Sponsored by:
Sponsored by: CARiD
rpm switch connection quick please
Old Nov 21, 2005 | 12:32 PM
mad-max98's Avatar
where do we conect the input wire that's supposed to be connected to tach signal
Old Nov 21, 2005 | 12:42 PM
Nealoc187's Avatar
SLOW
You mean to get the RPM signal? You can either use the TAM screw behind the instrument cluster or the RPM signal wire on the ECU harness. I personally used the RPM signal wire on the ECU harness. Check your FSM or Haynes or Chiltons to find out what color it is.
Old Nov 21, 2005 | 11:10 PM
I30tMikeD's Avatar
White with a green stripe if you go the ECU route
Old Nov 25, 2005 | 01:31 PM
zander's Avatar
tam screw is easy, no cutting/splicing
Old Nov 26, 2005 | 09:27 AM
mad-max98's Avatar
i used the wire behind the cluster,, i still had to solder though
Old Nov 26, 2005 | 09:45 AM
s0ber's Avatar
my rpm wire was blue w/ white strip on teh ecu
shilov
Feb 19, 2024 09:40 PM
James92SE
Oct 8, 2015 04:57 PM
Colossus
Sep 9, 2015 05:46 AM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
