Sponsored by:
Sponsored by: CARiD
00vi clutch issues?
Old Jun 1, 2006 | 07:08 PM
MorpheusZero's Avatar
00vi clutch issues?
How will the stock 4th gen clutch hold up to the 00vi? I was forced to abuse it less than 300 miles after it was put in (45degree incline, VERY confined space, had to back up) and it won't even come close to chirping second, it's pretty mushy/glazed. I don't powershift. Will my clutch be roasted by the added toark of an 00vi?
Old Jun 1, 2006 | 07:30 PM
Kevlo911's Avatar
Kevlo for President
No it won't. 00vi doesn't add more power than the stock clutch can handle.
Old Jun 1, 2006 | 08:52 PM
Well a clutch handles torque, not power.... but thanks, it opens some options to me... a little.
Old Jun 1, 2006 | 09:39 PM
steven88's Avatar
Need A Light?
If you add a large amount of hp...then you have to upgrade the clutch system...when I mean large amount, probably 70+whp
Old Jun 1, 2006 | 10:21 PM
....you're missing the point.
A clutch will hold a certain amount of torque. Not power. If you add 70whp but somehow keep the peak torque the same, the clutch will hold it no problem.
...Anyway.
Old Jun 2, 2006 | 05:54 AM
Kevlo911's Avatar
Kevlo for President
Umm okay
00vi doesnt add that much more TQ.. Do some research, you have alot to learn.
Old Jun 2, 2006 | 06:32 AM
It doesn't add all that much, but the 5th gen clutch isn't stronger for nothing. Since my 4th gen is already worn down I was unsure.
And I'm not the one being corrected, bud.
Old Jun 2, 2006 | 07:21 AM
95BLKMAX's Avatar
Well the 5th gen clutch isnt stronger much for the fact that the DEK makes that much more ubber TORQUE than the DE, but for the fact that it has to move the weight of a heavier car on the transmission side. If you have a heavier car, chances are, you will need a stronger clutch to have the same longevity as a clutch on a lighter car (5th gen vs 4th gen). Someone correct me if Im wrong on this..
Old Jun 2, 2006 | 08:42 AM
SDot82's Avatar
Well with out power you cannot have torque so like kevlo said do some research.
Old Jun 2, 2006 | 09:27 AM
eng92's Avatar
Actually you have it backwards. You can have a "gazillion" ft-lbs of torque at 0 rpm and that equals 0 hp. To have power, useful work needs to be performed (ie. you need X ft-lbs of torque at Y rpm where X,Y cannot be 0).
Old Jun 2, 2006 | 03:32 PM
right. Thanks for the education.
Just so you know (here's a basic physics lesson), torque is the actual rotational force that the engine produces. Power is sourced from torque and depends on it--power = torque * rotational speed.
Old Jun 2, 2006 | 03:34 PM
Good point. I think it's probably a combination of the two.
Old Jun 2, 2006 | 04:29 PM
SDot82's Avatar
I keep forgetting that torque is a force applied at the moment of an object. But how can you have a lot of torque at 0 rpms if torques is a force on an object causing it to rotate (incase of a car rpms)?
Old Jun 2, 2006 | 06:20 PM
eng92's Avatar
The 0 rpm case does not really have any application in terms of cars. It was just meant to show that you can have applied torque without developing any power.
Old Jun 2, 2006 | 06:32 PM
Imagine an ox pushing a 100 foot pole hooked up to a vertical rod coming out of the ground. The ox can probably deliver about 500lbs of force (about 10000N) to the end of the pole, making the amount of torque around the pole about 50000ftlbs. But it takes him about 5 minutes to fully walk around the pole. So that would be 50K ftlbs @ .2rpm. Say if the pole wouldn't budge, wouldn't turn at ALL even from 50K ftlbs of torque. So the torque is still being applied at 0rpm. It's like you pushing on the wall, you're still delivering xxlbs of force but the wall's not going anywhere--xxlbs @ 0mph.
But no, in internal combustion engines torque at 0rpm will be irrelevant and nonexistant. With elecrtic motors, however, it's a different story...
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
