3.5 owners w/ debuloz/ebay cams
How have the Debuloz/ebay cams affected your idle? Is it obvious that you have a set of aftermarket cams or does the loping sound only occur at WOT? Also, did you have to raise your idle speed?
You shouldn't have a problem with that idle issue. As long as you keep your idle rpms adjusted above 700, you shouldn't even stall. The only time it stalls is if it gets down below 600'ish. Sometimes, when you rev up and let the rpms come down, it may go past the 700 mark towards 500, it'll feel like it's stalling, but it'll fight itself back to idle. Oh yeah, it shakes pretty rumbly when it's below 700 rpms. Your loping sound comes from low rpm idles. The higher it gets, it'll disappear. and WOT sounds ear piercing mean.
From what I found, these cams are supposedly copied versions of jwt cams.
Other than that, I have jwt 3.0 cams on my 3.5 swap, and it's pretty similar to what they described it to be.
