Sponsored by:
Sponsored by: CARiD
Mallfinder TB + jwt or techno ecu
Old Sep 26, 2005 | 11:22 PM
Playboycutie69
Will getting the pathfinder throttle body wit a jim wolf ecu be enuf to feel a oticeable difference. If I am getting a pathfinder throttle body should I order my jim wolf ecu wit timing very advanced to get the most out if it.
Old Sep 27, 2005 | 05:08 AM
Stephen Max's Avatar
You'll feel a difference in throttle response with a larger TB, but overall power gain from a Pathfinder TB on a NA 3.0 is going to be marginal at best, unless you do other things to significantly increase the airflow (i.e. cams, high rev limit, or VQ35 swap).
Old Sep 27, 2005 | 06:05 AM
DandyMax's Avatar
3.5 in the works
I just trapped 101 basically with the 00VI and only 4th gen TB and that's with 7000 rpm limiter. Plus the recent dyno from Joe showing a mid-range loss and I'm not convinced PF TB is the way to go on a 3.0.
I have one but been debating whether to put it on or not...
Old Sep 27, 2005 | 10:11 AM
Playboycutie69
let us know the outcome when you do.
Old Sep 27, 2005 | 11:13 AM
Weimar Ben's Avatar
Helicopters! Money!!!
You would be a lot better off spending the $500 on a MEVI, 00VI, or swapping in the DE-K than spending it on a JWT or TS ECU. With the MEVI or 00VI, it'll scream on the top end. The DE-K will give you better power on all parts of the powerband.
I wouldn't worry much about the ECU and TB. There was someone that had a MEVI, stock ECU, and stock TB that got 205whp.
Old Sep 27, 2005 | 10:32 PM
Playboycutie69
Thanks alot foo. Once again u save the day wit ur knowledge. One more thing, how will the 3.5 conv and pathfinder tb reactmwit jwt or ts?
Old Sep 28, 2005 | 07:15 AM
nismology's Avatar
Those dyno results are VERY questionable. His numbers are higher than any other maxima, ever, with those mods. I'd take those numbers with a grain of salt. By NO means is that typical.
Old Sep 28, 2005 | 07:29 AM
deezo's Avatar
Who owns the dyno?
Old Sep 28, 2005 | 07:36 AM
nismology's Avatar
Originally Posted by deezo
Who owns the dyno?
I'm not sure, why?
Old Sep 28, 2005 | 07:39 AM
Weimar Ben's Avatar
If you do the 3.5 swap, it would be a lot cheaper to convert the egas TB to cable driven. The mallfinder TB is hard to find and if you do find it, expect to pay $100-$200. Go look at my sticky. There's some pictures and directions on how to convert the E-gas to cable driven.
An ECU upgrade will net you much better gains on a 3.5 swap than with a 3.0L. ECU upgrade on a 3.0L without a VI would net you 5whp or less. On the 3.5, you're prolly looking at around 10whp, maybe 15. If you do that, have them advance the hell out of the timing and do a 7200rpm rev limit. Alternatively, you could get a E-manage Ultimate and do the same thing, plus a few more things.
Old Sep 28, 2005 | 07:42 AM
Weimar Ben's Avatar
I agree that those numbers may be a little high. I can't remember the exact details of it, but my larger point is that a ECU and TB upgrade won't net you much power on the 3.0L. Especially if you don't have a MEVI or 00VI.
Old Sep 28, 2005 | 07:46 AM
Weimar Ben's Avatar
This is what a MEVI or 00VI in combination with a JWT ECU will get you....
After 5000rpm, the stock intake manifold gets
Old Sep 28, 2005 | 07:48 AM
nismology's Avatar
Improper assumption again. The gains from an ECU on a 3.0 have been compared to the gains from an aftermarket y-pipe. Like +12 HP/+12 TQ. That's with stock intake manifold. Where do you get this stuff from? Just wondering...
nismology's Avatar
No. An ECU will net you substantial gains, VI or not. I agree with the PF TB though. Pretty useless on an n/a 3.0 IMO.
Old Sep 28, 2005 | 08:00 AM
Weimar Ben's Avatar
I seriously doubt that you would get 12hp/12tq throughout the powerband with a stock 3.0L. Please show a dyno where this is the case. I could believe 12hp with a 7200rpm limiter with a 00vi.
Another thing you have to take into consideration is the mods are less than the sum of their parts. Using ricer math, you could say
12hp ECU upgrade
20hp Y-pipe
10hp intake
25hp 00VI
10hp catback
10hp UDP
____
77hp + 190hp = 277hp. No need to get a 3.5!!! But that simply isn't the case. Your dyno numbers for the above mods would be around 200whp/200wtq which would equal about 240hp. I think the only mods that are really worth a d*mn are the 00VI and a y-pipe. Those two mods alone should net you 190whp-195whp.
Old Sep 28, 2005 | 08:20 AM
NmexMAX's Avatar
dot dot dot ...
Ricer math ... ..
I've seen dynos add 8hp/12tq JWT on a 3.0L.
BTW There's also no dyno with 10-15whp from advanced timing w/ 3.5L either
Old Sep 28, 2005 | 08:25 AM
Weimar Ben's Avatar
Originally Posted by NmexMAX
Ricer math ... ..
The 3.5 heads allow you to advance the hell out of the timing, a lot more than with the 3.0 heads. I think Tilley may have upgraded the ECU, but I don't think anyone else has. The 3.5swap in a 4th gen will make less power than a 3.5L in a 5.5gen or in a Altima 3.5. This is because the timing in the 5.5gen ECU is more advanced than with the 4th gen ECU.
Old Sep 28, 2005 | 08:31 AM
nismology's Avatar
You search. I've seen many dynos over the past 2 years or so i've been on this site.
12hp ECU upgrade
20hp Y-pipe
10hp intake
25hp 00VI
10hp catback
10hp UDP
____
You're preaching to the choir. Like i've said, many people have compared the gains from and ECU to the gains from a y-pipe. Very noticeable. Perhaps not 12 WHP like i said, but 8 WHP/ 12 WTQ like NmexMAX have certainly been gained, dyno proven many times.
An upgraded ECU is worth it, period.
Old Sep 28, 2005 | 08:37 AM
NmexMAX's Avatar
dot dot dot ...
It's worth it much more than a PF TB.
And besides better throttle response, the TB isn't really worth it, and the relation between TB and timing is minimal at best.
of all my mods, I/Y/E/MEVI, my ECU was the most noticeable, and it adds no loud wail such as an intake, or drone such as an exhaust, so instead of placebo, it was ACTUALLY noticed.
Old Sep 28, 2005 | 08:47 AM
eng92's Avatar
Here is about 8 whp peak increase just by changing the ecu. The increase in the midrange is more like 20 whp. Obviously no MEVI or 00VI.
However, this is with a dramatic increase in timing.
Old Sep 28, 2005 | 08:50 AM
nismology's Avatar
Thank you for that chart. This is one of the MANY that show that an aftermarket ECU is worthwhile, stock IM manifold or not.
Old Sep 28, 2005 | 09:40 AM
krismax's Avatar
Father of the 00 VI
My jwt ecu gives me 0% HP as proven on a dyno with back to back runs with and without.
Old Sep 28, 2005 | 09:50 AM
nismology's Avatar
That is not typical. Perhaps they didn't change the timing or a/f maps. This is what i'd call an anomaly.
Old Sep 28, 2005 | 09:51 AM
DandyMax's Avatar
3.5 in the works
That's what I was going to suggest.. perhaps they bumped the rev limit and forgot to change the timing and fuel maps...
Old Sep 28, 2005 | 11:27 AM
Playboycutie69
So what I am gettin from this is you can still use the jwt or tecnosquare with the 7200 rev limiter for the 3.5 to 4th gen conv but just ask them to advance the hell out of ur timing. And if you do decide to take this route, add the 00vi and pF tb you should be seeing at least 240-250 whp? Or a little less?
Old Sep 28, 2005 | 11:37 AM
NmexMAX's Avatar
dot dot dot ...
Why doesn't anyone do that? Surely there's someone around you 4.5g fellas has a JWT or TS ...
It's hard to throw a guess at whp when no variables are known (i.e added whp w/ timing advance w/ JWT/TS advance tuning etc)
Old Sep 28, 2005 | 11:40 AM
nismology's Avatar
There's no dyno evidence yet that says that the 00VI is superior to the stock 2k2 IM. It's all speculation so far.
Old Sep 28, 2005 | 08:01 PM
Nealoc187's Avatar
SLOW
Why do you keep calling it a Mallfinder TB?
Old Sep 28, 2005 | 08:20 PM
JClaw's Avatar
Housemoms.
If 5.5 gens and 3.5 Altimas can get like 10whp from an ECU, surely us 4.5 gens can get quite a bit more, since we start lower for the timing chart, especially with all the crap I've done to my car.
Old Sep 28, 2005 | 10:27 PM
Playboycutie69
Goodluck wit that. Maybe u can get technosquare or jwt develop a special timing advance for you 4.5 guys. I will be there soon hopefully.
Old Sep 28, 2005 | 10:36 PM
Weimar Ben's Avatar
Because 90% of all Stupid Urban Vehicles never see a dirt road. Their only use is for going to the mall or to soccer practice.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
gigabyte
Jan 6, 2017 06:05 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
