Sponsored by:
Sponsored by: CARiD
Dropped the VE off at the machine shop today....
Old Apr 29, 2006 | 07:22 PM
  #41
Matt93SE's Avatar
STFU n00b!
yeah, pretty much. I might do a turbo later just cause I can- mainly to get the piping done and working so that I can develop a kit... but it'll be built for n/a performance.
Old Apr 29, 2006 | 07:43 PM
  #42
gtr_rider's Avatar
192.168.1.1
hmm interesting.. btw, the BBK looks great mang..
Old Apr 29, 2006 | 08:24 PM
  #43
Matt93SE's Avatar
STFU n00b!
You mean the rust pile?
I have a new set of rotors I'll get put on there when I get it running.
Old Apr 29, 2006 | 08:48 PM
  #44
Kevlo911's Avatar
Kevlo for President
Can I use the old rotors
Old Apr 29, 2006 | 08:56 PM
  #45
Matt93SE's Avatar
STFU n00b!
you don't want them... they're cracked.. I was going to order new ones as soon as the track event was over.... then I blew the engine.
Old May 8, 2006 | 07:20 PM
  #46
Matt93SE's Avatar
STFU n00b!
Old May 8, 2006 | 07:41 PM
  #47
SR20DEN's Avatar
VQ Wizard
Holy bore spacing Battman! So what did you have it punched to? And how thick are those cyl. walls?
Old May 8, 2006 | 07:53 PM
  #48
Matt93SE's Avatar
STFU n00b!
just went to 87.5mm on them (stock is 87). it was either that or go with custom pistons at $1450 a set. I stuck with off-the-shelf JEs for a Z32 NA.. $700w/ rings instead.
Old May 8, 2006 | 09:06 PM
  #49
SR20DEN's Avatar
VQ Wizard
What was the feasibility of using KA, QR or NAPS-Z, 89mm pistons?
Old May 9, 2006 | 09:46 AM
  #50
Matt93SE's Avatar
STFU n00b!
These are NA Z pistons. 87.5mm
going any bigger is custom.. the other block I took them was going to require boring to 89mm and the numbers above were my quote for the pistons from JE.
As for using anything else, I was concerned with deck height and wrist pin spacing and etc. I knew these pistons would drop in without problems so I went with them. quick and easy way to safely up the compression.
Old May 9, 2006 | 09:49 AM
  #51
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Sounds like you're doing everything top-notch, very nice.
Why not SwainTech coat to help run the high compression?
Also, any pics of the block surface without the gasket on?
Old May 9, 2006 | 03:09 PM
  #52
Matt93SE's Avatar
STFU n00b!
basically, it's more time and money that I don't have. I could have gotten these coated from Polydyn since they're right up the street, but more money and more downtime than I felt like messing with. Plus with the forged pistons compared to the stock cast POS, I don't see it being a huge issue.
Old May 15, 2006 | 06:13 PM
  #53
-shock211-'s Avatar
This is very exciting Matt. Can't wait to know how she runs and what the dyno will reveal.
Old May 18, 2006 | 08:57 PM
  #54
Matt93SE's Avatar
STFU n00b!
Slowly but surely!
Old May 19, 2006 | 04:42 PM
  #55
-shock211-'s Avatar
ooh looks like a damn crate motor.
Old May 19, 2006 | 09:07 PM
  #56
Matt93SE's Avatar
STFU n00b!
another 8 hours of work and I have the cams, chains, lash adjusters, and rollers installed..
Old May 19, 2006 | 09:13 PM
  #57
chris'smax's Avatar
lookin good man, i think you may get your car running before i do
Old May 20, 2006 | 06:54 AM
  #58
Kevlo911's Avatar
Kevlo for President
It's so purdy...
Old May 20, 2006 | 08:43 AM
  #59
BigLou93SE's Avatar
Looks like fun! In for more updates down the road.
Old May 20, 2006 | 12:55 PM
  #60
505max94se's Avatar
Nice work Matt...I can't wait to see some dyno numbers
Old May 20, 2006 | 07:04 PM
  #61
Matt93SE's Avatar
STFU n00b!
All I've got left is manifolds, engine mounts, and a couple brackets!!
She'll be in the car tomorrow night!
Old May 20, 2006 | 08:15 PM
  #62
nismology's Avatar
Which break-in procedure/style do you plan on using?
Old May 20, 2006 | 08:25 PM
  #63
Matt93SE's Avatar
STFU n00b!
the 'fire it up on monday morning and drive it to work like your 45 min late' method.
Old May 21, 2006 | 12:01 AM
  #64
stephenlc's Avatar
go to lightspeed and get it dynoed, not SGP racing.
It does not matter. Just get that ***** running.
Old May 21, 2006 | 04:45 AM
  #65
-shock211-'s Avatar
question?
why do you have what looks to be 2 or 3 vg30de's laying around???
Old May 21, 2006 | 03:19 PM
  #66
Matt93SE's Avatar
STFU n00b!
Well.. it's in... sorta..
now let's just see if I can fab up an exhaust.
Old May 21, 2006 | 08:11 PM
  #67
Alex_V
uh, do I see a 300zx manifold on there? wth?
Glad your getting close to done! I cant wait to see it run. I know you've been waiting a while.
Fabbing an exaust? what do you have in mind for that?
~Alex
Old May 21, 2006 | 08:22 PM
  #68
98SEBlackMax's Avatar
Maxima.org Insomniac
Nice work Matt, I wonder what the dyno #s are gonna be.
It also looks like were both cutting it close for Maxus. I finally got the DEK fired up tonight, still got alot of other stuff to do but it should be on the road this week.
Old May 21, 2006 | 08:59 PM
  #69
Matt93SE's Avatar
STFU n00b!
finally gave up at 11pm.. 15 hours in the sun was enough for me... All I've got left is to get the axles, starter, battery, fluids, and a couple random gadgets installed and it'll be up and running. can easily tackle all that tomorrow after work..
I was hoping to have it running, but I spent 3 hours wandering around looking for the plates that go between the tranny and engine.. I never did find the very bottom one and just stuck a washer in there for spacing to keep everything in line. as long as I don't drive through any water until a new one gets here, I'll be fine.
Old May 22, 2006 | 07:25 PM
  #70
505max94se's Avatar
did you finish it yet? How does it run??
Old May 23, 2006 | 07:24 AM
  #71
Matt93SE's Avatar
STFU n00b!
I got it started last night, but it just sputters and dies. The engine itself runs smooth when it gets a good squirt of gas, but it won't idle worth ****. I'm assuming (HOPING!!!!) it's just bad gas in the tank. it's been sitting for almost a year now.
What sucks is that **** is FULL... I gotta find a way to dump 17 gallons of bad gas.
Old May 23, 2006 | 08:34 AM
  #72
Aaron92SE's Avatar
NWP Engineering.com
I don't know much about it, but isn't there some kind of gas restorer? Something you can poor in that will allow you to use gas that has been sitting for months at a time. I have no idea if it works or not.
Old May 23, 2006 | 08:38 AM
  #73
Jeff92se's Avatar
I'm needing a caw
When my max was totalled, it had JUST put 15 gal of super in. I just removed the seat, took out the fuel pump and used a hand pump to get it into 3 5 gal cans. Dad used it in his lawnmower!
Old May 23, 2006 | 09:10 AM
  #74
Matt93SE's Avatar
STFU n00b!
yup.. that's the plan is to just pump it out.
Aaron, there's products out there that will stabilize gas for storage and will supposedly 'restore' stale gas, but after I just dumped nearly $4000 in this engine, I'm not going to take a chance at damaging it to save $50 on a fresh tank!
Old May 23, 2006 | 01:15 PM
  #75
Aaron92SE's Avatar
NWP Engineering.com
Good point! I hope everything works out for ya. I'd love to hear your reviews after you get it running perfectly.
Old May 23, 2006 | 06:36 PM
  #76
Matt93SE's Avatar
STFU n00b!
AAAAAARRRRRGH!!
Fawking rear head gasket it leaking coolant everywhere!!
well you guys won't be seeing my Maxima at Maxus this year. too much work, not enough time to put it together.
Edit... worse than I thought...
1: 205psi
2: 202psi
3: 0psi
4: 177psi
5: 0psi
6. 197psi
Needless to say, the machine shop will be getting a few words from me if I tear this down and find out it's in the heads.....
Old May 23, 2006 | 08:11 PM
  #77
MaxGordon7's Avatar
ahhh bummer man.
Old May 23, 2006 | 08:21 PM
  #78
nismology's Avatar
AAAAAARRRRRGH!!
Why??
10 frijoles
Old May 23, 2006 | 08:54 PM
  #79
CandiMan's Avatar
Say Candyman 5 times
AAAAAARRRRRGH!!
Could this be the reason why it was sputtering? What's the likely hood of it having bad gas? Weren't you at the track the last time the car was running and wasn't that less than a year ago? I'm no chemical engineer but can't gasoline sit longer than a year for the most part without any problems.
I would have suggested to check your base time, but with the heads leaking water you have no choice but to re-check the base timing once you have replace your head gasket.
As I'm reading this post I see folks saying they can't wait to see dyno numbers, what are your expectations from this engine? Besides the port and polish heads and Z32 pistons what other mods have you installed? Larger valves, lighter retainers/keepers, change valve spring rate, gapless rings, polished journals?
Old May 23, 2006 | 09:23 PM
  #80
Matt93SE's Avatar
STFU n00b!
Mike, that's about all I did with it were the pistons and the head porting. There's almost zilch for room in the combustion chambers for larger valves, so I don't see it happening on this kind of budget. I'm investigating some springs and retainers, but was going to worry about that ex post facto on this engine... since it's all coming apart, I may take the time to do some more checking on it as well.
