00VI swap question
Originally Posted by gtr_rider
Anything yet?
wow you REALLY did bend that bracket pretty far.. anyway to get a farther out picture, this is deciding if I need to buy that bracket from Stephen or not..
Just finished a DEK swap in a 4th gen, and we swapped the main harness for the IACV to use the 5G IACV and it idles fine, just stays near 1500. Will let you know if that is resolved.
Not as of yet, I believe the IACV adjusts based on the temperature of the antifreeze travelling through the throttle body/IACV(2000) during cold starts. If there isn't any fluid travelling through it ala bypassed it remains at a cold temp idle.
Bump for those trying to use the 5th gen IACV.
http://forums.maxima.org/showthread....highlight=IACV
Also my testament that it works on cold starts and with the AC on.
I've got a DE-K in my 4th gen with a PF TB and 4th gen IACV, and only had cold start issues after the install of the PF TB. If I'm reading this correctly, will the use of the 5th gen IACV correct the cold start issues associated with the PF TB?
I think the one he posted is also this one:
http://forums.maxima.org/4006477-post15.html
and
http://forums.maxima.org/4006484-post16.html
and
Would a V-Tec controller work?
yes like the vafc-ii would work just fine. I am currently using the vafc-ii and its functions well
what he said...
what he said...
I plan on bypassing the throttle body coolant on my 00VI swap....will that actually cause Cold Idle (1500rpm) all the time?
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
QueensMAX
Sep 15, 2015 04:14 AM
