Building a custom VQ35DE intake manifold
Old 03-05-2006 | 02:52 PM
  #41
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Perhaps you should read and learn instead of talking crap.
Old 03-06-2006 | 05:14 PM
  #42
Fred Allen Burge's Avatar
Update:
Chucked the steel long tube manifold idea and took the advice of many on here and went w/ a short runner large(ish) plenum design, still working out many details but here's a couple teaser shots.
enjoy,
allen
Old 03-06-2006 | 08:41 PM
  #43
aznsap's Avatar
oh you tease
Old 03-07-2006 | 03:59 AM
  #44
JClaw's Avatar
lol
Allen, does the VQ35 timing chain clear the stock 240 hood? Will it clear with your custom plenum?
Old 03-07-2006 | 04:39 AM
  #45
chris'smax's Avatar
Originally Posted by allen22
Update:
enjoy,
allen
Looks good so far, what tool or machine are you using to make the bends in the sheet metal?
Old 03-07-2006 | 05:57 AM
  #46
Originally Posted by JClaw
lol
The timing cover definately clears, I've got 3 1/4" from the intake manifold gasket to the hood on the front and about 4 1/4" on the rear by the firewall.
I'm making the intake to clear the hood, definately a must there.
allen
Old 03-07-2006 | 06:00 AM
  #47
It's actually 1 1/2" tubing ripped in half and taped together for mock up, will be TIG welded of course. Got a Miller Syncrowave last week, muuaahhhaahhaaha, /evil laugh.
allen
Old 03-07-2006 | 07:03 AM
  #48
virgilio7's Avatar
i guess you can get an already made plenum.
http://www.rossmachineracing.com/uni_intakeparts.html
Old 03-07-2006 | 11:11 AM
  #49
UK-nissan's Avatar
Two issues I see, the extra wasted volume below the mouth of the trumpets will increase lag and the extra unevenness in the top of the cover will increase turbulence and reduce the flow.
Mike
Old 03-07-2006 | 11:38 AM
  #50
maxmale's Avatar
Originally Posted by SuperStasiu
I know what they do its just that a direct boost fed system seems like it would work alot better since its goes right through solid manifold to engine. This set up how ever all the boost goes to open space then get sucked in through the runners in my opinion that type of throttle body would be very effective on top of a blower. I think it wastes the boost and the full boost isnt utilized fully. Ok lets say you have a box with a tube out of it and you push air into the box the air coming out the tubehole is gonna be at lower pressure then if you would just push the pressure through the tube. I know the their is suction their but the forced air isnt going to each throttle body directly its just going into an open space. Also how do you know that that black box will hold an XX amount pressure also how do you know the throttle body thats farthest away from where the air is entering the space is getting the same amount of pressure as the one thats closest to it. Just cause they are top secret doesnt mean they are the greatest company ever.
i have to disagree with some of what you are stating. i actually see this setup as being a pretty efficent setup. if you think about it it almost ensures that all itb's will see the same air flow. i really don't think you are going to have unequal pressure in that little space. now that i really think about it it actually seems like a really good idea. it seems just like a normal itb setup operating in a pressurized enviroment.
Old 03-07-2006 | 11:46 AM
  #51
Jeff92se's Avatar
I'm needing a caw
Seems to work pretty well for BMW:
http://www.worldcarfans.com/photos.c...ml/country/gcf
Old 03-07-2006 | 01:11 PM
  #52
virgilio7's Avatar
crawford was building something for the z but was twin tbs. they close the idea cause only yield gains of about 10 hp. the individual throttle body idea is done by a company for about 6000 bucks.
Old 03-07-2006 | 01:43 PM
  #53
Mike
It's been discussed before that the trumpets will flow better if they are spaced up off of the floor of the intake manifold instead of flush w/ the bottom of it. It's also been discussed that a larger plenum will out perform a smaller one on a naturally aspirated VQ35 and proven by dyno tests of the ever popular plenum spacers. I've never tested either theory. I doubt an increase in lag like you mention would even be measurable in any case, much less perceptible on a street car.
I haven't built the top cover yet.
Having said all that - Who cares! I need an intake that clears the hood, clears the firewall, looks trick and gets this car back on the road!
allen
Old 03-08-2006 | 11:20 AM
  #54
aznsap's Avatar
how would an IM designed like this but without the individual throttle bodies be?
i mean, just the horns coming up into a box type of design.
Old 03-08-2006 | 11:46 AM
  #55
That's basically what I'm building, I think it will work great.
allen
Old 03-08-2006 | 01:49 PM
  #56
JClaw's Avatar
allen
How come Broaner had issues w/ clearing the stock hood? Is the S13 engine bay really that much smaller/shorter than the S14?
Old 03-08-2006 | 07:00 PM
  #57
Not sure, could be taller motor mounts, steeper hood angle, etc. I know the S14 has a wide long raised bump area in the center of the hood, hard to see in photos.
allen
Old 03-08-2006 | 08:58 PM
  #58
MaxGordon7's Avatar
wow i want your tool set
Old 03-08-2006 | 09:28 PM
  #59
Ninos_Maxima's Avatar
be the change u want2C
http://www.homemadeturbo.com/tech_projects/itb/
Old 03-08-2006 | 09:38 PM
  #60
any one ever try adapting one of these???
Old 03-09-2006 | 07:22 AM
  #61
vsamoylov
such horrible piping
Old 03-09-2006 | 07:42 AM
  #62
Nismo3112's Avatar
Custom User Title
That looks worse than Hal's kit...
Old 03-09-2006 | 12:03 PM
  #63
notnser's Avatar
Is this going to be on a boosted motor? A lot of runner length and plenum design is specific to the application. IM's on a boosted car are more forgiving in that they work well with a larger plenum and loose less area under the curve even when you use shorter runners. On an NA motor it is much more crucial to research runner length, plenum volume and taper as well.
Looks like a really cool project!
Old 03-09-2006 | 08:05 PM
  #64
virgilio7's Avatar
bad welding.
Old 03-09-2006 | 09:18 PM
  #65
SuperStasiu's Avatar
Are you talking to me im just makeing a suggestion relax man jeesus
Old 03-09-2006 | 09:23 PM
  #66
I see your point im just saying that for a FORCED induction set up. How the pressurized air is delivered to those throttle bodies. That the throttle bodies that are closer to the pipe where the pressurized air comes in will get more boost then then ones farther away. Im trying to disrespect anyone so dont get mad at me like dude above, lol just makeing an assumption
  #67
Jeff92se's Avatar
I'm needing a caw
It looks bad but it's not that bad. The beads are huge but even for the most part and least look like decent penatration of the metal. It's odd that they use straight pipe for the bends. When you MIG, the weld can look like that. But it's much easier to weld that way vs TIG.
It's ALOT of work to cut and weld so many pieces. Really a waste of time since ebay mandrel bends are cheap.
Old 03-09-2006 | 09:27 PM
  #68
Jeff92se's Avatar
I'm needing a caw
I'll say boost makes manifold design LESS prone to cylinder to cylinder variances. Because the whole thing is pressurized to the same psi.
Old 03-09-2006 | 09:36 PM
  #69
no boost. thats the only pic i could find that some what resembles the vq. OBTW according to the owner that taurus is running mid-hi 12's, these are the guys mods
TO4Eturbo 1.32 turbine with a split tangential housing and V-bad discharge, .70 compressor *forgot to add 1st time*
4 inch custom cat back exhaust
Ported and polished heads, 5 angle valve job and custom ground race cams
Quaife LSD
6 puck unsprung clutch
Remapped ecu, AFC, 50lb/hr injectors, walboro fuel pump
upgraded MAF (forget what size)
Old 03-10-2006 | 05:27 AM
  #70
notnser's Avatar
You'd be wrong on this point. As someone said above boosted application are LESS sensitive to IM taper for air distribution. Boosted cars typically like a large plenum period.
If this car is not boosted I am VERY curious to see how the before and after dyno sheet look.
Old 03-10-2006 | 06:22 AM
  #71
This car will be run NA for the short term at least. I'll have no "before" dyno to compare to since this will be the first time it's even been started up with this setup. However, we could probably compare it to an average of some stock VQ35DE dyno charts.
I'll dyno it once I get it drivable w/ the wideband then re dyno later when/if I turbocharge it. Honestly, after owning, building and driving several custom turbocharged cars, I'd just like a powerful torque-y NA car. Turbocharging just kills a little something on a street car that's hard to defiine, I think it has something to do w/ throttle response.
allen
Old 03-12-2006 | 05:55 PM
  #72
vipervadim's Avatar
I like Maximas
Wow all those mods and that Taurus can't clear 12's -- it's time for some serious weight reduction...
Old 04-24-2006 | 10:34 PM
  #73
Buck96's Avatar
Originally Posted by virgilio7
bad welding.
Hey Ma we're out a argon; Just use the Acetylene
Old 04-24-2006 | 10:46 PM
  #74
Buck96's Avatar
nice info now I want one!!! or something similar and less money
I like the Inline vs. the staggered
Originally Posted by 6spd_Hayes
sorry to bring this up from the dead but....... (also, sorry for the size)
Only $6090 from http://www.topsecretjpn.com/!!!
http://www.topsecretjpn.com/engine.shtml
Old 04-26-2006 | 08:51 AM
  #75
MaximaSE96's Avatar
Maxima Owner
skylien use ITBs fed from a common manifold...its seems to work pretty well for that motor
Old 04-26-2006 | 06:54 PM
  #76
stephenlc's Avatar
Its a straight six making it easier, and the engine bay also has the room to lay them horizontal.
Old 04-27-2006 | 09:28 PM
  #77
nissannx's Avatar
I wish topsecret would publish some dynos on that ITB setup, just so we could drool over it. Or even better, Iwish someone would make an ITB setup that doesnt cost 6 grand.
Old 04-30-2006 | 10:46 PM
  #78
Buck96's Avatar
This should get things flowin,
Stock Left, Nismo Right
The caption says "Notice bellmouthing around each inlet runner. #6 is not bell mouthed to help even out flow though the plenum. "
inside of the Nismo Z-tune RB26 IM
the Bell's are much smaller/shallower than I thought
Old 10-27-2006 | 02:01 PM
  #79
japmaxSE's Avatar
Go Get a Life!
So has their been any further development into this particular build?
Old 01-14-2007 | 12:11 PM
  #80
Broaner's Avatar
2060lbs and falling...
Reviving this one for more questions.
How is the Z33 IM working now Fred?
Did you ever go further with your second mock-up than the pics you took? I really like that idea and I think I might get crackin on it. If you don't plan to use them I'd be interested in buying those few parts you got made up already.
Questions to anyone are; for boost response is it still better to have a larger plenum or would a very small say, 3'ish liters be good in order to encourage the pressure to push into the cylinders more rapidly after the plate is cracked? Also, anyone have a good source for trumpets in steel?
litch
123
01-04-2024 07:01 PM
James92SE
142
01-02-2024 09:23 AM
Fbana41
08-29-2016 12:18 PM
hayne
10-05-2015 11:53 AM
dshinn
09-26-2015 08:07 PM
Quick Reply: Building a custom VQ35DE intake manifold
