Sponsored by:
Sponsored by: CARiD
Ignition timing/advance
Old Aug 25, 2005 | 08:22 PM
killerVQ30DE's Avatar
Whats the typical max advance that our A32's see.
I recall seeing in the FSM that advance is typically up to 25
I did a datalog when I got my consult scanner the other week
Questions ......
My highest reading was Ignition Timing 46 @ 5563rpm ... this sounds way high or am I looking at the right figure .. is Advance the same as timing?
Does Closed/TPS mean i'm not WOT ?
Old Aug 31, 2005 | 11:28 AM
00SEMAX19's Avatar
that sounds about right under acceleration. I checked mine with my snap on scanner and it was very similar.
Old Aug 31, 2005 | 11:42 AM
nismology's Avatar
Questions ......
That sounds a little high. Ignition timing advance depends on RPM and throttle position more than anything else. The highest timing advance occurs at high RPM with little to no load i.e. closed throttle. Next time you datalog try to capture the timing advance at WOT only because as you back off the throttle the advance will go up.
Old Aug 31, 2005 | 11:45 AM
nismology's Avatar
3.5's typically experience more timing advance than 3.0's so if your numbers are similar, his numbers are too high for sure.
Old Aug 31, 2005 | 02:53 PM
00SEMAX19's Avatar
Makes sense. I was with no load also and this was at high rev. If I remember right mid 40's was about the peek timing I saw.
Old Aug 31, 2005 | 03:41 PM
I have a factory MEVI.. I'm wondering if my JDM ecu has better timing settings.. I keep hearing about slow Autos.. but my auto hauls
Old Aug 31, 2005 | 04:02 PM
Jime's Avatar
My timing is 17-19 under WOT with a 3.5. Stays the same except a bit of fluxuation when shifting.
Old Aug 31, 2005 | 04:22 PM
nismology's Avatar
Yea that's why they're so high. Highest is at high RPM with no load.
Old Aug 31, 2005 | 09:34 PM
eng92's Avatar
Here is some A32 ecu WOT timing data for stock and TS ecus.
This is another thread with timing data from some JWT ecus added for comparison
http://forums.maxima.org/showpost.ph...&postcount=131
Old Aug 31, 2005 | 09:46 PM
krismax's Avatar
Father of the 00 VI
My TPS will not go lower on my car than 28% even at idle w2hat does this mean for me? doe sthis help or hurt power?
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
Gingerheadman
Oct 1, 2015 05:11 PM
msellas
Sep 23, 2015 09:16 PM
rnb754
Sep 14, 2015 11:39 PM
