Sponsored by:
Sponsored by: CARiD
igntion upgrade?
Old Apr 2, 2006 | 01:43 AM
99Maxxx's Avatar
igntion upgrade?
I was curious about something...as far as I know there's no way tp upgrade the factory setup due to the coil-on-plug system. My question is this...MSD does make a setup that can run up to 4 coils so could you modify the system using 3 coils designed for a GM 3800? If so, does the DIS-4 system require that you use the control module to run properly or does it just need the coil setup? This is a complicated and seemingly pointless question I know, but I'm still wondering.
Old Apr 2, 2006 | 09:21 AM
Kevlo911's Avatar
Kevlo for President
Splitfire makes upgraded coils for us. They should help, but not many people have dished out the money for them.
Old Apr 2, 2006 | 09:36 AM
Brushedpewter's Avatar
You only need to upgrade this if you're running really high power. Doing this on an NA car with bolt ons will almost yield nothing.
Old Apr 3, 2006 | 09:39 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Kenne-Bell Boost-A-Spark....
Old Apr 3, 2006 | 02:16 PM
Tim96I30t's Avatar
I thought about splitfire but then I found out they are 500-600 a set...don't think the msd would work
Old Apr 5, 2006 | 03:30 PM
99Maxxx's Avatar
Well, I'm sure that the stock ignition would be enough to run the 100 wet shot that I plan on adding this summer. However, I know that with the added cylinder pressures of nitrous, boost, etc. that any help that can be given to the ignition system the better and the multiple spark given by the MSD seems to be the wy to go. I'm just not sure if it can/has been done before. Any clue on whether the DIS4 system that would be used to Grand Prix's and whatnot uses the factory ignition control module or no? Because if not, that would be the only way I know of to do it without major wiring issues
Old Apr 5, 2006 | 04:32 PM
IceY2K1's Avatar
For $250 or less and proven, why????
http://www.kennebell.net/accessories...oostaspark.htm
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Dasmith
Sep 23, 2015 08:28 PM
