00VI Swap Photo Gallery
I just finished my 00VI swap over the weekend. I used the 4th gen lower, which required considerable modifying. Some have used two of the center bolt holes in the lower, but the ports are off 3/16" if you do that. I filled, drilled, and re-tapped all four center bolts for a direct port match. I would not recommend this to the novice without machining tools. I probably spent at least 4-6 hours alone on the lower.
The 5th gen lower is obviously made for the upper, so there is no modifying involved. The 4th gen fuel rail and injectors will not work, so you have to use the 5th gen fuel rail, injectors, and fuel pressure regulator. The injectors are different and so is the fuel pressure, so you have to mess with fine tuning the a/f ratio with VAFC or similar piggy back system. It's just a matter of which direction you want to go and how much money you want to spend. I personally would do the 5th gen intake manifolds, injectors, fuel rail, throttle body and tune them with a VAFCII if I had the money. And don't forget the rear valve cover and coil packs. You have to do some grinding on the coild bosses and redo the PCV valve is you try to use the 4th gen stuff.
I can say for sure that it is a worthwile mod as far as performance goes. Worth every bit of the $300 I have invested.
I was thinking of using 5th gen Tb and just leaving the iacv plate with water lines and just capping it off where the iacv sensor goes has anyone did this and how well did it work.
Depending on what year of car you have, you will likely have trouble fitting the TB with IACV, as there are coolant pumps and other devices just below the TB. The TB plate is very easy to make and the coolant lines are very easy to loop. I don't know any advantage of leaving the IACV there, if not functional. Just my .02.
I made my plate and still had fitment trouble with the primary vacuum spyder. I had to bend the bracket and re-route a couple vacuum lines to make room for the TB.
Even then, the lower part that screws to the bottom of the TB extends down approx. 2.5". I had to bend some stuff around with the IACV completely removed and blocked off. Remember, the 00VI has a different angle and sits lower in the back than the USIM. I didn't know how everything was going to fit until I took the USIM off and test fit the 00VI. Only then will you know if it will work.
Everytime I read a thread on doing this swap I rethink myself. Seems like so much more work then I expect everytime I read....if I havnt done too much engine work do you recommend doing the 00vi swap?
I have plenty of experience working on cars and it was a difficult swap. I think anyone could do it, as long as they take the time and do the research. I spent months learning everything that was out there and still learned a ton during the swap. It is well worth the effort.
Can someone help me? I just did a dek swap this weekend but i'm not sure where to hook up the boost sensor? Also I'm having alot of trouble starting the motor i need to keep pressing the gas pedal to start if anyone can help please let me know?
You're going to have to tell us a little more about the swap. Are you using the 4th gen or 5th gen TB, IACV, TPS, etc. I doubt anyone could even guess at this point without knowing more about the swap.
I read that the 4th gen tb has some issues after doing the swap.
Hey do you guys recommend using the 5th gen VC or the 4th gen? I'm looking at the pics and wondering which one is actually easier.
Ok I just did the swap this week I got the motor running fine and then I went to a store and came back and the car will not start I checked the spark and I'm not getting any. Did anyone have this problem?? (Dek motor with 4th gen TB, IACV) Please help
If you need pics theres plenty here. http://forums.maxima.org/all-motor/5...pics-vids.html
If your looking for something in particular just pm me. I have pics of every part for the swap.
Same, between aj's thread and mine you should be covered(granted, I link to aj's in mine.
http://forums.maxima.org/showthread.php?t=538119
)http://forums.maxima.org/showthread.php?t=538119
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
ef9
Oct 4, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
