Sponsored by:
Sponsored by: CARiD
Question about plenum
Old Mar 20, 2006 | 07:31 AM
wperdigon's Avatar
Is there a spacer on the market for more horsepower? I was looking and I didn't find anything. I know that the plenum for the z works, what about the maxima?
William
Old Mar 20, 2006 | 07:46 AM
Kevlo911's Avatar
Kevlo for President
None for the maxima.
Old Mar 20, 2006 | 06:50 PM
vsamoylov
none for the maxima but for the 350z yes
Old Mar 20, 2006 | 07:01 PM
Nismo3112's Avatar
Custom User Title
Maybe it would be possible to make a spacer to go in btween the two halves of the 2k2 IM....
Old Mar 20, 2006 | 07:05 PM
vsamoylov
hood clearance would be a problem
Old Mar 20, 2006 | 07:25 PM
NmexMAX's Avatar
dot dot dot ...
The gains seen in the case of the Z33 spacer is because the front 2cyls are somewhat 'starved' for air. In the case of the A33B IM, this is not the case since they differ (clamshell vs tubular plenum)
Old Mar 20, 2006 | 08:34 PM
Nismo3112's Avatar
Custom User Title
How? It wouldn't be making the IM any taller...
Old Mar 20, 2006 | 09:57 PM
Hoooper
would make it taller, hence: spacer.
Old Mar 20, 2006 | 10:30 PM
NmexMAX's Avatar
dot dot dot ...
Depends on where the spacer would go.
The A33B/A34 IM has 3 different pieces....Upper collector, lower collector and intake manifold, which we typically refer to as the LIM.
Old Mar 21, 2006 | 05:16 AM
86maxima96's Avatar
I Broke OT
wasn't there some talk about a gasket that would absorb less heat and therefore allow cooler air to flow though the IM? seemed like it would make such a trivial difference that the part wasn't even made. the only IM mod i had heard about for the Max.
Old Mar 21, 2006 | 06:16 AM
NmexMAX's Avatar
dot dot dot ...
Yes, that would be a phenolic type spacer. The concept between the Z spacer and phenolic is not the same.
Old Mar 21, 2006 | 08:38 AM
Nismo3112's Avatar
Custom User Title
Finally, some intelligence in here.
I was talking about a spacer between the upper intake manifold and the "elbow". This would NOT make it taller.
Old Mar 21, 2006 | 02:05 PM
Hoooper
thats true. i was thinking about a spacer between upper and lower IM, which would make it taller. both right hmmm
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
