Sponsored by:
Sponsored by: CARiD
help with evap hose on vi swap
Old Sep 15, 2005 | 07:15 AM
mad-max98's Avatar
i just finished the swap however i don't know how to run the evap hoses on the 00tb especially the one towards the front of the car does anybody have any diagrams or pics or ideas on how to run them thnx
Old Sep 15, 2005 | 07:54 AM
MAXimumHP's Avatar
You may not have them, but I used all the brackets and hoses from the 2000 to run the evap lines. I can post pics tonight if you want to see them.
Old Sep 15, 2005 | 09:57 PM
mad-max98's Avatar
could you post them thnx man
Old Sep 16, 2005 | 11:22 AM
MAXimumHP's Avatar
This may actually be more useful. The red shows the line between manifold vacuum and the solenoid. I used the vacuum point on the top of the manifold for my vacuum source (sort of hidden by the blue hose) The blue shows to the solenoid from the rest of the system. Basically I just hooked up the 4th gens line where the blue line ends because there is a service port in that area. I had to move some hoses around a bit and extent the wire for the solenoid, but it results in a really clean, factory looking install.
Edit: Re-did my coloring (I failed kindergarten)
Old Sep 16, 2005 | 12:46 PM
Zack342's Avatar
pics..........
Old Sep 17, 2005 | 03:43 AM
mad-max98's Avatar
thnx maximumhp,,, do you guys know if coolant lines run to 00 tb also what the hell is this thing right on the bottom of the throttle body with 2 ports and a plug in of some sort
Old Sep 17, 2005 | 05:42 PM
MAXimumHP's Avatar
Here's some pics if this help anyone:
Old Sep 18, 2005 | 04:22 AM
mad-max98's Avatar
bump.............
Old Sep 18, 2005 | 10:26 AM
Stephen Max's Avatar
The 00 and 01 throttle bodies have the IACV mounted on the bottom. I believe coolant lines do run to the TB, just like with the 4th gen TB. The coolant lines attach to the two ports on the IACV.
Old Sep 18, 2005 | 10:29 AM
jmeister's Avatar
They do run coolant lines to the TB but you can bypass that by just looping the lines back together instead of going in & out of the TB.
Old Sep 18, 2005 | 07:14 PM
MAXimumHP's Avatar
I looped mine, can't really see where they connect in this pic, but you get the idea.
Old Oct 5, 2005 | 06:24 PM
Powerman5115's Avatar
Coolant Lines: I'm alittle confused. Are both the in and out coolant lines on the TB, or is the in on the TB and the out on the intake manifold? If both are on the TB why can you not leave it as is, if you have a 4th gen TB?
Question about evap. I believe the objects I have circled in this picture are the a couple of components of the evap system. Sorry, I don't know the technical names of these. In my pic, the silver thing gets vacuum from the manifold, then goes to the black circular object. The black object has 2 hoses, one looks like it's going to the EGR and one going to the canister. Would all I need is the EVAP canister purge volume control solenoid valve and I can get ride of these 2 components?
MaximumHP: In your first post here in the diagram, the blue hose goes straight to the canister and the orange getting vacuum from the manifold; is that right?
Old Oct 5, 2005 | 08:21 PM
MAXimumHP's Avatar
After looking at this closer with other members, I noticed my car is totally different because I have a 99. That is why my swap was so easy, I basically had what 2000's have. I'd have to look into this closer on the FSM to answer your question if no one else can help you.
You can keep the coolant loop through the TB if you want, most of us just get lazy and close the loop. If I have problems this winter, I will probably re-route mine through the TB also.
Old Oct 5, 2005 | 08:26 PM
Kevlo911's Avatar
Kevlo for President
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
tseng1023
Oct 15, 2015 08:30 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
