3.5 swap using de-k timing equipment in 4th gen?
Old 09-13-2006, 10:52 AM
matts95max's Avatar
ok I need to know if I can use all of the timing stuff from a de-k I have sitting around? Its going in my 95, now I dont know if the signals from the de-k's timing will read? I had the de-k in the car and it work so I dont see y I couldnt put all the de-k timing stuff on the 3.5 and it work just fine..knowlege is welcome! thanks guys
matts95max is offline
Old 09-14-2006, 08:44 AM
matts95max's Avatar
no one knows?
Old 09-14-2006, 09:22 AM
SDot82's Avatar
if its working in your car now then it should work if you swap it over. Just compare FSM's for the 95-99 to 2000-2001.
SDot82 is offline
Old 09-14-2006, 09:23 AM
fwd gone rwd cr00
tavarish's Avatar
yes you can use the dek components just fine, i'm using dek timing equipment in the vq35 auto i'm building.
tavarish is offline
Old 09-14-2006, 11:30 AM
matts95max's Avatar
ok sweet, that makes getting prepped much easier and faster! thanks tar!
Finkle
09-27-2015 09:53 PM
schmellyfart
09-25-2015 04:47 PM
95naSTA
08-16-2015 05:03 PM
95naSTA
08-16-2015 05:02 PM
Blackwind
08-05-2015 06:35 PM
Quick Reply: 3.5 swap using de-k timing equipment in 4th gen?
