Sponsored by:
Sponsored by: CARiD
Cam timing theory for 3.5 swaps w/out VTC
Old Jun 22, 2006 | 04:48 PM
nismology's Avatar
Reading the VTC vs. RPM thread here and cam timing theory in general i've come to realize that for good top-end power there needs to be as little intake cam timing advance as possible. The A33B ECU starts to retard cam at around 4000 RPM or so and retards it to nearly zero advance at redline. To my knowledge the drillers of the intake cams are doing it such that they're drilling halfway between full advance and full retard. Since the cam angle sweep is 30+ crank degrees, this would mean there is currently around 8* of cam advance with these swaps. While this might be good for mid-range torque, is it possible that these swaps sans VTC can sqeeze out better top-end performance by retarding the intake cam a bit??
Old Jun 22, 2006 | 08:14 PM
mforrest100's Avatar
OK. Reading this thread, is it like this for VQ30's as well since we don't have VTC's??? When I do runs on this side block out by my sister's house I realized that once I go over 6500 RPM's with my JWT the power starts to drop off so I started to shift earlier in second gear for the most part. This kind of goes with what you are saying because the JWT has advanced timing period throughout the entire RPM band. I think that is what is going on.
Old Jun 22, 2006 | 08:35 PM
95BLKMAX's Avatar
Mr. mforrest100, he's asking about CAM TIMING.
What you're pondering about is IGNITION TIMING.
Easy to confuse, but not the same. But you should definatly keep an eye on this thread, its going to get interesting...
Old Jun 22, 2006 | 08:36 PM
OK. I got you. Thanks for the clarification. I ned to go back to some of the EU threads as I believe retarding the cam timing was spoken of at different RPM's.
Matt93SE
Apr 8, 2018 09:23 AM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
95naSTA
Aug 16, 2015 05:03 PM
Blackwind
Aug 5, 2015 06:35 PM
