Sponsored by:
Sponsored by: CARiD
3.5L: Is it just me or does oil pickup at startup seem a little slow?
Old Aug 17, 2006 | 01:33 PM
csb's Avatar
csb
It seems that when I start the car (if it's been off for more than, say, 20 minutes or so) the oil pump's a lil' slow to circulate the oil and build full pressure. I typically hear a little valvetrain clatter for about a half second or so before pressure builds. I did use the 3.5 oil pump in the swap and everything's running great...I just don't recall the VQ30DE exhibiting this behavior. Anyone else having this experience? I've seen other threads recently re: using other pumps entirely...is this why?
Old Aug 17, 2006 | 02:04 PM
nismology's Avatar
Did you use new o-rings between the oil pan and oil pump/engine block? And if you did, are you sure that they were seated properly when you installed the upper oil pan?
Old Aug 17, 2006 | 02:09 PM
csb's Avatar
csb
No, I didn't use new o-rings (as the motor had 600 miles on it and EVERYONE I asked...including two dealers and several other org'ers...said it wasn't necessary) and yes, I am certain they were in the right place. I checked them several times beforehand and as I was installing the upper pan. I inspected each one and they couldn't be told from new, BTW. Strange...
Old Aug 17, 2006 | 02:21 PM
nismology's Avatar
How long does the oil light stay on after the motor starts?
Old Aug 17, 2006 | 02:31 PM
csb's Avatar
csb
Well...I just went out and did a "test-start"...the car's been off now for roughly one hour. The oil light went out immediately as the engine started. When I cold-start it in the morning, it always goes off within one second. These are the reasons why I'm wondering if it's simply the nature of this particular beast. Hey Nismology...check my other post about a tiny oil leak I'm experiencing and give me your 2 cents . Thx.
Old Aug 17, 2006 | 05:59 PM
diymaximakid's Avatar
Mine does the same thing.
Old Aug 17, 2006 | 06:16 PM
Nismo3112's Avatar
Custom User Title
Mine did the same thing.
Old Aug 17, 2006 | 09:31 PM
tavarish's Avatar
fwd gone rwd cr00
Mine does the same thing. It's normal.
Old Aug 18, 2006 | 07:29 PM
eng92's Avatar
Well in this case I guess it is ok to be the odd man out.
My oil light goes out as soon as the engine catches and there is never any valvetrain "clatter"
Mind you I had the engine stripped down to just the block (with the crank in it) and every part hit the parts washer before it was re-assembled with all new seals and gaskets used.
Old Aug 18, 2006 | 07:45 PM
csb's Avatar
csb
While I didn't have the motor torn down to the block, it had a Carfax-verified 600 miles at startup, looks brand new inside and has new gaskets (save for the head gaskets of course). I'm relieved, at least, to hear others experiencing the same pattern.
Old Aug 18, 2006 | 07:56 PM
nismology's Avatar
I don't think what you all are hearing is valvetrain clatter. My guess is that it's the timing chain and tensioner. I know the 3.5 tensioner has a gasket between it and the oil gallery and the 3.0's doesn't. Maybe that allows oil pressure to build up inside the 3.5 tensioner sooner.
Old Aug 18, 2006 | 07:58 PM
csb's Avatar
csb
Good theory.
Old Aug 18, 2006 | 08:02 PM
nismology's Avatar
Ehh..turns out i was wrong. I remember looking up the diagram in the FAST program and seeing a gasket there but i just checked and there isn't one. Nevermind me...sorry lol
Old Aug 18, 2006 | 08:08 PM
csb's Avatar
csb
In that case...bad theory . I was wondering why I couldn't remember removing a tensioner gasket from the 3.5 when I stripped it.
Old Aug 22, 2006 | 06:44 AM
virgilio7's Avatar
it must be the oil filter. when you use nissan oil filter they have some type of valve. do you use nissan oil filters or aftermarket?
Old Aug 22, 2006 | 06:52 AM
csb's Avatar
csb
I'm using a K & N oil filter. The one I used b4 this was another brand (STP, I think). Same oil pickup with both filters.
Old Aug 22, 2006 | 09:45 AM
indecentspeeds1's Avatar
my car makes the same noise.
Old Aug 22, 2006 | 07:27 PM
virgilio7's Avatar
try using nissan oil filters and check back again. is only an oil change and 7 bucks for the filter.
mclasser
22
Nov 12, 2020 01:58 PM
D Mason
Jun 21, 2016 04:43 AM
05RLS2
Apr 14, 2016 11:49 AM
Andy29
Sep 29, 2015 05:32 AM
