Sponsored by:
Sponsored by: CARiD
Technosquare ECU upgrade
Old May 30, 2006 | 06:53 PM
vsamoylov
I have a couple of questions abotu the ecu upgrade that technosquare offers for the 5.5 gen max. I know sr20 has a upgraded ecu so maybe he can chime in as well. I just got a spare ecu that i want to send out and have it reflashed. Now should we use some info from the 350z and have it put into the maxima ecu? also can the yget rid of the immobilizer? thanks for the help.
Old May 30, 2006 | 07:18 PM
Kevlo911's Avatar
Kevlo for President
You should try to get a 350z tune so you have the better vtc and better over all maps.
Old May 30, 2006 | 08:36 PM
NmexMAX's Avatar
dot dot dot ...
Seems as if the A34 ECU is easier upgraded using Z33 maps. It takes quite a bit of explaining to TS that you want the Z33 maps on the A33B ECU.
They try and feed you quite a bit of crap, but with enough nagging they should be able to use the Z33 VTC etc.
Originally Posted by Sales Dep. Technosquare, Inc.
We use same VTC map for stock camshaft application for all VQ35 application, so you have same upgraded map as what we send out for 350Z. For some reason, you are thinking Maxima ECU and 350Z ECU works same way, but it is not. Especially you got 2003 ECU which even hardware configuration is different. Thus, mapping is very different because of sensor difference (ex. MAF). So, we can't simply copy 350Z map into Maxima ECU, because coefficient
is different. We maximize the Ignition timing based on the Maxima map, but end result is very similar to 350Z's timing in degree, but the number on the map is very different. We can't make the ignition timing identical to 350Z, because your VQ is side mounted, so the cylinder bank in rear gets detonation due to the cooling efficiency.
Cam timing map is based on the Z and actually improved even more for higher rpm part. Unless you are using different cam shafts, that map is as good as youo can get for stock cams.
Since the Maxima has side mount VQ with different configuration of intake, simply installing Z maps doesn't work. We optimized the Z map for side mount VQ and that is what you got in it. The program is based on the Maxiam, but maps are even more radical then Z33. By the way, why did you change intake plenum to 350Z one? Didn't you loose more bottom end torque than what you gained at higher rpm? 350Z intake plenum is designed under a lot of compromises.
Old May 31, 2006 | 11:35 AM
vsamoylov
i also asked them about using the maps from the 350z and they gave me the exactly same answer. and i been looking at the fsm for both the 350z and the maxima because i wanted to use the 350z ecu but its alot easier for the 6th gen guys to use the early versions of the g35 ecu then for 5.5 gen maximas to use the 350z ecu.
any other inputs or advice?
Old May 31, 2006 | 11:51 AM
Kevlo911's Avatar
Kevlo for President
I thought the EARLY G35's had the 5.5gen connector. 6th gens have the current Z connector...
Old May 31, 2006 | 12:37 PM
vsamoylov
i have no clue about that. anybody know?
Old May 31, 2006 | 12:58 PM
eng92's Avatar
per the 03 G35 sedan FSM:
Early models with A/T were "TYPE 1" and use the A33B connector.
All M/T and later A/T models were "TYPE 2" and use the Z33 connector.
You would need to verify if it is the same for the coupe.
Old May 31, 2006 | 01:17 PM
vsamoylov
thanks for that info
But i dont have an A/T so according to that info I cannot use the g35 ecu because the M/T models use the z33 connector. I havent looked into the coupe but most likely its the same.
Old May 31, 2006 | 01:31 PM
eng92's Avatar
If you are feeling ambitious, just make yourself up a patch harness to go from an A33B male connector to a Z33 female connector.
If you are feeling ambitious and daring, pull all your ecm connector terminals out and plug them into a Z33 connector.
If I do not get anywhere with the EU controlling my VTCs without codes, I may consider the second option.
Old May 31, 2006 | 10:09 PM
maxS
unfortunatly, the difference is not in the connectors only...
Old Jun 1, 2006 | 04:46 AM
eng92's Avatar
Is it the CAN system that bothers you?
You cannot be a true pioneer without some imagination. If you want PnP, buy a Honduh.
Old Jun 1, 2006 | 09:41 PM
maxS
yeah, i've gone through the diagrams, and it looks doable, but involves more work then i feel i want to do.
Old Jun 3, 2006 | 08:50 AM
mdemonte's Avatar
HOw about using the UTEC?
Link;
http://www.turboxs.com/products.htm
Old Jun 3, 2006 | 10:02 AM
Starchild2K2SE's Avatar
Well I called and spoke to one of the techs at technosquare last week and they told me this following information which could be very useful to some. I asked them if they still tune the air/fuel ratio and they said no, I guess this is because various people have various parts, and they see it would be harder to program one specific tune, onto many peoples ecu. They told me what they wanted me to do is dyno my car, with the a/f readout, and they told me they will tune my ecu based on the dyno, which I figured is a great idea. So now, they can tune my car better with my a/f then just giving me one of their base setups. The only thing about that tho, is when I send the ecu I want a 7200rpm limiter, and my dyno will only read to 6600rpm. I guess the remaining rpms will just be untuned. But I just wanted to share some of this information for the people that didn't know about this. And I know it takes time, and I know they probably won't get the perfect a/f ratio for my all motor car, I can make a few adjustments on the dyno when I go after, and tune with a vafc-II.
Old Jun 3, 2006 | 02:08 PM
Mass_Media's Avatar
Mass_Media™
Im new to the whole tunning your engine thing. But from what i have read in the sc/tc forums wouldn't it be easier just using Greddy EU then sending in your ecu or trying to make it work with the z33.
Old Jun 3, 2006 | 08:27 PM
NmexMAX's Avatar
dot dot dot ...
Go to a different dyno becauae lean at that RPM =
... Do you mean tune A/F etc with the EU, and then sending the ECU to get Z33 VTC maps and ?
Old Jun 5, 2006 | 02:36 PM
konak85's Avatar
Side question: I haven't been following ECU's lately. Did Technosquare figure out how to extend fuel cut on 5 speed 4thgen ecu's?
Old Jun 5, 2006 | 05:31 PM
NmexMAX's Avatar
dot dot dot ...
They don't do A32 ECU's anymore.
Old Jun 5, 2006 | 08:30 PM
konak85's Avatar
so only options are JWT or EU?
Old Jun 6, 2006 | 03:47 PM
NmexMAX's Avatar
dot dot dot ...
Among others.
Old Jun 11, 2006 | 10:02 AM
Snolife's Avatar
What we have here is a failure to communicate
Ok, got some dumb questions here, partly because I am still learning some of this stuff. Here are copies of my dyno's that I did a week ago. All I have is a full Cattman cattback along with the FastCat and the Cattman Y-Pipe.
Some mentioned to me that my AFR is all over the place, still learning what that might mean, please excuse the ignorance, but will getting the Technosquare ECU upgrade be beneficial to me in term of numbers, etc.? Since they are right around the corner from me, I presume, I can get in and out in a timely fashion if it is worth it for me to spend the $495. Thanks for any inpute.
Old Jun 11, 2006 | 04:50 PM
lividian1's Avatar
Dude you are all over the place you should try running like a 13.1AFR and you have one hell of a dip at 4000 RPMs. What mods do you have on your car? Do you have a SAFCII to correct it.
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
