Sponsored by:
Sponsored by: CARiD
VQ35 Oil cooler
Old Feb 13, 2006 | 05:23 PM
JClaw's Avatar
VQ35 Oil cooler
What needs to be done in order to use the stock oil cooler that came with the 3.5 in my 95? I just took it off when I did the swap, so the oil filter is directly onto the block.
Old Feb 13, 2006 | 05:50 PM
Fred Allen Burge's Avatar
It just has coolant running through it. You could probably use the VQ35 thermostat housing to get the water feed since it has the 1/4" or so outlet there. Then you'd need to get the water back into the stream at some point. Make sure you tap it in the right place with respect to the direction of coolant flow though.
allen
Does that cooler just spin off like a filter? I want mine off.
allen
Old Feb 13, 2006 | 09:55 PM
eng92's Avatar
allen
No, you just unscrew the oil filter stud and the cooler comes off.
Old Feb 26, 2006 | 11:06 AM
96sleeper's Avatar
What is the coolant flow direction on the 3.5? On the oil cooler, one line comes from the back of the block, the other was a rubber line that is cut on my engine. The one from the back, is that input or output? If you used the 3.5 thermostat housing, that would be your other port if the direction was right. I am interested in this also.
Old Feb 26, 2006 | 03:01 PM
nismology's Avatar
The line from the back of the block is the input according to the 2k2 FSM.
Old Feb 26, 2006 | 03:26 PM
96sleeper's Avatar
Yeah, I just checked too. Instead of the 3.0 thermostat and housing, use the one from the 3.5 and run the line from the oil cooler to the nipple on the housing. That way you can keep the 3.5 oil cooler.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
