Sponsored by:
Sponsored by: CARiD
does the VQ33 stroker work and how much does it cost?
Old Aug 17, 2005 | 03:28 PM
rmh3093's Avatar
Only gentoo powered Maxima!
alright I have been reading these posts about putting the crankshaft and rods from a vq35 into a vq30 to get a vq33 and comfused, i though I saw a thread with this done successfully and then there are a bunch of treads that says this dosent work, does it work and how much are the parts?
Old Aug 17, 2005 | 03:30 PM
Jeff92se's Avatar
I'm needing a caw
Any particular reason you want to go to more trouble to get less displacement vs just using a VQ35 long block?
Old Aug 17, 2005 | 04:21 PM
PTownMax's Avatar
I still miss the max
be different
Old Aug 17, 2005 | 04:27 PM
mad-max98's Avatar
^^^^ funny
Old Aug 17, 2005 | 04:30 PM
mad-max98's Avatar
maybe replacing the crank and rods is easier than dealing with wiring and trouble shooting for him
Old Aug 17, 2005 | 05:13 PM
Kevlo911's Avatar
Kevlo for President
Give me a year.
Old Aug 17, 2005 | 07:34 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
A YEAR~!!!!!!
I thought it was going to be sooner then that???
Originally Posted by Kevlo911
Give me a year.
Old Aug 17, 2005 | 07:54 PM
rmh3093's Avatar
well cause probably doing the stroker would be cheaper then a full VQ35 swap
Old Aug 17, 2005 | 07:56 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by IceY2K1
A YEAR~!!!!!!
Hehehe, it should be. I need to do my audio, projectors, and get everything setup for college. Then I will have free time to do it
Old Aug 17, 2005 | 09:21 PM
Jeff92se's Avatar
I'm needing a caw
It's probably close for someone that knows that they are doing. But if you have to hire someone to break down your VQ30 and bascily rebuild it with thew parts, that will probably blow a VQ35 long block swap out of the water. (note that I didn't say full VQ35 swap)
Old Aug 17, 2005 | 10:36 PM
rmh3093's Avatar
whats involved with the long block swap?
Old Aug 17, 2005 | 10:42 PM
JClaw's Avatar
WTF? Did you guys ever hear of using a full VQ35 with VQ30 timing chain and wiring?
Old Aug 17, 2005 | 10:44 PM
JClaw's Avatar
No way. With the full VQ35 swap all you need is a VQ35 (800$) + 130$ for JWT spacers and get the cams drilled.
The way you want to go, it would cost you the same thing, except you'd have to tear down both motors completely.
Old Aug 18, 2005 | 04:36 AM
Stephen Max's Avatar
Not necessarily.
I have a spare set of VQ35 crank, rods and pistons I would sell for $150 plus shipping.
Old Aug 18, 2005 | 05:41 AM
chris'smax's Avatar
I thought the whole vq33 thing had been put to bed due to piston not clearing the heads?
Old Aug 18, 2005 | 06:01 AM
The pistons do stick up an estimated .6 mm (.024"). Since the head gasket is about .036", there is clearance to start with, but at some rpm level there may be contact due to the rods lengthening under spin loading. No one knows for sure at this point.
This has all been thoroughly talked about in other threads.
http://forums.maxima.org/showthread....highlight=vq33
jerrod99_se-l
Aug 27, 2015 08:27 PM
raffivegas
Aug 23, 2015 09:54 PM
KristyKarina
Aug 23, 2015 09:53 AM
jchronis2552
Aug 13, 2015 07:48 AM
kenc15
Aug 5, 2015 08:29 AM
