Sponsored by:
Sponsored by: CARiD
timing graph
Old Mar 15, 2006 | 08:34 AM
virgilio7's Avatar
timing graph
I'm an altima owner and i was experiencing some timing problems. the cam install was not done right. one tooth off on the intake cam. anyways, i was looking forever on different sites for timing graphs or how the timing should be on wot. have not seen any showing how it should be.
Anybody knows what timing should look like? from 16 to 26? or from 22 to 30?
I did the ts flash and want to compare other cars timing and check if i can still run nitrous on my ride without causing any detonation or damage to my engine.
Old Mar 15, 2006 | 08:58 AM
DandyMax's Avatar
3.5 in the works
You have a VQ35 I take it? Here's some stock Maxima VQ35 #'s as a start...
http://forums.maxima.org/showthread.php?t=457652
EDIT: I missed it that you have a TS... it will be more advanced probably than the above cases
Old Mar 15, 2006 | 03:35 PM
Brushedpewter's Avatar
Doesn't the ts flash advance your timing???
If they did I wouldn't go higher than a 50 shot. Here is what I would of done.. If I was going to buy their reflash I would of only asked for their extended rev limiter and no top speed limiter. Then I would use the safc2 or vafc2 to get the right a/f. But you already know all this.
I'm probably wrong like I always am. What do I know about nitrous? nothing. It must of been dumb luck that I didn't blow my engine yet.
Old Mar 16, 2006 | 07:12 AM
virgilio7's Avatar
I have the technosquare flash and for some reason the send me the car with the exact a/f 12.9-13.1
I have the safc2 to fine tune and problably nitrous. BUT, I don't know if they really advanced the timing or the car actually pulls it back to stock. that is what i want to know
Old Mar 16, 2006 | 11:01 AM
why not call TS and ask them???
Old Mar 16, 2006 | 11:05 AM
virgilio7's Avatar
oh like they are going to say " yeah, we didn't advance your timing"
Old Mar 16, 2006 | 01:16 PM
I'm sure you got some 3.5 altima auto friends. Why not go to autozone and rent a odb2 tool and check your timing while driving. Then get into another 3.5 auto that doesn't have a TS ecu and see the timing on there while driving?
Old Mar 16, 2006 | 03:38 PM
virgilio7's Avatar
i have an obd2 reader. i did that already. looks like mine could be advanced a bit. but not all cars are the same so i want to know any others without advancing to check if mine is "really advanced"
Old Mar 16, 2006 | 03:53 PM
Did you call and ask TS if they can reflash your ecu with just the extended rev and no speed limit?
Old May 3, 2006 | 10:51 PM
mforrest100's Avatar
I believe this thread should help you:
http://forums.maxima.org/showthread.php?t=468488
Seems like the timing for your ECU should be in the 20 - 28 degrees range based on the graphs. The stock timing may be closer to 16 - 24 degree range.
Hope this helps.
Mike
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
