Sponsored by:
Sponsored by: CARiD
00vi help!
Old Jun 20, 2005 | 06:44 PM
  #41
eckohb's Avatar
I thought so too but I rechecked them from the stock ones and they run to the same places or as close as possible with the different fitting locations. I personally think that it's cause we didn't use new gaskets and there is a massive air leak somewhere.
Only rewiring we did was of the two ground connections and we ran them to the timing cover.
Old Jun 20, 2005 | 06:50 PM
  #42
DandyMax's Avatar
3.5 in the works
Unless the old gaskets are really in bad shape they're probably fine. I re-used my IACV and TB gaskets with no problems.
Old Jun 20, 2005 | 06:52 PM
  #43
Kevlo911's Avatar
Kevlo for President
00vi has rubber gaskets that are supposed to be re-used, the lower IM gaskets should be changed, I dout not changing the gaskets can cause that big of a leak.
Old Jun 20, 2005 | 07:00 PM
  #44
jmeister's Avatar
Originally Posted by eckohb
Ok, car starts, runs rough, and turns off after 10 seconds. We're getting
0205 IAC AAC Valve
1008 purge volume control valve
1302 map/baro solenoid valve
Those were the codes I got when I had my vacuum lines routed wrong on the map/baro solenoid. Everything checks out against the FSM vacuum line diagrams?
Old Jun 20, 2005 | 07:05 PM
  #45
DandyMax's Avatar
3.5 in the works
I agree. Having a leaky gasket would be the same as unplugging a vac line. It won't shut the car off... your idle just goes up a bit, you get a hissing noise etc.
I'm inclined to think there's something of a larger magnitude incorrect with your setup.
And you already checked that your TPS is adjusted correctly, right?
Old Jun 20, 2005 | 07:06 PM
  #46
Kevlo911's Avatar
Kevlo for President
Some is not plugged in IMO...
Old Jun 20, 2005 | 07:11 PM
  #47
DandyMax's Avatar
3.5 in the works
I know you say you've done it but double, triple, heck - quadruple check all those vacuum and air routings... it's easy to miss something even when you think you've gotten it all right...
Old Jun 20, 2005 | 07:15 PM
  #48
eckohb's Avatar
Right now. The tps is at 507 at closed and 3720 a WOT. We have no open fittings and I guess we'll have to take everything off and try again.
Old Jun 20, 2005 | 07:22 PM
  #49
jmeister's Avatar
Does it stay running under throttle?
Old Jun 20, 2005 | 07:27 PM
  #50
eckohb's Avatar
not at all.
Old Jun 20, 2005 | 07:33 PM
  #51
THT's Avatar
THT
Throbbing member
Out of curiosity...is the brake booster hose connected? When Nismo and I did my install, we forgot to connect it and the following happened: the car turned over, stayed running for about three seconds and during those three seconds, the idle was all over the place as the car struggled to operate...then it died.
Old Jun 20, 2005 | 07:39 PM
  #52
eckohb's Avatar
It's connected to the nipple all the way on the passanger side of the manifold.
Old Jun 20, 2005 | 07:42 PM
  #53
DandyMax's Avatar
3.5 in the works
This is probably a stupid question... what size hose did you run from the back of the IACV adapter plate to the manifold?
Old Jun 20, 2005 | 07:45 PM
  #54
Kevlo911's Avatar
Kevlo for President
Is IACV plugged in correctly? Mine was not and it ran bad and turned off
Old Jun 20, 2005 | 08:38 PM
  #55
eckohb's Avatar
I think we have 5/8 going from the TB plates to the IACV adapter, and then from the stock IACV fitting to the resonator is the same size, it's snug.
Old Jun 20, 2005 | 10:50 PM
  #56
Nismo3112's Avatar
Custom User Title
Now that I look at my friend's TB, the vac hose on the bottom of the TB goes to something else... This is where the vac source connects to:
Also to get a better understanding, can you list off where these lines are going to?
Old Jun 21, 2005 | 05:03 AM
  #57
SDot82's Avatar
0205 IAC AAC Valve
I had the 1302 map/baro code throw up on me after I did the swap and it made it hard for me to start the car. Sometimes I was start it and it would die right out. Found out that I had some of my vacuum hoses mixed up and after I fixed it there were no more problems.
Old Jun 21, 2005 | 02:46 PM
  #58
eckohb's Avatar
Car runs, there is a faint whisling sound but I don't see/feel any leaks except the EGR tube which isn't blocked off. Now, besides the green LED, how do I know the butterflies are opening? I don't hear a change is sound or anything. We have the white wire, normally open, running to the actuator. We tried both the wires coming from the connector and still can't tell a difference.
Old Jun 21, 2005 | 03:10 PM
  #59
jmeister's Avatar
pop the hood and watch the VI solenoid open when you hit the RPM setting
Old Jun 21, 2005 | 03:12 PM
  #60
eckohb's Avatar
We have no hood on yet. I figured that the metal piece at the bottom would move to open it, the one you can move manually to open them, but it's not moving at all.
Old Jun 21, 2005 | 03:28 PM
  #61
s0ber's Avatar
What is the vacuum source you have for it? Try hooking up direct vacuum and see if it opens up and stays open, it should stay open just to make sure its functional.
Old Jun 21, 2005 | 03:34 PM
  #62
eckohb's Avatar
We have no vacuum for it. The brass nipple is left open and the black, plastic one is capped. That's what we were told to do.
Old Jun 21, 2005 | 03:35 PM
  #63
Kevlo911's Avatar
Kevlo for President
It is supposed to be connected to the midpipe.
Old Jun 21, 2005 | 03:37 PM
  #64
s0ber's Avatar
Yes, it wont open without it..
Old Jun 21, 2005 | 03:39 PM
  #65
eckohb's Avatar
are both wires on the connector to the VI supposed to be used? one to the rpm switch for sure, and is the other one supposed to be grounded?
Old Jun 21, 2005 | 03:40 PM
  #66
eckohb's Avatar
which one is supposed to be connected to the mid pipe? we have one that was capped, and the other small nipple that isnt supposed to be used. the one that was capped im assuming somehow goes to the midpipe?
Old Jun 21, 2005 | 03:41 PM
  #67
jmeister's Avatar
both solenoid wires are used... the yellow is connected to the 12v power and the blue/green is the RPM switch activated ground.
http://forums.maxima.org/showthread.php?t=391394 post #3, not sure about the RPM differences though
Old Jun 21, 2005 | 03:43 PM
  #68
Kevlo911's Avatar
Kevlo for President
The inner most one is suppose to be connected to the midpipe.
As for the wireing, many ways to do it. Test and find out which one opens it.
Old Jun 21, 2005 | 03:47 PM
  #69
Nismo3112's Avatar
Custom User Title
Do not cap it off, or else it will have a hard time opening, also I did not have anything connected to the solenoid nipple.
Old Jun 21, 2005 | 03:53 PM
  #70
DandyMax's Avatar
3.5 in the works
Ok. The nipple on the solenoid can be left open or connected to your intake, it doesn't matter unless you are expecting a lot of dirt to get in there in which case connect it so it's only seeing filtered air. All the nipple does is allow air at atmospheric pressure to go through the solenoid to the power valve actuator (not into the engine itself). When the solenoid receives a ground, it cuts off the air passage and allows vacuum from the internal tank to go through to the actuator, thus rotating the power valve.
Now, as for the wiring. You need a positive side and a negative (grounded) side running to the solenoid. Are you using a Harlan? I'm not familiar with the color codes as I have the Summit but basically the switch will have a lead that supplies ground upon reaching the set rpm... connect this to the ground side of the solenoid. The other side of the solenoid should be wired into a positive 12v source (from the battery) but put it on a switched line like after your ignition switch so it won't constantly be draining.
So what was your problem that caused the car to keep dying then? Sounds like you found it if it's staying on now...
Old Jun 21, 2005 | 04:19 PM
  #71
eckohb's Avatar
red to cig. lighter positive
black to cig. lighter negative
white to white/green tach wire
gray to yellow on the connector to the VI
when yellow from the Summit was connected to the VI the green light was always on. Are we supposed to be using the black wire from the summit switch to the connector on the VI?
Old Jun 21, 2005 | 04:21 PM
  #72
eckohb's Avatar
oh yeah, our problem was that we found a dead rat inside one of the cylinders
Nismo3112: ANSWER YOUR PHONE!!!
Old Jun 21, 2005 | 04:25 PM
  #73
THT's Avatar
THT
Throbbing member
A dead rat? I want pics.
Old Jun 21, 2005 | 04:28 PM
  #74
eckohb's Avatar
we fed the rat to a cat in the alley behind Daves house. but anyways, why wouldn't you guys answer your phones! and is the black wire from the rpm switch supposed to be ran to the VI connector? I was told only one wire was necessary to run from the rpm switch by none other than...NISMO3112
Old Jun 21, 2005 | 04:44 PM
  #75
THT's Avatar
THT
Throbbing member
I was at work but saw you guys called five times lol
You'll use all the RPM switch wires except for one (the normally open wire).
Old Jun 21, 2005 | 04:45 PM
  #76
eckohb's Avatar
yes, i realize that. but does it matter where the switch is grounded? we have it grounded to the cig lighter, and the VI ground is on the chassis of the car.
Old Jun 21, 2005 | 04:47 PM
  #77
eckohb's Avatar
wait, so the yellow one is the one that we do not use? And we are supposed to be using the gray one?
Old Jun 21, 2005 | 04:50 PM
  #78
THT's Avatar
THT
Throbbing member
Where you ground it shouldn't matter.
Old Jun 21, 2005 | 04:52 PM
  #79
eckohb's Avatar
So then why is not opening? THT, you dont have a vacuum source hooked up to it do you?
Old Jun 21, 2005 | 05:01 PM
  #80
DandyMax's Avatar
3.5 in the works
So you won't tell us what the rat.. er problem was?
Here's how I did the Summit wiring as follows:
Black - connect to engine or chassis ground
Red - connect to switched +12v source (such as ignition switch)
White - connect to tach
Yellow - connect to negative (ground) side of VIAS solenoid
Grey - not used
Using this setup do not hookup a vacuum line to the VIAS nipple. You still need to run a positive line to the solenoid to complete the circuit.
