Sponsored by:
Sponsored by: CARiD
3.5 swap procedure and FAQ
Old Nov 15, 2005 | 10:03 AM
  #81
MaxObesset's Avatar
i just put on the stock fpr car runs even better im gettin an aem fpr but im still havin the jerkin issue alil bit not as much as before but still there you think it could be my 02 sensor and crank/cam causin the car to do this?
Old Nov 29, 2005 | 07:43 AM
  #82
Max1man's Avatar
Now here's a question....Tilley is in the process of completing my engine (waiting for Cattman GEN2 Headers) and when we spoke he told me that I didn't really need to worry about doing anything to the fuel system or FPR after I told him I had a hiflow aftermarket fuel pump. Any comments on this?
And maybe I'm missing something here, but, by following the directions for the FPR, thats all well and good but what connects to the outlet of the fuel rail? If you 'T' the line between the filter and the rail, run one leg to the rail and the other leg to the FPR, thence to the return (to tank) line that was plugged into the outlet of the fuel rail.....well...doesn't that just leave and open exit port on the fuel rail??
I'm basing this question on the pics I've been seeing in here. Does the 5.5 fuel rail have a sealed end on it in stock form? Perhaps I've been looking at 'modified' rail pics that look like they have an entrance and an exit?
Old Nov 29, 2005 | 11:15 AM
  #83
nismology's Avatar
The fact that you have a high-flow fuel pump would be an even better reason to get an adjustable FPR IMO.
Yes the stock 3.5 fuel rail doesn't have an exit to go back to the tank, only an inlet.
Old Nov 29, 2005 | 12:25 PM
  #84
Max1man's Avatar
So what we're talking about here is not attaching an FPR to the fuel rail via an Off Kit but merely using it in between the feed and return fuel lines?
Old Dec 2, 2005 | 09:54 AM
  #85
Max1man's Avatar
*bump* for answer to last question
Old Dec 2, 2005 | 10:22 AM
  #86
Jime's Avatar
Thats where mine is going. I don't see any requirement to feed in and out of the fuel rail. I am just connecting the output of the FPR to the rubber hose feeding the fuel rail and connecting the fpr return to the stock return line. KISS
If someone wanted to use the stock 4th gen fpr you could just use it to replace the damper at the end of the rail but then you would only have 42 psi not 52 that the 3.5 is used to feeding on.
Old Dec 2, 2005 | 10:52 AM
  #87
nismology's Avatar
51 is stock fuel pressure spec for 5.5's.
Old Dec 2, 2005 | 01:10 PM
  #88
MaxObesset's Avatar
anybody have any pics of there fuel setup i also did the 3.5 swap i have the stock fpr on the one side and just a plain line in the other im installin my aem fpr this week to 51psi
also do we need to use the dampers on the 3.5 rail with the stock 97 fpr or no need to?
Old Dec 2, 2005 | 01:19 PM
  #89
nismology's Avatar
There's no need for the dampers since the inline fuel filter dampens the pulses on its own.
Old Dec 2, 2005 | 01:41 PM
  #90
Jime's Avatar
There is no need for them but there is also no need to take them off if you are using an aftermarket fpr, you are just making it more difficult for yourself.
Old Dec 2, 2005 | 04:49 PM
  #91
MaxObesset's Avatar
ok right now i have the stock 97 fpr with a plain fuel line in the car im gonna put the aem fpr in tomorrow or sat and set it to 51 psi i have the damper also i was thinkin of installing it on the other side of the fpr i just wanna know what it is and should i put it on or not
Old Dec 16, 2005 | 02:53 PM
  #92
WielkiWaac's Avatar
MaximaDriver
Tb
why we cannot use TB from VQ30 engine??
Old Dec 16, 2005 | 03:51 PM
  #93
Nismo3112's Avatar
Custom User Title
You can, but its 9-10 mm smaller than a stock VQ35 TB, so I don't see why you would want to.
Old Dec 20, 2005 | 02:17 PM
  #94
ajcool2's Avatar
How long should a swap like this take? I'm sure it depends on alot. If you have the swap how long did it take to get it done.
Old Dec 20, 2005 | 02:28 PM
  #95
lowerhalo's Avatar
so I've looked through this
Head swap from the 3.5 to 3.0 possible? And any probable substantial gain?
Old Dec 20, 2005 | 02:48 PM
  #96
MDeezy's Avatar
When I do the swap I'm going to take a week off from work. Hopefully that will be more then enough time
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
