VQ35 RevUp cams in non-Rev heads w/o machining
Old 05-19-2006, 09:50 AM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
I've been talking with a member ALong over on my350Z.com about what modifications he had done to make this work. He initially said that you must machine a bit off the exhaust cam end, which made sense to me since there wouldn't be the thick exhaust VTC sprocket. However, he just reported no machining was needed and everything bolted in. All that was needed was to source some longer "exhaust cam bolts" he located at some fastener store.
Just a reminder, but these cams have 10.5mm lift and 248-degrees duration on both intake/exhaust. The only question is how they perform in a NA application without VTC control, since they have -4degrees overlap. They sound perfect for FI applications though.
I believe DAVEB said all 4-cams were less then $500, but don't hold me to it.
IceY2K1 is offline
Old 05-19-2006, 09:43 PM
VQ Wizard
SR20DEN's Avatar
I'm not suprized.
I wonder how long it's going to take for those people to realize they can use aftermarket cams in their revup engines with minor dremel work.
That price doesn't sound correct though.
SR20DEN is offline
Old 05-20-2006, 04:55 AM
MardiGrasMax's Avatar
$500!!!!!!!!!!!!!!!!!!
MardiGrasMax is offline
Old 05-20-2006, 05:06 AM
eng92's Avatar
They are about $141/each over on pinnaclenissan.com
eng92 is offline
Old 05-20-2006, 12:36 PM
DAVEB's Avatar
They've gone up a little- I could do $135 a cam now, but Nissan has been changing (raising) prices on the 1st of each month lately.
DAVEB is offline
Old 05-20-2006, 04:20 PM
Turbo is too much fun!
jcy98maxse's Avatar
Will this work only for 3.5 swappers or can someone make this work for a DE or DEK?
What is involved in the dremeling?
jcy98maxse is offline
Old 05-21-2006, 04:13 AM
Father of the 00 VI
krismax's Avatar
i dont see how its worth the effort for 600-700 you can buy aftermarket cams
krismax is offline
Old 05-21-2006, 05:24 AM
What aftermarket cams can you get for 600-700? I thought they were all like $1100-1300
Old 05-21-2006, 05:36 AM
VQ Wizard
SR20DEN's Avatar
The Ebay (JWT knockoff) cams.
And the classifieds on my350z.com. It seems that every week someone else has a set of Nismo cams to sell because they were told they can't be installed in their '06 Z.
SR20DEN is offline
mclasser
22
11-12-2020 01:58 PM
worldwiderecognized
09-30-2015 01:16 PM
jaydot901
09-29-2015 01:18 PM
Quick Reply: VQ35 RevUp cams in non-Rev heads w/o machining
