Sponsored by:
Sponsored by: CARiD
what else do i need for the 00vi swap?
Old Nov 14, 2005 | 12:48 PM
Mr.Duck's Avatar
i have
-upper 00vi
-rpm switch
-iacv adapter
-tb adapter
i know i need some bolts which i will get but what else? also i either need the egr block off, or the 2k egr guide tube correct?
Old Nov 14, 2005 | 01:31 PM
aznsap's Avatar
you'll need to drill your lower IM. also maybe something about jwelding some cup? i'm not really sure, i was planning on looking into it later as i plan to get an 00VI as well in the future
Old Nov 14, 2005 | 03:46 PM
THT's Avatar
THT
Throbbing member
Dave, are you planning on using the 4th gen lower IM and fuel equipment? If so, we'll need to port match the lower IM and do one of the following:
a) Keensert/Helicoil the lower IM for 6mm bolts
b) Drill out the 00VI bolt holes to 8mm from 6mm
You'll want something to control the VI opening as well; I suggest a VAFC. As far as the EGR is concerned, we should be fine with removing the vaccum source which will keep the EGR valve closed.
Old Nov 14, 2005 | 03:58 PM
Nismo3112's Avatar
Custom User Title
But I believe the EGR valves on 99's are electronic.
Old Nov 14, 2005 | 06:22 PM
Zack342's Avatar
You believed correct
Old Nov 15, 2005 | 03:55 AM
Mr.Duck's Avatar
well i know about the port matching and the drilling, i was wondering if i need to purchase any more parts....
*edit* lol i also find it funny that the 1st 3 replies are from the 3 ppl that are helping me install lol
Old Nov 15, 2005 | 07:22 AM
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
is there a write up on how to install the 00VI
Old Nov 15, 2005 | 06:55 PM
Mr.Duck's Avatar
bump, still wondering if i need more parts...
Old Nov 15, 2005 | 07:07 PM
Nismo3112's Avatar
Custom User Title
-PCV valve that doesn't have a 90 degree angle to it, and something to connect to the valve cover with.
-misc vacuum hose
-extra wire to hook up VI, and rpm switch
Old Nov 19, 2005 | 11:44 PM
mad-max98's Avatar
i'm sorry i don't mean to steal the thread but where do you connect the input wire for the rpm switch
Old Mar 10, 2006 | 02:05 PM
ronin22357's Avatar
mr duck - did you get this installed? I am going to take the same route with my 00VI as you have 00VI upper/ 4th gen lower. What are you using as a switch, how did you hook it up? A VAFC is out of the question for memy pockets are not that deep right now. What other parts did you need to get? I am going to do a detailed write up with pics for this setup and want to get all the info I can before I get started.
Old Mar 12, 2006 | 07:32 PM
speed racer's Avatar
It sounds like you got everything. You will need to grind down the coil bosses. Your method requires alot of fabrication but its doable. Get lots of hoses various sizes and clamps. As far as the EGR guide tube is concerned you need to look into the local laws for emission testing and I'm not sure about the elctronic setup for the 99s but sounds like it needs a little more research.
Old Mar 13, 2006 | 03:35 AM
ronin22357's Avatar
all I need to know now is what the two connectors on the 00VI are for so I can wire my summit switch up. somebody please help me out
Old Mar 13, 2006 | 07:00 AM
SDot82's Avatar
The red/yellow wire it power and the other wire, which is green I think, is ground. The ground goes to the rpm switch and then hook the power up to any type of power source.
Old Mar 13, 2006 | 08:50 AM
ronin22357's Avatar
I didnt get the harnesses with my 00VI it has a black 2 pin connector and a brown 2 pin connector next to each other. Which wire goes to which?
Old Mar 13, 2006 | 10:41 AM
SDot82's Avatar
The left (should be black 2 pin connector) is the one you want to use. For the pins the left pin (on the black connector) should be for power, and the right pin should be for ground. Somebody correct me if I am wrong because I don't have my car infront of me.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
JonBlz
Oct 5, 2015 06:02 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
