Sponsored by:
Sponsored by: CARiD
3.5 crank pulley removal
Old Apr 10, 2006 | 05:57 AM
greg hazlett's Avatar
Guys,
Have an UD pulley to install on an 06 max and cannot get the stock crank pulley bolt out and have read conflicting reports on whether it is right hand/left hand thread and what the trick is do getting this bolt out.
Greg
Old Apr 10, 2006 | 06:25 AM
95BLKMAX's Avatar
How are u trying to get it off? Assuming that the bolt on the 3.5 goes in the same way as the 3.0(which I dont see why it wouldnt), the easiest way is the breaker bar/ starter trick. In case ur not familiar with it....
-Disconnect the CPS just under the pulley
-Lookin at the pulley straight on, place a socketover the bolt on a long breaker bar, and have the end of the bar resting against the ground towards the front of the car
-Have some one just crank the motor (a bleep not even a second long is usually long enough)
-The crank turns to the left, and by not allowing the bolt to move due to the breaker bar being wedged against the ground, it'll loosen itself.
Good luck
Old Apr 10, 2006 | 07:33 AM
I was using 2 different air guns and then myself and a friend, combined weight of 500lbs pushing on a breaker bar with a pry bar wedged in the crank pulley and after 3 hours we gave up. Which was is the bolt to loosen-traditional or left hand thread?
Old Apr 10, 2006 | 07:40 AM
nismology's Avatar
Lefty loosey, like almost every other fastener in your car.
Old Apr 10, 2006 | 08:00 AM
Understand but in reading the threads they said the crank is left hand thread meaning opposite on loosening the bolt....
Old Apr 10, 2006 | 08:30 AM
nismology's Avatar
I can guarantee you that you need to turn the bolt counterclockwise to loosen it.
Old Apr 10, 2006 | 02:45 PM
Stopped at the Nissan dealer and the shop sup said it is a right hand thread.
I guess the starter blip method will get a try!
Old Apr 10, 2006 | 04:08 PM
Nismo3112's Avatar
Custom User Title
I'm suprised an air gun didn't loosen it. You probably didnt have enough psi in the air supply.
Old Apr 10, 2006 | 05:25 PM
I was using a sears vertical cpmpressor, think it is 5.5 hp with 125 psi. Not sure what shop air is rated at...
Old Apr 11, 2006 | 08:06 AM
Biggs_02's Avatar
i used a 250lb impact gun. Held it for couple of seconds and it came right off. and your turn it to the left to get it off.
Old Apr 11, 2006 | 09:49 AM
See what I mean about no one has a concrete answer? The nissan dealer said it was normal right hand thread meaning the traditional loosen applies but if I read your post correctly I have to aim toward the back of the car to loosen......
Old Apr 11, 2006 | 09:53 AM
SR20DEN's Avatar
VQ Wizard
Holy crap dude. This question has been answered CORRECTLY already. You turn the bolt COUNTER CLOCKWISE to remove it from the crank shaft.
The post you just made says this exact same thing.
That is what they mean by 'right hand thread'. You turn it to the right to tighten it. Righty-tighty Lefty-Loosey.
If it were left hand thread it you would turn it to the left, or counter clockwise to tighten it.
Old Apr 11, 2006 | 10:11 AM
nismology's Avatar
Old Apr 11, 2006 | 11:52 AM
Sorry! With all the talk being left hand/right hand thread I mixed them up in my post. Thanks, I think....
Old Apr 11, 2006 | 06:43 PM
I finally got it off, the starter bump did not work, I used a chain with a J hook on it attatched to a strap attatched to an Excursion to hold the pulley in place and using a breaker bar the bolt finally came off. It is right hand thread and is loosened the normal way, thanks for all the advice and help.
Old Apr 11, 2006 | 06:46 PM
SR20DEN's Avatar
VQ Wizard
I am glad you finally got the thing off. But it shouldn't have been that difficult to remove in the first place. It sounds like the people in Smyrna were misbehaving when they built your car.
Old Apr 12, 2006 | 03:36 AM
It did not help that for 3 hours I tightened it! Nothing like creative engineering to complete a task....
SEmy2K2go's Avatar
Go BUCKS!!!
The initial tightening it with the impact most definately made his a more difficult install than it needed to be.
Old Apr 12, 2006 | 05:27 AM
Concur. Hopefully someone else will learn from my mistakes.
mvm062
Nov 30, 2020 09:00 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
conansriver
Sep 11, 2015 10:26 AM
