Sponsored by:
Sponsored by: CARiD
3.5 swap and emissions
Old Mar 1, 2006 | 08:35 AM
Biggs_02's Avatar
hey guys, i'm shopping around for a 4th gen to put a 3.5 into. The problem is i'm not lookign to spend alot and the 95's are the cheapest. I know that 96 and up used the obd to test emissions and the 95 use that dyno machine thingy. Will i pass the emissions test if i put in a 3.5? Need to know this before i go out and buy a car. thanks!!!
Old Mar 13, 2006 | 07:25 AM
d00df00d's Avatar
Old enuf to pick his own gears
My knowledge is limited on this topic, but your best bet might be to get a 2002 VQ35 because that model uses the exhaust cams rather than EGR to control emissions, so you don't have to worry about having to lose EGR. Slap a good catalytic converter on that and you might be set.
Someone correct me if I'm wrong...
Old Mar 16, 2006 | 08:05 PM
vipervadim's Avatar
I like Maximas
buy a 96 max 5-speed, then do the 3.5L swap, passing the obd2 is alot simpler than passing the tailpipe breathalyzer.
Old Mar 23, 2006 | 01:18 PM
owais's Avatar
Tilley is in the process of doing a 3.5 swap on my 95 Maxima, I'm not due for inspection for another year. However, would there be a problem for emissions with 3.0 headers, budget ypipe and the rest is stock?
Old Mar 23, 2006 | 04:39 PM
Biggs_02's Avatar
from what i know, you should pass emission if you have the primary cat on there. You have to let the car warm up and it'll pass emissions.
Old Mar 26, 2006 | 10:39 AM
MaxBlack97's Avatar
Hey Ovias how much is he charging u 4 the swap? Whas the total price of the swap? Lemme know how it runs and if its worth it.
Old Mar 26, 2006 | 11:24 AM
jcy98maxse's Avatar
Turbo is too much fun!
With a OBDII you have to plug in the OBDII port but from what I heard if you have a CEL, its an auto fail. With out EGR, it trips on the CEL so ???
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
09maxshawn11
Sep 30, 2015 10:28 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
