Sponsored by:
Sponsored by: CARiD
Using heads from other VQ35s
Old Apr 2, 2006 | 02:51 PM
sciff5's Avatar
Hey guys this may be a stupid question but if you have a VQ35 is there any reason why you wouldent be able to use freer flowing heads made for the G35 or 350z if you also use the 350z plenum?
Old Apr 2, 2006 | 03:04 PM
Glude's Avatar
I believe anyone with a 3.5 could use the heads from the 6th gen which people say are the heads from the pathfinder.
Old Apr 2, 2006 | 03:10 PM
SR20DEN's Avatar
VQ Wizard
You assume they are.
Old Apr 2, 2006 | 03:41 PM
Nismo3112's Avatar
Custom User Title
You could.. But why would you want to?
Same part numbers.
5.5 gen VQ35's, 350Z = same part numbers
6 gen = different part number
R50 PF VQ35 = different part numbers from the two above.
Old Apr 2, 2006 | 07:25 PM
vsamoylov
nismo heads
Old Apr 2, 2006 | 07:41 PM
Glude's Avatar
Originally Posted by vsamoylov
nismo heads
Extremely expensive if I remember correctly, right??
Old Apr 2, 2006 | 08:04 PM
Nismo3112's Avatar
Custom User Title
Anything Nismo = expensive lol.
Old Oct 19, 2007 | 10:15 AM
coinage's Avatar
sorry to bring up an old thread but what are the difference between the 5.5gen and the 6th gen heads? i read something about softer valve springs... would it be a good idea to swap in the springs from my 02 onto the newer heads if i want to cam the motor?
Matt
Old Oct 19, 2007 | 10:25 AM
NmexMAX's Avatar
dot dot dot ...
If I was going to toss cams in, I would use JWT VS's.
Old Oct 19, 2007 | 10:39 AM
coinage's Avatar
any other differences?
Old Oct 19, 2007 | 10:45 AM
NmexMAX's Avatar
dot dot dot ...
The only difference in A34 heads vs A33B heads is the VS's. No other differences exist. So, having said that, flow characteristics are not affected by that small difference.
Old Oct 19, 2007 | 11:08 AM
coinage's Avatar
cool... thanks that all i needed to know
Old Oct 19, 2007 | 11:13 AM
DandyMax's Avatar
3.5 in the works
Even better, I'd use double shimmed HR springs, and HR retainers. And way cheaper too.
Wait, I already did that... with a heavier DEK valvetrain that still revs to 8k+ no problem.
Old Oct 19, 2007 | 11:16 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by DandyMax
I'd use double shimmed HR springs, and HR retainers. Wait, I already did...
. . . . I was hoping you’d chime in with that because I didn’t feel like searching high and low for that post. But yes, my actual point was ‘I would not use A34 springs’.
Old Oct 19, 2007 | 11:37 AM
nismology's Avatar
Any particular advantage to using the HR/Revup retainers for his purposes? Just looks like they have a bit more mass on them according to SR20's images.
Old Oct 19, 2007 | 12:16 PM
DandyMax's Avatar
3.5 in the works
They do look a little stronger. And they're dirt cheap.
I don't recall off the top of my head what the HR retainer weight was (I can check my notes at home later), but I *think* they might have been about .75-1 gram lighter than the non-revup, and they're definitely several grams lighter than the DE/DEK.
Old Oct 19, 2007 | 02:11 PM
KRRZ350's Avatar
& IINM they're NOT titanium FTW, or am I wrong here?
Old Oct 19, 2007 | 02:51 PM
nismology's Avatar
Figured that much. I've had DaveB price 'em out for me. Was just wondering if it would be worth the expense (albeit small) for his setup is all.
Please do check again because that would be nuts if they were actually lighter. Looked like they had more meat on them.
Old Oct 19, 2007 | 06:01 PM
DandyMax's Avatar
3.5 in the works
If you're in there changing springs anyways...
Well I checked and I was mistaken (darn lousy memory). They're about the same, or slightly heavier by a few tenths of a gram, which does make sense.
Old Oct 19, 2007 | 09:54 PM
sciff5's Avatar
So even if we used the HR Valve springs in our Vq35s and were able to raise the rev limit to 7500 or so, would the heads/ intake be able to support power at those levels?
mclasser
22
Nov 12, 2020 01:58 PM
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
