Sponsored by:
Sponsored by: CARiD
So, what is the final answer on 4th gen timing?
Old Jul 26, 2005 | 04:00 PM
plurco's Avatar
I have been searching and reading but I am getting conflicting reports on whether or not you can adjust 4th gen timing without upgrading the ECU or running a piggyback. One report I got said you could do it with a consult 2 as long as your car was OBDII, and the other report said you could, but it would revert back to stock when you shut the car off. Which is the truth? I would like to get about 3 degrees adv. to run with racing fuel.
Old Jul 26, 2005 | 04:39 PM
THT's Avatar
THT
Throbbing member
Consult 2 will not work. The ECU "forgets" the setting when the car is turned off. Additionally, 5th gens can only get an extra two degree advance if memory serves me.
Old Jul 27, 2005 | 08:02 AM
95BLKMAX's Avatar
IIRC, 4th gen ECUs are ROM (read-only Memory), so you could advance the timing with a consult2, but like THT said, the ECU would go back to stock timing the moment its turned off. You can advance the timing on the 5th gen ECU and it would maintain that timing because that ECU is flashable.
Hope that helps
Old Jul 27, 2005 | 09:28 AM
DandyMax's Avatar
3.5 in the works
^^^ That is all correct. You can't advance timing on a 4th gen permanently without going piggyback or aftermarket ECU. I have personally confirmed this on my car using the Consult. It will only let you adjust timing for diagnostic purposes. Once the car is turned off, the changes are gone.
Finkle
Sep 27, 2015 09:53 PM
maxinout93
Aug 16, 2015 07:25 PM
WeetoddA32
Aug 16, 2015 12:45 PM
MaxStock
Aug 12, 2015 08:33 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
