even have settings for the VTC.
But everyone take note that I never said you had to toss the VTC. It will however be ALOT of extra work to keep it though.
Old Jun 22, 2005 | 08:00 AM
  #75
Pimpmobile's Avatar
SR you are a true asset to the maxima comunity!
Would a company such as TS be able to transfer the fuel maps and timing maps from a VQ35 to a VQ30 ECU? Would it provide better gains with the 350z or g35 maps than the FWD maps for a non VTC VQ35?
Also what would be the starting point to get VTC on a VQ30DE ECU driven VQ35, multiple RPM switches, somthing similar??
Old Jun 22, 2005 | 09:45 AM
  #76
98SEBlackMax's Avatar
Maxima.org Insomniac
Without Variable Timing Control volume metric efficency is reduced on the low~mid range. If Techno Square programs a stock 2k2 timing and fuel map onto a 4th gen ECU as proposed the result would be less than perfect timing on the low ~ mid range. This occurs because Nissan programs ECUs to pull back timing when the VE is high. I also observed this when I was tinkering with the SMT-6 and timing advance. Adding timing where VE is highest can result in easier detonation and doesn't seem to gain that much power. However with the SMT-6/7 piggyback it can add timing down low to make a little more power for the 2k2 ECU tune and missing VTCs.
Old Jun 22, 2005 | 09:50 AM
  #77
No.
I have a plan in the works but don't want to say, not because I like to keep secrets but I would rather have it working and post dyno results.
End users will be able to tweak and program the VTC functions and this should also allow us to use the NISMO VTC assemblies for even more advance. This should in theory allow us to run more radical aftermarket VQ35 cams and still be streetable.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
