Sponsored by:
Sponsored by: CARiD
VQ Powered S13 Video Compilation
Old Mar 5, 2006 | 06:45 PM
  #41
JClaw's Avatar
Originally Posted by Broaner
Also keep in mind that the coupes are lighter than the FB's.
Can't be all that much, right? I assume the difference is roughly 30 pounds or so?
Old Mar 5, 2006 | 08:00 PM
  #42
vsamoylov
piping is the easy part.
Old Mar 5, 2006 | 08:37 PM
  #43
aznsap's Avatar
freakin sick man. nice to see you making progress
Old Mar 6, 2006 | 09:59 AM
  #44
Broaner's Avatar
2060lbs and falling...
No the piping isn't the easiest. I understand how to fab piping. I plan on running an FMIC. The bay is designed for a four banger. When you cram a six in there and already have to cut into the firewall for the TB and the hood for basically the whole motor it becomes painfully clear that piping will be a significant project. To give an example of the tight clearances, I have less than 1/2 cm between the steering shaft and the left manifold.
JClaw, some speculate that the FB's are up to 100lbs heavier than the coupe. That is a huge chunk of glass on the hatch not to mention the struts, windsheild wiper motor and parts, etc. I prefer the looks and chassis benifits of the coupe any day.
Old Mar 6, 2006 | 06:01 PM
  #45
choray911's Avatar
The Crazy Azz Cracka
Thats pimp dude! Congrads on getting the car running. Who cares what the car looks like.....It has a 3 litre! Does the 240 cluster work, or are you using the maxima guages.
Choray
Old Mar 7, 2006 | 09:45 AM
  #46
Broaner's Avatar
Custom Gauges...
Check homepage. SPA Dual digitals, Autometer 5" in-dash tach going in shortly in the dash hood.
Old Mar 9, 2006 | 07:34 AM
  #47
Broaner's Avatar
Parts continuing to accumulate. Still need rotors, SS lines, 5 lug hubs and possibly adjustable RLCA's.
This may no longer be all motor so... mods feel free to move.
Old Mar 10, 2006 | 09:15 AM
  #48
Thaniel's Avatar
[QUOTE=Broaner]No the piping isn't the easiest. I understand how to fab piping. I plan on running an FMIC. The bay is designed for a four banger. When you cram a six in there and already have to cut into the firewall for the TB and the hood for basically the whole motor it becomes painfully clear that piping will be a significant project. To give an example of the tight clearances, I have less than 1/2 cm between the steering shaft and the left manifold.
[QUOTE]
Have you considered cutting and fipping the intake like I did on my engine? I believe I could mount a supercharger on mine without too much trouble. Depending on what room you have upfront it might work on yours as well.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
