Sponsored by:
Sponsored by: CARiD
cheapest 00VI
Old Aug 9, 2005 | 07:56 PM
WielkiWaac's Avatar
MaximaDriver
cheapest 00VI
do you guys know what is a cheapest way to do 00VI mod on 4th gen??
Old Aug 9, 2005 | 08:19 PM
SR20DEN's Avatar
VQ Wizard
Don't charge yourself.
Old Aug 9, 2005 | 08:20 PM
s0ber's Avatar
Buy the upper and drill the lower A32 IM..
You're still going to have to 1) get the adapter plate sets and use 4th gen TB, you'll still need a plate for the IACV, or 2) use 5th gen TB, remove EGR, and wire up the A33 IACV...
ORRRRRRRRRRRR
3) use the 5th gen TB, keep EGR, and use a plate for teh IACV..
Theres 91823912839123821 combinations, your choice.
Old Aug 10, 2005 | 05:10 AM
scrhale's Avatar
I can't do option 2 :'( ... I would fail emissions without an EGR over NOx. Drilling the lower seems soooo scary. I wonder if it is cheaper to use 5th gen TB over buying an adaptor plate to keep your 4th gen TB. I know 5th gen TB is slightly larger in diameter.
Old Aug 10, 2005 | 05:19 AM
s0ber's Avatar
its the same thing, im using a 5th gen TB w/out IACV...
Old Aug 10, 2005 | 11:43 AM
WielkiWaac's Avatar
MaximaDriver
sorry. i was thinking about easiest way to do 00VI
Old Aug 10, 2005 | 12:11 PM
s0ber's Avatar
there is no easy way
the EASIEST its gonna get is.....
-A33 Lower/Upper
-A33 Valve Cover
-A33 Rear Coilpacks
-A33 EGR Guide Tube
-A33 Throttle Body
-A33 Fuel Rail/Injectors
-A32 Idle Air Control V
-Adapter Plate for IACV from someone here.
Using the whole shibang you wont have to grind down the coil towers, or worry about PCV placement.
Old Aug 10, 2005 | 12:32 PM
scrhale's Avatar
Yes ... but everyone has to remember that when you do s0ber's "easy" way, you have to splice in the injectors into the A33 Lower.
Old Aug 10, 2005 | 12:46 PM
Stephen Max's Avatar
Here's the easiest way that retains egr and pcv functionality, and allows you to keep your injectors and fuel rail:
1. 00vi
2. A33 rear valve cover and ignition coils
3. A33 egr guide tube
4. A32 IACV
5. A32 TB
6. TB adapter plate
7. predrilled A32 lower intake manifold (PM me!)
8. IACV remote mounting plate
Old Aug 10, 2005 | 01:31 PM
s0ber's Avatar
It's either splicing a couple little wires, or drilling your lower A32 IM to suit your needs, or you could just get it pre-drilled, which stephen max is correct, would be the easiest setup.
Old Aug 10, 2005 | 02:17 PM
Nismo3112's Avatar
Custom User Title
Buy everything you need including the VI off of me for $80..
Wait... I already sold it to THT
Old Aug 10, 2005 | 04:12 PM
scrhale's Avatar
1. 00vi
4. A32 IACV
5. A32 TB
6. TB adapter plate
It is just as easy to use A33 TB which bolts directly to A33 Upper.
How expensive is the rear valve cover and ignition coils?
Old Aug 10, 2005 | 06:39 PM
Jar's Avatar
Jar
you just sold off what you had already for that or can you hook it up?
Old Aug 10, 2005 | 08:02 PM
eckohb's Avatar
He sold it to THT...like he said...
Old Aug 12, 2005 | 12:05 PM
PTownMax's Avatar
I still miss the max
where's a good place to get 00 valve cover and coil packs?
i can't find a junk yard around here with any 00 and up maxes
Old Aug 19, 2005 | 12:20 PM
Weimar Ben's Avatar
Helicopters! Money!!!
My state only scans for codes for the emissions testing. Would removing the EGR valve with this swap throw a code? If you remove the EGR, doesn't that give a little more power and gas mileage?
Old Aug 19, 2005 | 12:22 PM
Nismo3112's Avatar
Custom User Title
Some have gotten codes, but I have not. And no removeing the EGR will not give you more power, or more gas mileage.
Old Aug 19, 2005 | 12:34 PM
I didn't get any codes, but some other people I know have.
Old Aug 19, 2005 | 03:04 PM
PTownMax's Avatar
anyone know an answer to post #15?
Old Aug 19, 2005 | 03:10 PM
Weimar Ben's Avatar
car-part.com
I would prolly do a search on valve covers, if that doesn't bear fruit, do a search for an engine, scroll through the list and find some that are blown and call them.
For the coils, I would order 3 new ones.
Old Aug 20, 2005 | 09:21 AM
Nealoc187's Avatar
SLOW
You'd pay like $180 for coils you can get for like $30 car-part.com? Must be nice to be rich!
Old Aug 20, 2005 | 09:30 AM
Kevlo911's Avatar
Kevlo for President
I have three rear 00 coil packs, they work...
Old Aug 20, 2005 | 11:28 AM
Weimar Ben's Avatar
If you think paying $30 for used and possibly defective coil is better than paying $50shipped for a brand new updated one, be my guest. Go look at the 5th gen forums, there's a ton of people that had to replace all 6 coils and theres TSB's about it.
Paying $60 more now for the new coils will be cheaper in the long run if you receive defective or dying coils from a junkyard.
Maxboy23
55
May 1, 2025 06:09 PM
t6378tp
Sep 29, 2018 04:27 PM
lrb6805
Sep 30, 2015 08:12 AM
dvcamp
Sep 18, 2015 10:17 AM
Maximeltman
Aug 31, 2015 01:01 PM
