Sponsored by:
Sponsored by: CARiD
Anyone using Megasquirt yet?
Old Oct 17, 2005 | 06:32 AM
Fred Allen Burge's Avatar
Well, I've been reading up on Megasquirt lately. I'm strongly considering using it on my VQ in the future. It's a full standalone ECU for dirt cheap. http://www.megasquirt.info/
It would of course allow any changes to timing and fuel that you could ever want. So it would be great for NA or FI setups. Wiring it is simple, tuning it would be my biggest challenge.
I've got a lot of learning to do about it but it looks like changing to a Ford coil pack setup my be necessary (easy enough, cheap too).
Any thoughts?
allen
Old Oct 17, 2005 | 08:14 AM
DandyMax's Avatar
3.5 in the works
Can it read our crank/cam sensors, or would you have to change those out too?
Old Oct 17, 2005 | 09:26 AM
JeffesonM's Avatar
living out of a maxima...
Try contacting a guy named etx on my350z.com. It sounds like he has some experience with MS and was thinking about using it on his Z...
http://www.my350z.com/forum/showthread.php?t=128632
Old Oct 17, 2005 | 10:10 AM
I don't believe it requires a cam sensor, it does need a crank sensor. I believe you'd have to mount the trigger wheel on the front pulley and mount the new sensor next to it and ditch the stock front and rear crank sensors.
allen
Old Oct 17, 2005 | 12:42 PM
eng92's Avatar
allen
You have to know your valve position in order to inject fuel and fire your plugs. With some programming, for rpm, you can get away without a crank sensor, but you have to have a cam sensor.
Originally Posted by Megasquirt website
Sequential injection requires:
at least as many injectors as you have cylinders, with one dedicated to each cylinder (i.e., not a 4 injector TBI on a 4 cylinder).
as many injector drivers as you have cylinders,
and also requires a camshaft position sensor (a crank sensor is not adequate for a 4-stroke cycle engine).
Looking at the page a little more, you can see it was developed for engines using distributors. No COP system is currently available.
It looks like more of an educational/training tool than something you would put on your daily driver. I didn't see any mention of feedback control so I guess it is fulltime openloop.
db_s13
Mar 10, 2015 10:12 AM
jartech
34
Apr 9, 2013 09:50 AM
hightuner
Jul 13, 2010 11:10 AM
rmh3093
Apr 12, 2010 06:45 AM
thisisausername
Dec 9, 2005 05:32 PM
