Sponsored by:
Sponsored by: CARiD
mevi or 00vi?
Old Aug 3, 2005 | 07:49 AM
  #41
sean05's Avatar
Originally Posted by NmexMAX
Where did you get that pic from, and what are you interested in? I have MEVI, and I don;t have anything switched like that under my hood.
The lower pic looks like a solenoid.
I'm using the Dawes devices solenoid, and the NAPA vac can and Summit RPM switch ... I love doing 90+mph in second (auto)
VQpower.com http://www.vqpower.com/v2/modules.ph...howpage&pid=40 page 3 and 4
Old Aug 3, 2005 | 08:01 AM
  #42
NmexMAX's Avatar
dot dot dot ...
The site explains it all ...
Old Aug 3, 2005 | 08:13 AM
  #43
sean05's Avatar
me no understnad... it says its relay that activates the MAP switch. What is a MAP switch?
Old Aug 3, 2005 | 10:07 AM
  #44
NmexMAX's Avatar
dot dot dot ...
Manifold Absolute Pressure swtich, read the MEVI FAQ:s and get aquianted with the terminology, EXACTLY how it works, and the .orgers different ways of setting it up .. i.e using a relay or not ...
PM me for some details.
Old Aug 3, 2005 | 10:27 AM
  #45
eckohb's Avatar
Use the 00VI, and call it a day. It's very easy, grinding the coil mounts down with a file takes 5 minutes. Look at the area underneath the curve between the two manifolds, and think about the 400-600 you will spend on an ecu to get the rev limiter and get your low-mid power back. Dont be afraid to try something because it involves a little work
Old Aug 3, 2005 | 10:31 AM
  #46
sean05's Avatar
im not afraid to try it becuase of the work. Im afraid of fukking something up and the down time.
Old Aug 3, 2005 | 10:36 AM
  #47
eckohb's Avatar
Downtime...one weekend AT THE MOST. That's if you take breaks, naps, get drunk, high, play a game or two of Madden 06, and make time for meals. Taking the USIM off and putting the VI on is easy. The hardest part of the install is figuring out the vacuum lines. And then if you search, you can look at other peoples' threads about installing the VI coughMEcough. You could easily have this done in an afternoon. Ask for help from some Florida ORG members. Kevlo911, I know there is another. Dont sell yourself short
Old Aug 3, 2005 | 10:42 AM
  #48
sean05's Avatar
is the gains of the 00Vi that much more then the mevi?
Old Aug 3, 2005 | 10:44 AM
  #49
eckohb's Avatar
http://forums.maxima.org/showthread.php?t=363625
i told you to look at this already, but since you apparently havent, scope it out. its not always about peak numbers when it comes to a dyno
Old Aug 3, 2005 | 10:45 AM
  #50
sean05's Avatar
yes ive already read that. But can u even feel that on the butt dyno? i didnt ever feel much gains for the y pipe when i installed that
http://forums.maxima.org/showthread....=1#post4210442 so that is everything i need?
Old Aug 3, 2005 | 11:03 AM
  #51
Stephen Max's Avatar
I could immediately feel the increase in torque after switching from MEVI to 00VI. If you go from USIM to 00VI you might not be able to feel anything except at higher rpm.
Old Aug 3, 2005 | 11:13 AM
  #52
mike96's Avatar
what are the gains from the MEVI and the 00vi in whp and in hp
for a 4thgen
Old Aug 3, 2005 | 11:27 AM
  #53
eckohb's Avatar
peak is probably 10-15. But making over 40 whp at 6.5k rpm with the VI vs the USIM is a huge difference.
Old Aug 3, 2005 | 12:22 PM
  #54
japmaxSE's Avatar
Go Get a Life!
*HINT*
I just found a way for the MEVI owners to get more power through out the whole power range over the 00VI
With a liltle tinkering there is no way you can improve the design of the 00VI Well me and my buddies couldn't, because, IT"S PLASTIC!
Anywho I don't have any real Dyno #'s to compare to but my butt dyno tells me it Kicks both 00VI and the crappy 02+VI
I'm going to be like SR20DEN and call this my SECERET SAUCE MANIFOLD HMM HMM OH HA HA HA . Only because I can sorry.......
Just be on the look out for the record.....
Old Aug 3, 2005 | 12:33 PM
  #55
NmexMAX's Avatar
dot dot dot ...
Actually, you can ..
No dyno no care
The record, or the dyno?
SSIM for 4th gens .. I think SR actually had some thoughts on this awhile back ...
Old Aug 3, 2005 | 12:38 PM
  #56
mike96's Avatar
holy moly 40 whp at 6.5k sweet
Old Aug 3, 2005 | 12:40 PM
  #57
NmexMAX's Avatar
dot dot dot ...
That used to be the average for the MEVI ... (10 people or so) :thumbup:
Old Aug 3, 2005 | 12:56 PM
  #58
deezo's Avatar
*HINT*
Let's see it mang!!!!!!!!!!!!!!!!!!!!!!
Old Aug 3, 2005 | 08:51 PM
  #59
mike96's Avatar
so with the 00vi it should pull more whp?
Old Aug 3, 2005 | 09:01 PM
  #60
sean05's Avatar
more low end torque. lol i got yelled at that question so ill answer it.
http://forums.maxima.org/showthread.php?t=363625 check out that thread and scan over the dyno
Old Aug 3, 2005 | 09:03 PM
  #61
sean05's Avatar
defiently! so i can do this b4 i put mine on!
Old Aug 3, 2005 | 09:28 PM
  #62
JClaw's Avatar
Yeah yeah yeah get that thing on the track
Old Aug 3, 2005 | 09:33 PM
  #63
sean05's Avatar
so waht did you do to the mevi?
Old Aug 3, 2005 | 09:45 PM
  #64
japmaxSE's Avatar
Go Get a Life!
Not just yet, not untill I get actual Dyno numbers and compare.
Then I got to make sure it holds up. Drive it around for awhile and see if there's any more room for improvement.
My suggestion to you is get the 00VI it's the best of the bunch unmoded. A little more work but like everyone here says it's not all that bad a few hours and your done the vaccum lines is what your going to need help on and maybe TB and stuff everything else is cake. If my SSIM goes through it won't be cheap $$$$$$$
Old Aug 3, 2005 | 09:53 PM
  #65
s0ber's Avatar
when we did the 00VI on my car the vacuum lines wasnt really a concern, more figuring out the pcv valve problem, we just placed the vacuums the way they were back on the regular manifold...
But this doesnt hold true for 96+ maximas that have that EVAP thing all over the place there... mine was alot simpler I believe.
Old Aug 4, 2005 | 04:44 AM
  #66
deezo's Avatar
Thanks for heating up the "Battle of the Manifolds".
Old Aug 4, 2005 | 08:58 AM
  #67
sean05's Avatar
lol i want to know what he did!
Old Aug 5, 2005 | 11:17 AM
  #68
blazingchimp's Avatar
Originally Posted by MaxesRule
Gotcha covered on this one. Use the 00/01 rear valve cover. lol See, problem solved! And do u know what 10wtq would do for acceleration?
is this true? it makes sense that you wont have to grind the coil bosses anymore but will this bolt on to the engine with no fabrication and will the coil packs still bolt on? seems like a good way to go if it works and ive read alot of 00vi threads and never encountered anyone taking this path.
Old Aug 5, 2005 | 11:29 AM
  #69
This works, but you will also have to use the 5th gen rear ignition coils. There are a few people who have this setup (myself included as of last weekend).
Old Aug 5, 2005 | 12:06 PM
  #70
how hard is it to swap to 5th gen ignition coils
Old Aug 5, 2005 | 12:10 PM
  #71
No difficulty at all.
Old Aug 5, 2005 | 02:09 PM
  #72
Kevlo911's Avatar
Kevlo for President
All you need is 5th gen vavle cover
Old Aug 6, 2005 | 09:05 AM
  #73
scrhale's Avatar
Forgive my noobism, but is the valve cover just the stupid piece of metal over the engine????
Old Aug 7, 2005 | 11:39 AM
  #74
eckohb's Avatar
Front valve cover is the metal under your plastic Nissan v63000 cover. The rear valve cover is under the IM and you slide your coil packs through there
Old Aug 7, 2005 | 04:32 PM
  #75
japmaxSE's Avatar
Go Get a Life!
You must really love your max...
Old Aug 7, 2005 | 08:20 PM
  #76
eckohb's Avatar
Or are you talking about the Intake Manifold? Im sure those stupid pieces of money serve some purpose, such as the valve covers covering up our cams and spark plugs
Old Aug 8, 2005 | 09:22 PM
  #77
scrhale's Avatar
Ah got it ... yes I do not like my max much. It is auto and FWD. No I wasn't talking about the IM.
Old Aug 9, 2005 | 11:02 AM
  #78
s0ber's Avatar
so do a 5spd swap...
or get a RWD car
Old Aug 9, 2005 | 01:32 PM
  #79
scrhale's Avatar
But a 5 spd swap costs 2K. That's a lot when the car is worth 4.5K
Old Aug 9, 2005 | 01:53 PM
  #80
japmaxSE's Avatar
Go Get a Life!
Damn I spent only 900 for my swap...
