Sponsored by:
Sponsored by: CARiD
Counterfeit 3.5 EBay Cams
Old Oct 16, 2005 | 06:37 AM
Jime's Avatar
Has anyone been watching this thread about these cams. Going to be dynoed and results posted soon, should be interesting.
http://www.nissanclub.com/forums/sho...d.php?t=205439
EBay listing
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Oct 16, 2005 | 07:12 AM
SR20DEN's Avatar
VQ Wizard
From what I can see in the pictures, they are Nissan blanks but the lobes look stock. They are VQ35 cams because of the timing slots but the lobes arent back cut so I know they aren't just stock cams.
The price is nice if they actually do anything but we've already seen that cams in this spec range don't do much of anything for most FWD setups.
Whoever buys these better have a big collection of shims.
Old Oct 16, 2005 | 07:44 AM
SR20DEN's Avatar
VQ Wizard
I just read more through that thread and I noticed the deal brewing for the demo set. I sent the guy an email through Ebay and volunteered to be a test candidate.
Old Oct 16, 2005 | 02:12 PM
krismax's Avatar
Father of the 00 VI
wow if i had the cash id buy now ,wish they were alittle more agressive
Old Oct 16, 2005 | 02:45 PM
stephenlc's Avatar
it seems like he didnt gain any power, it sucks that he has an auto though.
Old Oct 16, 2005 | 03:12 PM
krismax's Avatar
Father of the 00 VI
he didnt dyno with the cams yet do you have a time machine
Old Oct 16, 2005 | 04:11 PM
SR20DEN's Avatar
VQ Wizard
He turned me down for the demo offer. We will just have to wait and see how things go now for the Altimas.
Old Nov 2, 2005 | 05:41 PM
Jime's Avatar
So do the shims have to be replaced with the cams?
Old Nov 2, 2005 | 05:59 PM
SR20DEN's Avatar
VQ Wizard
The seller said they don't.
Old Nov 6, 2005 | 06:17 PM
virgilio7's Avatar
i was the test car and got around 15 to 20 whp.
Old Nov 6, 2005 | 06:23 PM
Kevlo911's Avatar
Kevlo for President
You got the Dyno to prove it?
Old Nov 6, 2005 | 07:01 PM
virgilio7's Avatar
well. i was dynoing at 245-250 and the latest one came out at 265whp.
the spike showing 289 torque was a downshift. this dyno was before fixing the lean mixture i had with the other intake pipe. now is fixed and go it the dynoed at 262.
Old Nov 6, 2005 | 08:40 PM
SR20DEN's Avatar
VQ Wizard
I see you just got pretty close to my 270whp STD record with a 265whp STD in an auto. Not bad at all. What were the SAE numbers?
Old Nov 7, 2005 | 04:07 AM
virgilio7's Avatar
sorry i didn't get them cause i was so pissed that my tunning doesn't feel consistent after a couple of hours. i guess the ecu is changing the tunning by itself. hopefully this week i'm going to get a wideband and check it out for myself cause dyno sessions are becoming way expensive. i'm seriously thinking now about the tc flash.
Old Nov 7, 2005 | 05:51 AM
SR20DEN's Avatar
VQ Wizard
Be wary of paying for the full TS software unless they can tune your car specifically. Like most of us you're probably just better off getting the L-Spec and do the rest of the tuning yourself.
Old Nov 7, 2005 | 06:56 AM
NmexMAX's Avatar
dot dot dot ...
Try getting the run files next time ...
Old Nov 7, 2005 | 09:19 AM
virgilio7's Avatar
now that i read about setting up the safc2, the lo-throttle should be set at 40% what about hi throttle? what percentage?
Old Nov 7, 2005 | 09:44 AM
Stephen Max's Avatar
Most people (that I know of) are setting the low and high throttle settings right next to each other, e.g. low throttle at 39% and high throttle at 40%. So they are transitioning directly from zero correction below the low throttle setting to whatever correction at the high throttle setting. This means the SAFC is being used only for WOT corrections. You would have to do extensive dyno-tuning at various amounts of partial throttle to take advantage of the linear interpolation between low and high throttle settings.
Old Nov 7, 2005 | 09:57 AM
Jime's Avatar
That is how I had my 3.5 auto setup and it worked quite well.
Old Nov 7, 2005 | 10:28 AM
SR20DEN's Avatar
VQ Wizard
The best thing that works for me right now is 15% and 85%. But I have some parts that no one else has (390cc injectors and 77mm MAF).
Old Nov 7, 2005 | 11:25 AM
virgilio7's Avatar
there is a group buy for the headers I installed. 599 plus shipping. the deal is on nissanclub. check on it if interested.
Old Nov 7, 2005 | 11:49 AM
NmexMAX's Avatar
dot dot dot ...
I don't believe those will fit our cars.
Old Nov 7, 2005 | 12:36 PM
krismax's Avatar
Father of the 00 VI
I tried xs headers and they didnt clear our crossmember. unless they take a path in our favor they wont work
Old Nov 7, 2005 | 12:57 PM
virgilio7's Avatar
me and my stupid self. hahahaha my head is spinning as i'm trying to find info on a wideband. I was talking about cams. not headers sorry
Old Nov 7, 2005 | 01:03 PM
liqidvenom's Avatar
brotherhood of tq
so when are we gonna see this in a 3.5 maxima?
also would these cams work in those people using the 3.5 motor on a 4th gen ecu?
or would these cams even fit in a 3.0 motor?
Old Nov 7, 2005 | 01:11 PM
NmexMAX's Avatar
dot dot dot ...
It has already been done to 2 ( 4AT and 6MT) 3.5L Maximas that I know of...
You have search, use it.
Old Nov 7, 2005 | 07:38 PM
Starchild2K2SE's Avatar
What is the website? I am very intrested.....
Old Nov 7, 2005 | 07:46 PM
NmexMAX's Avatar
dot dot dot ...
Use the 1st link in this thread and start looking in there. .... It should be in the top 5 psots in that forum.
Old Nov 7, 2005 | 08:01 PM
virgilio7's Avatar
http://www.nissanclub.com/forums/sho...d.php?t=208259
Old Nov 7, 2005 | 09:00 PM
liqidvenom's Avatar
brotherhood of tq
i didnt kno anyone put these ebay cams in a max....my fault.
Old Nov 7, 2005 | 09:10 PM
NmexMAX's Avatar
dot dot dot ...
I was referring to JWT cams, which are the same grinds as the 'ebay' cams. Sorry...
Old Nov 8, 2005 | 04:24 AM
03BlkSETE's Avatar
IIRC, one guy had the JWT's installed incorrectly, (PhxBlue), and the other guy had Tomei 264's but in conjuction with stillen headers so it probably didn't show the results that he would have got with HS or Cattman headers.
Old Nov 8, 2005 | 05:59 AM
SR20DEN's Avatar
VQ Wizard
Yeah it was look2me40s car that I installed the Tomei 264 cams in. IIRC he only made 230ish whp but he did have the Stealin headers. Too bad I didn't get to stick around to tune his car or do a few other things to it.
Old Nov 8, 2005 | 06:59 AM
nismology's Avatar
SR20, what's your opinion on these ebay cams?
Old Nov 8, 2005 | 07:54 AM
SR20DEN's Avatar
VQ Wizard
I think they're very attractive for that price, at least compared to all the other cams.
Old Nov 8, 2005 | 08:03 AM
MardiGrasMax's Avatar
I guess my queston would be is the material they are made of going to stand the test of time?
Old Nov 8, 2005 | 09:12 AM
NmexMAX's Avatar
dot dot dot ...
Only time will tell...
Unless someone wants to do some metallographic analysis on the lobes/cams etc
Old Nov 8, 2005 | 03:28 PM
03BlkSETE's Avatar
Just so you guy know for what it's worth, it looks like Topspeed/Pro-1 are the makers of these cams. I had orignally thought so, but this thread confirms it.
http://www.my350z.com/forum/showthre...d+headers+pics
Old Nov 8, 2005 | 07:10 PM
nismology's Avatar
Would these cams need taller shims since they are modified stock cams instead of made from blanks?
Old Nov 9, 2005 | 05:43 AM
SR20DEN's Avatar
VQ Wizard
http://forums.maxima.org/showpost.ph...78&postcount=8
http://forums.maxima.org/showpost.ph...42&postcount=9
Also, I thought these were nissan blanks. Regrinds should need new shims unless they were welded and ground to spec on the base circle.
I wish someone would copy the Nismo Spec1 cams and sell them for that price.
