3.5 problems
Originally Posted by SR-71 Blackbird
It's kinda hard to describe. It doesn't rev freely at all. It sputters really bad and seems to be misfiring. All cylinders are getting gas. The fuel pressure is set at 40psi.
I would think that if the cam timing was off, that the compression would be much lower or none at all. The engine has 800 miles on it. One thing that was interesting is that all the spark plugs in the front bank were pitch black, not sooty or oily though. The spark plugs in the rear looked nearly brand new and weren't black at all.
I did a compression test and found that the rear bank's cylinders were all at 190psi and the front bank were all at 150. Is there any good explaination for that?
Don't you mean the front bank? The front bank had 150psi and the rear had 190psi. Wouldn't 190psi right about where it should be, whereas 150psi is a little low, but still within spec.
This is from pg. EM-30 of the 97 Maxima FSM
I'm not quite understanding this. How do you install the pulley and then turn it 60deg independent of the crank? Or is it saying that you should turn the crank 60deg??? Could someone explain???
Originally Posted by Biggs_02
i think it's saying turn that bolt 60 degress front that position on the pulley
torque + angle is very common for critical torques in the automotive and construction industry. It is alot more accurate than a torque value alone since lubricants and other things can come into play.
i suggest that you get someone to help you if you are doing this alone. The reason being, is because now you are fluttering your mind with endless possibilities to cause this problem. Maybe to correct everything is just a small ajustment or maybe a big repair...they say 2 heads are better then one right...don't worry, it'll work, especially if the motor has only 800 miles on it. Also don't take advise too seriously on forums. Narrow down where the problem may start from and move forward. Sometimes that might mean starting over aswell. Keep all options open, hope for the worst espect the best. Think about the day it'll work fine and you will be done with it. You never know, it could be really soon. Enjoy it
Ed
Ed
I think I know what the problem was. I just scanned the codes using a obd-ii scanner and there was a maf code. I just started up my other maxima with the MAF unpluuged and it ran in the same way that this 3.5 was running.
The problem now is that it doesn't seem to be seeing the crank sensor (REF) and oil pressure sender. Everything's plugged in, but it isn't turning on the fuel pump because it doesn't see the crank sensor. The oil light used to turn off when cranking. I'll have to do some pin testing to see if there's a problem with the harness.
How do you turn the bolt 60deg after you torque it down? Why would it not just give a torque # instead of just saying torque it down 30ftlb then torque it down more by turning the bolt 60deg?
a dirty maf can cause issues, but it doesn't seem that the maf is the issue. It's been raining or snowing on my days off lately, so I haven't been able to work on it much.
i really hate to bother you but i need to no this stuff and nobody seems to lend a hand.is it normal for when im cranking the car should the rpms beat @ ~1000rpms(fluttering).also when crankin my car backfires sometimes.also when turn the crank by hand i can hear the injector clicking so this means im gettin fuel.right?oh yeah this is a vq35 4th gen.
MaxRPM6
Sep 11, 2015 06:56 PM
