Sponsored by:
Sponsored by: CARiD
VAFC-II setup template
Old Jun 8, 2006 | 01:07 AM
  #41
diymaximakid's Avatar
mines under the radio
Old Jun 8, 2006 | 06:41 AM
  #42
jmeister's Avatar
Originally Posted by aznsap
where have you 4th gen guys put these? i'm wondering where people install these. in the glove box? on the dash somewhere?
Take a look on page one of this thread
Old Jun 11, 2006 | 04:16 PM
  #43
aznsap's Avatar
so if you didn't cut and tap into the MAF wire, this would just serve as a fancy readout/gauge device, correct?
i'm thinking about installing mine but i decided to put my 00vi install off until later, so i don't plan to do any tuning yet, just get the vafc2 in.
Old Jun 11, 2006 | 06:17 PM
  #44
jmeister's Avatar
yep, you'll have an expensive digital tach & voltmeter
Old Jun 21, 2006 | 08:46 AM
  #45
SR20DEN's Avatar
VQ Wizard
Bump. For the search impaired.
Old Nov 5, 2006 | 07:22 PM
  #46
deadlydreamx's Avatar
you guys think i should get this if im planning on turboing my max? friend tells me its useless to put it on if im planning on turboing.
Old Nov 6, 2006 | 06:44 AM
  #47
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/forumdispla...aysprune=&f=53
Old Nov 6, 2006 | 07:26 AM
  #48
d00df00d's Avatar
Old enuf to pick his own gears
Don't listen to your friend any more.
Old Nov 7, 2006 | 12:30 AM
  #49
A33 VQ30DEK's Avatar
can someone tell me the difference between the V-AFC 2 and the S-AFC.. and which ones more beneficial to my 5th gen
Old Nov 7, 2006 | 12:41 AM
  #50
915Max's Avatar
http://forums.maxima.org/showthread.php?t=446133
Old Nov 7, 2006 | 06:21 AM
  #51
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=479566
http://forums.maxima.org/showthread.php?t=452178
http://forums.maxima.org/showthread.php?t=433879
Old Nov 7, 2006 | 06:39 AM
  #52
MDeezy's Avatar
Just need to job my memory. Is closed loop under 3K only? or if you full throttle at 2K will it become open loop?
I'm planning out my 24 points for the vafc2, and if closed loop isnt modified in any way, there wouldnt be any point for me to start my point at 2400. I had my points set as follow.
Lvt: 2400,2600,2800,3000,3200,3400,3600,3800,4000,4200, 4400,4600
Hvt:4800,5000,5200,5400,5600,5800,6000,6200,6400,6 600,6700,6800
Lvt -> Hvt: 4600
Hvt -> Lvt: 4700
Old Nov 7, 2006 | 07:00 AM
  #53
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...7&postcount=87
Old Nov 7, 2006 | 07:15 AM
  #54
MDeezy's Avatar
Lovely. Thanks
Old Nov 7, 2006 | 04:04 PM
  #55
steven88's Avatar
Need A Light?
Lvt -> Hvt: 4600
Hvt -> Lvt: 4700
http://forums.maxima.org/showpost.ph...3&postcount=91
check this out too...quoted by nismology
Old Nov 8, 2006 | 05:42 AM
  #56
MDeezy's Avatar
I think the FSM stated open and closed loop somewhere. . . must search.
Old Nov 8, 2006 | 09:15 PM
  #57
NmexMAX's Avatar
dot dot dot ...
I still think eng92's hard/factual data is better.
Old Nov 26, 2010 | 08:49 AM
  #58
jowo9's Avatar
Thread resurrection alert!
Hey Nmex, both of those links are not working above. Just to clarify, if I'm NOT doing larger injectors/MAF, should I just tune Wide thr. At 3000+ rpm and go up to redline in smaller increments? Is that where open loop starts even if you're full throttle before that?
Old Nov 26, 2010 | 10:31 AM
  #59
essential1's Avatar
My axles cry for mercy...
Correct.
If i'm not mistaken, your ECU will try to correct any changes below 3k rpm. But have fun above that.
Old Nov 27, 2010 | 12:34 PM
  #60
Mad-MAX_SE's Avatar
Still kickin'
Old thread, yes... But here's a shot of where you can mount the VAFC/SAFC on a 4th gen. The temp gauge is almost completely visible from the driver's vantage point - besides, if you can't see the needle, the car isn't warmed up enough
The stand will mount easily to the instrument trim. I relocated my hazard and defrost switch so i can do a 3 gauge setup below the vents on the center console in the not to distant future.
Old May 19, 2011 | 11:55 PM
  #61
CPBOYZ's Avatar
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
