Sponsored by:
Sponsored by: CARiD
SE-R Engine
Old Sep 27, 2006 | 06:37 PM
  #41
DirtyErnie's Avatar
why not re-build the original engine? (hope i didn't miss something)
Old Sep 27, 2006 | 08:19 PM
  #42
SPiG's Avatar
SomePsychoGuy
If you can get a A34, Altima SE-R, or any other newer VQ35 with low mileage at a good price then swap it in and just change over anything that isn't exactly the same (should be minimal). If you can find a 02-03 VQ35 for cheap then just direct swap it. There really shouldn't be anything on the engine itself that will give you power. Getting headers, EMU, and gutting the VIAS would be much better attempt at more power than trying any kind of VQ35 to VQ35 swap unless an HR or Rev up was involved.
The newer VQ35s have external EGR, so just use your older VQ35 IM that doesn't have it. Putting headers on while you have the engine out will save you an enormous amount of time and frustration and give you a very good amount of power.
Old Sep 27, 2006 | 09:29 PM
  #43
MaxBlack97's Avatar
I think they give some decent power but not as much to cams or aftermarket y pipe for that matter IMO
Old Sep 27, 2006 | 09:38 PM
  #44
NmexMAX's Avatar
dot dot dot ...
are you referring to?
Old Sep 28, 2006 | 07:30 AM
  #45
MaxBlack97's Avatar
the aftermarket mod that gives the most power for the 3.5 motor between headers, cams and the y-pipe.
Old Sep 28, 2006 | 07:44 AM
  #46
scrhale's Avatar
Everyone knows headers are the best mod for the 3.5 because of their restrictive exhaust manifolds. Cams are not that effective. The y-pipe doesn't provide that good of gains for the 3.5 because the pre-cats are in the exhaust manifold (thus the beauty of headers).
Old Sep 28, 2006 | 10:18 AM
  #47
SPiG's Avatar
SomePsychoGuy
Cams can be very effective, but they are also expensive and hard to install compared to most bolt ons and piggy backs. Look at the the Z/G forums to see some gains from cams.
All headers come with Y pipe. Y pipe by itself will not give great gains on a VQ35.
Old Sep 28, 2006 | 12:53 PM
  #48
MaxBlack97's Avatar
Yea ur right, I am thinking 4th gen terms (swap). Using the 4thgen exhaust manifold.
Old Sep 28, 2006 | 05:02 PM
  #49
NmexMAX's Avatar
dot dot dot ...
Not the cheap **** sleaze ghey units.
But all quality headers do in fact come with their own y-pipe that only works with that set of headers and likewise for the headers. (they will only work with their own respective y-pipe)
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
