Sponsored by:
Sponsored by: CARiD
Blown coils in a VQ35 swap.
Old Apr 9, 2006 | 05:06 AM
MarcL's Avatar
Hey,
Tried to start my VQ35 with the VQ30 ecu yesterday (for the first time). Had one of the plugs out to make sure I was getting spark, and all looked good.
Put the plug back in, and spent some time trying to start it.
All of a sudden, smoke started comming out of all 6 coil-packs.
Any ideas on what went wrong? I though maybe I lost ground to the ECU (the coil packs are not grounded in the same place), or maybe my battery was running low and put the ECU in some funky state?
Also, anyone have any VQ35 coill packs they want to sell?
Thanks,
Marc
Old Apr 9, 2006 | 07:46 AM
tavarish's Avatar
fwd gone rwd cr00
sounds like a wiring problem, it's not likely all 6 would be busted.
Old Apr 9, 2006 | 08:27 AM
MarcL's Avatar
The smoke comming from all 6 coils is a good indicator they are toast... Not to mention, the plastic on all of them are melted now.
Today, I cranked the engine over with an ocilliscope hooked to the coil signal. Looks to be pulsing as expected when I crank the car over. The ECU seems to be OK.. I also have 12V and GND at each coil.
I am pretty sure I need 6 new coils, but what is bothering me is I don't understand why they burned up.
Old Apr 9, 2006 | 09:37 AM
diymaximakid's Avatar
how did you test to see if your getting spark?
Old Apr 9, 2006 | 10:21 AM
MarcL's Avatar
Hooked up a coil with a plug out of the engine, and looked for spark... It worked nice until the coils burned up.
Old Apr 9, 2006 | 10:32 AM
oh maybe 2 much current in the signal wire?
Old Apr 10, 2006 | 08:22 AM
MarcL's Avatar
Ugh, replacement is not too easy either.. rockauto.com has them listed for about $50 each. Called a few junkards, they want the number off of my old coils?! They claim there are 3 style coils for a VQ35 out of a Maxima.
Old Apr 10, 2006 | 09:52 AM
Nismo3112's Avatar
Custom User Title
Did you ground the tip of the plug?
Old Apr 10, 2006 | 11:02 AM
so it has to be the tip?
Old Apr 10, 2006 | 11:24 AM
Nismo3112's Avatar
Custom User Title
Well the tip is part of the outer part of the plug, so ground the metal part.
I wonder though if that has anything to do with the coils going bad
Old Apr 10, 2006 | 11:58 AM
MarcL's Avatar
Yes, the threads on the plug were grounded and I got spark..
I lost the coils after I re-installed the one plug I had out.
Old Apr 10, 2006 | 12:23 PM
tavarish's Avatar
fwd gone rwd cr00
if you want, i can swing by this week and check it out.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
mclasser
22
Nov 12, 2020 01:58 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
