*cam Spacers From Tilleys99*
Originally Posted by mforrest100
I believe Jclaw has one for sale. But to be honest I think the best route would to go eng92's way. Swap in the necessary parts of the harness.
honestly, I'd just redrill the sprockets and be done with it.. if you screw up.. it's a lot easier to replace a sprocket, than it is a cam.
I dunno... the only somewhat challenging aspect that I can think of with a 4th gen or early 5th gen, would be putting the drive by wire pedal in.. As for a harness.. you can nab one off of a SE-R, Maxima, Altima.. whatever.. it's 6 wires... and they all lead to the sub harness on the ECU. It might take you an hour to stretch out 6 wires, and loom them up.. then solder/crimp them to the accel pedal harness plug, and label them... run it behind your dash.. and up to the sub harness plugs.. From there, just peep into the FSM, to get your 2 5 volt feeds, grounds, and return signals.. (there's 2 potentiometers in the pedal).. The other thing would be to wire in the 4 wires for the TB relay.. Nothing major.. After that, you would wire up the fuel pump trigger, tach trigger, speedo, coolant temp, and whatever misc. emissions crap you want hooked up.
As for the pedal... go to lowes.. get some 1/8" steel flat bar, or aluminum, if you have the capability to weld it.. take your old pedal off.. and make a bolt template.. get your spacing how you need it, and build an adaptor. I've made several, going the other way around.. (cable style in a electronic pedal car), so I know that it works..
It seems complicated.. but, it's really not too bad.. I understand the down time issue though.. Maybe, I'll be able to tinker with this more, in the future, and get some diagrams and such for you guys to look at.
How's your car running with the new ECU, spig?
Travis
Travis
Hey im getting a set of vq3.5 cams and was wonderign if any of you can make me an adapter for them i have a 01 max with the vq3.0 de-k. I pm-d turbo but he hasnt responded. Since Tilley seems to take forever from your guys post. Thanks for the help.
I did try to contact u via PM but u never responded. Please PM me ur contact info. If ur busy its cools but since u said u would I figure I could take ur owrd 4 it. PM when u get a free chance so I can discuss it more wit u. Thanks
Have any of you guys heard from tilley yet?!?! Because i bought a 3.5 motor w/3.0 changeover like 5 months ago and i call, im, leave messages and everything he never answers my calls or returns them. that has put a lot of modding 2 the side that cant be done until I HAVE MY MOTOR!! im so fed up with it, if any of u could possibly get ahold of him 4 me in the next few days i would greatly appreciate it cuz im just about to make a trip to penn. and if thats what it comes down to i will not be a happy camper!
WOW!!! I am so sorry to hear that my man. I hope everything works out. And trust me when I tell you, I would have made the trip after 3 months of no response.
Mike
Mike
I would suggest buying the spacers/adapters from someone else, and contiue to try and get the matter resolved with Tilley. I know you dont want to shell out more money for a part you should have but atleast this way you can finish your swap.
Its frustrating to have your work halted by one part
Wow Tilley's highly regarded name is slipping. To be honest I was all for Tilley, his information, and contributions to the Maxima community, but to have two situation in which both result in no refund is not very cool. After all his hard work I still find it very hard to believe he has scammed people after working so hard in the maxima community. Obviously (and common sense) says there is a reason, whether it is legit or not, and I am curious to know it. I was considering purchasing a 3.5 through him since it would pretty much guarentee the engine would be healthy, but now ..............
Am I the only person seeing that his guy said that he paid for a motor? He probably lost out about $1200. Please correct me if I am reading wrong.
Maybe some PA members can swing by to see if his shop is even still at the address.
I just posted my experience with Tilley in the dealership and vendor feedback section. Here's the link: http://forums.maxima.org/showthread.php?t=491290.
Yes, if any of u around pa could go by 2 see if he is still there that would b great! i am going up to the rod run in gatlinburg, tn so i will be around a quarter of the way up there. ive been planning on making an appearance monday morning after its over
ps
ive tried every way i know to get in touch with him and if u cant talk to him u cant get a refund
ps
Maxboy23
Aug 11, 2015 11:59 AM
