Sponsored by:
Sponsored by: CARiD
how hard of a swap is this
Old Oct 22, 2005 | 05:44 PM
rome06's Avatar
ive been reading on this a lot and i have 2 mechanic friends that know what they are doing....but do you have to know MAXiMA's in general to know how to do this swap or just cars in general? Im sure a 3.5 swap is alot more challenging then just dropping in a honda motor where everything goes into place. thanks guys
Old Oct 22, 2005 | 06:17 PM
japmaxSE's Avatar
Go Get a Life!
It's always good to know your maxima in and out, it should make the install a whole lot easier. Doing the full 3.5 swap requires General Automotive knowlege, old engine out new engine in. If your going to tear the motor down like I had to for the Hybrid swap, you better have experience taking motors apart and knowing the proper procedures putting it back together.
Old Oct 23, 2005 | 01:16 PM
Weimar Ben's Avatar
Helicopters! Money!!!
your two mechanic friends shouldn't have any problem with the swap as long as they know the procedure-drilling the cams, using cam spacers, using stuff from the 3.0, etc.
Old Oct 23, 2005 | 03:55 PM
JClaw's Avatar
I had little mechanical knowledge before the swap (practical, anyway) and took my time. It's not much longer than a Honda swap, and it's a whole lot cheaper.
Old Oct 23, 2005 | 06:37 PM
rome06's Avatar
alright that good to hear because one of them has taken apart 2 porsche motors and rebuilt them for his cars and currently is rebuilding one now so hopefullly were in good shape.....now just time to find a engine....
Old Oct 23, 2005 | 08:37 PM
NmexMAX's Avatar
dot dot dot ...
www.car-part.com .. but I'm sure you already knew that.
Old Oct 24, 2005 | 05:37 AM
rome06's Avatar
yeah ive been lookin there mostly but thanks tho
Old Oct 25, 2005 | 01:03 PM
rome06's Avatar
the only thing you have to the vq35 is just put spacers im the cams and drill the holes right?
Old Oct 25, 2005 | 02:03 PM
guyfromkop's Avatar
i'm sure if the guy has worked on porsche engines he will have no problem
Old Oct 25, 2005 | 08:03 PM
rome06's Avatar
thats what im hoping man...im like a perfectionist freak...it its not done to perfection then you might as well rip one of my ***** out because thats how i would feel about my car
Old Oct 25, 2005 | 08:19 PM
NmexMAX's Avatar
dot dot dot ...
Instead of telling him what you want, refer him here, or print out as many important facts as you possibly can..from here
Old Oct 26, 2005 | 02:33 PM
Dubbya's Avatar
VK56 Inside
Poor padowan. There is much more. Timing system needs to be swaped to the VQ30, fuel pressure regulator added, rpm switch added, and a few other things. Read some more, all the info is in this forum. Id say you are off to a good start though.
Old Oct 26, 2005 | 08:24 PM
scrhale's Avatar
That is not true. Timing System is not necessary. If you are talking about VTC then it is just crazy to attempt swapping to 3.5 ECU. FPR will make the car perform MUCH better, but isn't 100% needed. RPM switch is just $50-$80 bucks so no biggy.
Old Oct 27, 2005 | 07:31 AM
Dubbya's Avatar
VK56 Inside
When I said Timing System I ment then Timing Chains and Gears. You know of a way to make the VQ35 ones work with the VQ30 Ecu or was I just not clear?
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
