Sponsored by:
Sponsored by: CARiD
Vacuum leak
Old Feb 9, 2006 | 01:33 PM
SonicDust187's Avatar
Vacuum leak
Hey guys, I have a small vacuum leak and know the general location of it. However, I can't seem to pin point it. Is there some kind of a die kit that I can use that would show me the location of the leak?
Old Feb 9, 2006 | 01:35 PM
Hoooper
where is the general location?
Old Feb 9, 2006 | 02:46 PM
Around the iacv and valve cover gasket.
Old Feb 9, 2006 | 06:10 PM
pmohr's Avatar
No more Maximas...
You can't really dye a vacuum leak since it's just negative pressure, not something like an oil leak where's there's actually liquid to dye.
For something like a positive pressure leak you can spray soapy water and watch to see where it bubbles up, but...not sure for vacuum.
Old Feb 9, 2006 | 06:35 PM
isnt the point of vacuum to suck thus I doubt any bubbles will form.
Old Feb 9, 2006 | 07:04 PM
pmohr's Avatar
No more Maximas...
That's why I said it was for positive pressure leakage, not vacuum.
Old Feb 9, 2006 | 07:36 PM
Hoooper
you can watch you engine suck in the soapy water, not suggested.
Old Feb 9, 2006 | 07:55 PM
So anyone who really knows how to find a leak? I am going to try some soapy water and pressurize the system without turning the motor.
Old Feb 9, 2006 | 08:55 PM
Hoooper
i would guess if you try the soapy method but take the brake booster line off the booster and stick an air hose in it it might bubble, just might take a little bit to build vacuum and only will if the engine is in the right place.
Old Feb 10, 2006 | 06:17 AM
I am going to get a mytivac (sp?) and use it to pressurize the system.
Old Feb 10, 2006 | 06:41 AM
i30krab's Avatar
Try spraying carb cleaner in the vicinity. Don't laugh, it will work!
Don't ask me what to look for, you'll know it when you see it!
Old Feb 10, 2006 | 07:49 AM
DandyMax's Avatar
3.5 in the works
Carb cleaner or TB cleaner etc. It does work, you'll hear the engine change as it sucks it in - voila you found the leak location.
Old Feb 10, 2006 | 10:32 AM
I did use it, thats how I know the general location, I just cant pinpoint it.
Old Feb 10, 2006 | 12:43 PM
i30krab's Avatar
Just keep spraying (make sure you work in a well ventillated area) you'll find it!!
Old Feb 10, 2006 | 01:25 PM
Yeah man, I am going to try and rent a mityvac and then spray soapy water around.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Mar 12, 2020 12:06 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
followthadollar
Sep 17, 2015 06:31 PM
