Sponsored by:
Sponsored by: CARiD
6spd in a 4th gen, what axles?
Old Jun 26, 2006 | 08:24 PM
h2kFrosty's Avatar
Like the subject says... I searched and couldn't find the answer... I'm putting a 6spd (with lsd) into a 4th gen. I need to know what axles to use. Thx.
Old Jun 26, 2006 | 08:25 PM
nismology's Avatar
4th gen manual axles.
Edit: Just noticed it's gonna have LSD. In that case i'd imagine the driver side axle must be an LSD axle.
Old Jun 26, 2006 | 09:03 PM
h2kFrosty's Avatar
REALLY.... Damn that's badass.. I didn't know the 5spd and 6spd used the same axles... sweet.
Old Jun 26, 2006 | 09:23 PM
Kevlo911's Avatar
Kevlo for President
Wanna weld on the 6speed mount for me on my car?
Old Jun 27, 2006 | 09:03 AM
JClaw's Avatar
Let us know how hard the conversion from rod-driven shift linkage to cable-driven is. My bro (who has my old car now) might swap back to a 3.5 next year and he wants to use the 6-speed.
BTW, is it possible to use the 5-speed maxima flywheel and clutch?
Old Jun 27, 2006 | 07:08 PM
vsamoylov
why weld when you can bolt it on
Old Jun 27, 2006 | 07:18 PM
nismology's Avatar
There is no "conversion". You just remove the 5-speed shifter assembly and rods and bolt on the the 6-speed shifter. It has to be the A33B shifter since the A34 shifter is different and won't bolt on. Then you run the shifter cables through the A/T control cable hole in the firewall.
Old Jun 27, 2006 | 07:19 PM
nismology's Avatar
According to Tilley the metal where the mount goes is not thick enough to drill and tap. How did you manage to bolt it on?
Old Jun 27, 2006 | 07:20 PM
vsamoylov
exactly....
Old Jun 27, 2006 | 07:22 PM
vsamoylov
what???? the paint fumes are getting to his head.
Old Jun 27, 2006 | 08:09 PM
Kevlo911's Avatar
Kevlo for President
O rly. This changes everything. Thanks
Old Jun 27, 2006 | 08:33 PM
nismology's Avatar
Old Jun 27, 2006 | 11:15 PM
SpeedCrazie's Avatar
Old Jun 29, 2006 | 09:04 AM
BigLou93SE's Avatar
Originally Posted by SpeedCrazie
In this thread for exactly that.
Old Jun 29, 2006 | 08:25 PM
maximariceboi's Avatar
nice..gota check this out..
Old Jun 29, 2006 | 09:58 PM
h2kFrosty's Avatar
I'll post pictures as soon as I'm done with it...
Old Jul 4, 2006 | 09:49 AM
cld12pk2go's Avatar
Eagerly awaiting pics...
So are there any electronic mods required for the swap? What about speedo issues?
Old Jul 5, 2006 | 06:51 PM
Derrick2k2SE's Avatar
The 6-speed uses the same axles for the open diff or HLSD when used in a 5.5th gen. I know the 5 speed has different axles for HLSD and open diff.
I don't know too much about the 4th gen and I'm not recomending anything. Just thought the info might be helpful.
Old Jul 28, 2006 | 12:21 AM
h2kFrosty's Avatar
and on that note i realized i never really got the answer i was looking for in this thread. So basically the question now is, do I use a stock 4th gen drivers side axle, or a 4th gen LSD axle which is thicker... The 6spd 5.5 gen axle is the same size regardless of LSD or not... so which axle would I use with a 6spd in a 4th gen then? vsamoylov or tilley might have to chime in for this one since they would probably know.
Old Aug 7, 2006 | 12:59 PM
vsamoylov
waht year maxima is the 6 speed tranny comming out of? the reason for that question is the axles are different length in the 5.5 and the 6th gen.
easiest way to answer your question is by asking how many splines are there in the 4th gen hub and how many splines are there on the 6 speed axle. if the numbers match up then go for the 6 speed axle. hope that makes sense.
Old Jan 1, 2007 | 05:51 PM
MAXSE5SPD's Avatar
not to bring up old threads, but im wondering the same thing.
my trans is a 03 hlsd, going into a 95 open diff. does anyone know how many splines the 03 axles have?
PH98I30
29
Feb 10, 2025 12:03 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
