For all those who swapped engines...
I'm looking to do my 3.5 swap in the spring, and i have a question for those who swapped engines. How easy is it to take out the engine and transmission attached to each other?
The reason I ask is i'm getting a spare 5spd tranny, and would very much like it if I got the whole assembly on before I put it into the car, so the only thing I would have to do after bolting on motor mounts is attaching sensors and axles, and starting the car.
I know how much of a hassle it is trying to perfectly align the tranny on the engine while inside the engine bay. Took me 2 hours to do it with 3 friends and a small hydraulic jack.
So, is it possible to angle the engine on a cherry picker for it to come out with the tranny still attached?
thanks,
-Freddy
thanks,
-Freddy
Well I pulled the engine and tranny together, then pulled the 3.5 apart, fit all the sensors correctly, changed the clutch and attached the tranny to to the 3.5 then put the whole neat package back into the car, no hassle, from under. But I had a lift to work with.
I think it would be harder to take both from the top than removeing the tranny and engine seprately.
I would remove the engine and tranny seprately, and then when it comes time for installation install both engine/tranny together from the bottom.
I've done it with removing BOTH an auto tranny and installing one with a manual tranny and it can be done, Oh...and from the top as well. its not that difficult, in fact the angle of the engine/tranny is all you have to worry about. When in the spring you looking to do this? I may be up for helping....
Thanks,
-Freddy
Originally Posted by JClaw
Anyone know what's the record for pulling the trans out while it's in the car? (jacking car up, axle, crossmember, bellhousing, ect)
This was done with a bike jack and one racthet 17mm 19mm 14mm 12mm 10mm same with wrenches thats it. Best time out of the four: had to be like 15min to 20min because sienfeld came on and was still on when I was done.
I left the wheels on this time much better.
Wow, I usually take a lot more time, although I've done it like 5-times yet. Once I had to pull and reinstall the trans 3 times because there were pieces of gear that jammed the shifter rod inside the casing under the differencial. Now I know my trans inside out.
I've done it about 15-20 minutes as well. Air tools of course. Hand tools (which I've also done) takes alot longer. I've pulledprobably 8 maxima transmissions now (like 4 in the turbo car, plus other people's maximas).
And half of those because it was stuck in reverse?
Kidding...
Did you ever get them to solve that problem or have you stored the car for the winter?
Kidding...Did you ever get them to solve that problem or have you stored the car for the winter?
No I was talking to Neal. But you should seriously consider doing your own tranny work. I do mine and it's really easy. I can completely disasemble my 5-speed in about 20 minutes. Both times I blew a gear I purchased a used one for 40$. Hell I even found a complete VLSD differencial for 150 bucks. Only thing you can't do yourself is reasemble all the gears/synchros/ect on the shafts, which any transmission shop will do for about 50 bucks.
I would if I had the time, I did the first couple of times. When reverse got stuck on me twice, that's why I thaught you were talking to me. But I would have changed my mind anyways. I'm looking at the bigger picture now that graduation is comming around.
Pulling the trans off should take like 20-30 minutes what were you doing that it took you two hours lol.
I've done an engine swap on a 1st ge eclipse, non-turbo auto -> turbo 5spd, and that was alot easier, considering the engine and tranny were always together, and we had a cherry picker.
Originally Posted by laylow1988
hey freddy how much would you charge for a 3.5 install or de-k even .
Hope this helps.
Thanks,
-Freddy
cool now that i know that you would be able to do this i will consider my options and let you know of my future plans. i still have your number so i'll keep in touch. i just bought another 4th gen engine at a great price just to get my car running so i'll most likely sell the mevi and use the income to buy the dek or 3.5 . when you get your 3.5 in maybe i'll have to get a ride in it to maybe make my decision
you can pull the engine and tranny out together pretty easily, but putting them back in together can be a bit of a pita because the tranny mount on the frame kinda gets in the way.
After doing 2 now I think the easiest way is to remove from the bottom. I did mine with a simple cherry picker hung from a balcony above my workshop outside. After removing everything that needed removing, I put a trolley under the engine and trans and lowered them down using the cherry picker. Then lifted the car up with the cherry picker using the front cross piece under the radiator. Raised the car high enough to clear the top of engine and then just pull the trolley out. Install the same way just put the engine and trans under the car and then lower it. Then lift the engine and trans to bolt up the mounts. Works very easily and simply.
I was in the same boat as you, then i drove Krismax's 3.5 4th gen, and I was astonished as to how much power that car put out. After driving that car, my car felt like a slug. And also, keep in mind his car revved to 8k. With this setup, I hope to get into the 13's. I will also have my power steering, and A/C functions. it's still a daily driver. I'll try to cut as much weight off as I can...I already got some pretty light 17's, and grippy tires. I've done the manual swap, and the 3.5 can be considered weight reduction, as it is 40 lbs. lighter than the VQ30. After the 3.5 swap, i'll do a turbo setup, because I caught the boost bug....all my friends have turbos in their cars...and i'm jealous. But my goal for next year is low 13's, high 12's in an all motor VQ, with full interior.
-Freddy
Thanks,
-Freddy
Originally Posted by tavarish
did you remove the crossmember before putting the trolley underneath? i have an engine hoist, and that's a creative way of taking out the engine, and also eliminates the fear of having my new 3.5 falling on the floor.
Thanks,
-Freddy
Thanks,
-Freddy
-Freddy
-Freddy
i think the 3.5 if i do indeed do it will be my last major modd for a while until i finish nurseing school. i pretty much just want my car to beat corvettes and other high priced cars that thnk they are the ish .
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
not in the snow
