Sponsored by:
Sponsored by: CARiD
Pin location for VI on 2k2 ECU?
Old Dec 15, 2005 | 07:21 PM
steven88's Avatar
Need A Light?
Sorry if this is a repost...but can someone tell me which wire is for the VI on the 2k2 ECU? I already downloaded Jime's wiring diagram (thanks) and have the VAFCII in hand...want to install it by this weekend...thanks!
Oh yeah...Besides mounting it on the top middle (above the A/C vents)...where else can I mount it? Any suggestions for mounting locations will be grealy appreciated!
Old Dec 15, 2005 | 10:43 PM
Puppetmaster's Avatar
Does this help? http://forums.maxima.org/showthread.php?t=441029
I might mount mine on the dash covering the trip computer, although it will be removable (velcroed). I was also thinking between the Bose and the steering wheel, although I'm not sure how much space there is and how well you can see it from there. These are just ideas, I need to actually take the unit into the car with me to get a better idea.
Old Dec 15, 2005 | 11:04 PM
steven88's Avatar
Need A Light?
I thought the VIAS wire is on the ecu itself? Or do you tap it to another wire somewhere else?
Old Dec 16, 2005 | 03:41 AM
Jime's Avatar
Pin 27=VIAS control solenoid valve
Old Dec 16, 2005 | 05:33 AM
Thanks for the info, Jime.
I just realized that its in the diagram on EC-28 of the FSM as well.
Old Dec 16, 2005 | 05:55 AM
Jime's Avatar
Yes thats a great diagram for an overall picture of everything. I usually use the lists starting on EC-142 because they give you a little more info but EC-28 sure is nice to have. Should print that out and hang it on the wall.
Old Dec 16, 2005 | 10:27 AM
NmexMAX's Avatar
dot dot dot ...
Why would you adjust the VI switchover, it's fine where it's at, unless you have dynos to prove otherwise re: your mods.
Old Dec 18, 2005 | 11:02 PM
steven88's Avatar
Need A Light?
I'm not gonna adjust VI switch over...I just want that wired to be connected...so I can get the red LED to blink when I hit my VTEC y0!
Hey Jime...I know your installation instructions are for an SAFCII....since I have the VAFCII...am I going to be left out with extra wires when installation is done? I know the VAFC has the RPM wire...also I read somewhere it has the VTC wire too....can you list the PIN #s for any wires that I should tap into while I'm down there? I just want everything to be hooked up
Old Dec 19, 2005 | 04:37 AM
Jime's Avatar
I don't have a pinout for the VAFC so I don't know what else is on it. BTW there are also wire on the S-AFC that don't get hooked up so don't expect to use them all. Never heard about the VTC wire either and the RPM is a must for both.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
