Sponsored by:
Sponsored by: CARiD
00vi
Old Dec 30, 2005 | 04:15 PM
99Maxxx's Avatar
00vi
Ok, so I have one more question about this thing. My intake finally got here today and after looking at it I do have one question. There's an almost football shaped port close to the throttle body on the underside of the intake. What goes there?
Old Dec 30, 2005 | 06:15 PM
Weimar Ben's Avatar
Helicopters! Money!!!
Sounds like the EGR. Take a pic and post it.
Old Dec 30, 2005 | 06:19 PM
99Maxxx's Avatar
Thats what I was thinking it was, as I saw no other place to mount the EGR. Other than the device to activate the VAIS, and the new EGR tube, are there any other parts I will need before I get knee-deep in the installation?
Old Dec 30, 2005 | 06:41 PM
Weimar Ben's Avatar
Stolen from a stephenmax post...
Parts from VQ30DE-K:
1. UIM
2. LIM
3. fuel rail and injectors
4. injector harness connectors
5. rear valve cover
6. rear ignition coils
7. egr guide tube
8. RPM switch or VAFC to control the VI.
9. IACV remote mounting plate
10. TB adapter plate, unless you use the DE-K TB
11. gaskets
Old Dec 31, 2005 | 08:33 AM
chilled's Avatar
1. UIM
2. LIM
5. rear valve cover
7. egr guide tube
11. gaskets
You can drill the LIM. You can use the 4th gen fuel injectors and rail. You can just get an egr delete plate. You can adjust the idle manually instead of using the IACV with the screw on the TB. You can grind down the back driverside coil pack boss and the one beside it instead of getting new valve covers.
This is just if your a cheapass like me.
Old Jan 1, 2006 | 04:46 PM
99Maxxx's Avatar
Yeah, thats what I had intended on doing. I got a complete upper off eBay for $260 that included the TB, IACV, and a functional VIAS. I'm just trying to track down all the other parts that I'm gunna need for a smooth installation. The local Nissan dealer has the 00 EGR tube for $40 or something like that, and as far as I know that should be the only other part that I need as long as I can figure out where all those damn vacuum lines go.
Old Jan 3, 2006 | 02:28 PM
96blackmaxSE's Avatar
boost me.....
make sure you have all your bolts ready....that was one of my problems
Old Jan 3, 2006 | 08:22 PM
99Maxxx's Avatar
Would you suggest going to Nissan to get them, or just drill and tap to use whatever bolt I can find at Lowe's or a hardware store or something?
Old Jan 3, 2006 | 08:28 PM
boost me.....
for the EGR you can get them from lowes....however to get the ones that go through the holes on the upper to hold it on you hvae to go to nissan....im still waiting for nissan to get my last bolt in so i can have peace of mind that its not going anywhere lol. i got the part numbers for them around here somewhere....ill post them up if i find them
Old Jan 3, 2006 | 09:02 PM
99Maxxx's Avatar
That would be awesome if you could. One other thing, does the EGR tube bolt directly onto the plenum or is there some plate to mount it to?
Old Jan 4, 2006 | 12:16 PM
SDot82's Avatar
Yeah you messed up a lot. You had me running all over city to get **** for you car.
Old Jan 4, 2006 | 01:02 PM
s0ber's Avatar
I remember when I did my VI, my friends musta wasted like 10 gallons of gas those 2 days going out gettin gparts that were missing.. lolers...
Old Jan 4, 2006 | 01:19 PM
Kevlo911's Avatar
Kevlo for President
I had an 00fed spec dek at my disposal.
Old Jan 4, 2006 | 01:35 PM
s0ber's Avatar
lucky bastid. lol
edit: tranny gets here on monday or tuesday, woot
Old Jan 4, 2006 | 01:44 PM
99Maxxx's Avatar
haha, too bad I'm going in on my own on this one. It definately oughta be a trip...
Old Jan 4, 2006 | 02:00 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by s0ber
lucky bastid. lol
Sweet let me know how it goes.
Paint and wheels comming soon
Maybe a month or two and my 5speed swap comes too. If paint doesnt get done, it might be a SC/5speed swap or VQ35/5speed swap
Old Jan 4, 2006 | 04:54 PM
boost me.....
it should have a triangular plate already on it with the holes for the bolts on the sides. It bolts directly onto the upper plenum on the bottom behind the TB.
Old Jan 4, 2006 | 04:56 PM
boost me.....
dude, it was a long 5 days....lol, im still recovering
Old Jan 4, 2006 | 05:23 PM
SDot82's Avatar
I had to do it myself and thats why it took me so long to do it. Everytime I need to go out and get something I couldn't because nobody was there to take me. My advise to you is buy a lot of extra hoses, clamps,J B weld stick, tees.
Old Jan 4, 2006 | 05:25 PM
SDot82's Avatar
lucky bastid. lol
What kind, lsd or non?
Old Jan 5, 2006 | 02:33 PM
99Maxxx's Avatar
Well, I ordered the bolts and the EGR tube today. We'll see if it all comes in as planned....on a side note I'm going to run at our only 1/4 mile track on the 14th to see how it does on motor/nitrous, which should be interesting as well.
Old Jan 5, 2006 | 04:29 PM
boost me.....
good luck with everything!
Old Jan 6, 2006 | 12:13 AM
Mr.Duck's Avatar
i hope you didnt may 40 dolllars for an egr guide tube... DaveB sells them for much less... thats where i got mine...
still waiting to install my vi.. its too cold here in chicago lol
Old Jan 12, 2006 | 02:22 AM
alsummax's Avatar
hi where can i get an iacv adapter plate?
Old Jan 20, 2006 | 09:08 AM
99Maxxx's Avatar
My ast question is concerning the hybridization of the 00 IACV and TPS onto my 99. Are the plug-ins the same? I mean, the TPS won't matter as much since I have to use my 99 unit anyway, but what about the IACV? Same plug?
Old Jan 20, 2006 | 12:29 PM
SDot82's Avatar
Kind of....there is a only minor cutting to be done. That is what I am doing with my 97. I plugged my 4th gen IACV plug into the 00 IACV. It works great meaning it does the high idle for cold starts and the rpms do not jump around on me or stall.
Old Jan 20, 2006 | 05:23 PM
99Maxxx's Avatar
Cool, thats one less thing to have to get concerned about. I went to the Nissan dealer today to pick up my bolts and EGR tube and they ordered me the wrong tube, so I'm considering putting the intake on and just plugging the EGR off until they can get it in....not the greatest thing to do, but I won't have another weekend to put it on for awhile, so...
Old Jan 20, 2006 | 07:16 PM
Mr.Duck's Avatar
im telling you.. buy the egr guide tube through daveb... cheap fast shipping.. dont waste your money!
Mr.Duck's Avatar
Old Jan 20, 2006 | 10:33 PM
99Maxxx's Avatar
well, as it turns out, the tube that she quoted me the proce for at the dealer that was $40 was the wrong tube, hence my question. The right tube was $18 and that sounded reasonable enough, but would I have any drivability problems if I install the intake and just delete the EGR until the tube comes in?
Old Jan 21, 2006 | 07:34 PM
99Maxxx's Avatar
I started the installation today, and about 9 hours later I'm still not finished, but this is just day one. I'll have some pics to post tomorrow. Other than having a time with the two bolts on the ends, it wasn't all that bad. The only thing that sucked was having to cut out the vacuum/fuel branch thats under the TB. With the IACV on there it wouldn't clear the branch and I couldn't move it, so I took it out. I'll have pics to explain all this later
Old Jan 22, 2006 | 07:38 PM
99Maxxx's Avatar
Ok, somebody lend me an idea here...
I got the intake put on today, got all the vacuum lines, fuel lines, and coolant lines hooked up and in the right places. No vacuum leaks that I know of, but the car idles up and down, even at operating temperature. I used the 5th gen TB, IACV, disconnected the 99 EGR guide tube. I'm not sure if the modification I did to the 4th gen harness worked using the 5th gen IACV, but it seems to be working just fine. Any ideas? Also, if you rev it to about 3000 it acts normal, but if you go higher than that, it comes back to idle very very very slowly, like the TB is stuck.
Old Jan 22, 2006 | 08:15 PM
SDot82's Avatar
Well I noticed when I fixed a broken hose on the egr-bpt valve (looks like a UFO) which connects to the egr-valve it corrected my idle problem. Before the idle would jump around after I let off the gas, then it would finally settle down around 600 rpms. Sometimes it would flux so much the car would die, so maybe the egr not being connected is messing up your idle. Or you might have the 4th gen IACV harness in the wrong way, you cand try flip it around (if you know what I mean by that).
Old Jan 22, 2006 | 09:26 PM
99Maxxx's Avatar
I thought about the EGR valve and IACV. The TPS could be out of adjustment too. I figured if I left the EGR connected I could just cut the tube to the intake and not cause any idling problems. I hope the 5th gen IACV works with the 4th plug, but that will ahve to wait til tomorrow
99Maxxx's Avatar
Also, I was only able to use 4 bolts on the intake, and after I helicoiled the middle two I couldnt really torque down on those bolts, but I dunno...
Old Jan 23, 2006 | 07:43 AM
SDot82's Avatar
It does because I am using it right now with no problems anymore (after a year of messing around with everything). I will try and get a pic of my plug and IACV
Old Jan 23, 2006 | 08:34 AM
jmeister's Avatar
I've removed my EGR system without any idle issues.
The idle isn't consistent but never flucuates more than 75RPM either direction. That's mainly due to my non-functioning IACV
Old Jan 23, 2006 | 08:55 AM
SDot82's Avatar
So does your not die out anymore?
Old Jan 23, 2006 | 09:07 AM
jmeister's Avatar
Well, I have to give it about 2% throttle on startup but other than that it runs like a scalded pig.
Old Jan 23, 2006 | 09:44 AM
SDot82's Avatar
Thats weird because on my friend's 96 SE (the one I just did the swap on) he has to give a little gas on startups if it has been sitting for over 5 hours. Mines starts up like a champ and idles like a champ now . Just need to replace those O2s this week.
